bjfrog Posted August 7, 2008 Share Posted August 7, 2008 (edited) About WinFlipWinFlip is a 'Flip 3D' function for Windows XPIt provides an alternate window-switcher to the standard Windows Alt-Tab. Winflip displays all open windows in a 3D stack, which the user can flick through and select using either keyboard or mouse.RequirementsOS : Windows XPLibrary : DirectX9.0c(2004 Summer) (only if SP1 or earlier)Official FroumWebsiteOfficial MirrorCautionAccording to their free redistribution rules I don't modify and add any file(s) from the original zip archive even all the features keep the default state,and I only made it to be a INF addon that can be integrated into I386 and installed it manually and uninstallable Basic UsagePress "WIN + TAB" key to apply "Quick flip"to your windows when WinFlip start,you can change other features by mouse "right click" WinFlip tray icon.I found using mouse can handle all the Flip 3D windows operations ,this function is awesome!Download it ,enjoy itWinFlip AddonVersion: 0.50 (5/25/2008)SIZE: 526 KB (539,627 bytes)MD5: 9E141E82BE134798D8C448C991AB6112 Edited August 9, 2008 by bjfrog Quote Link to comment Share on other sites More sharing options...
AMIRZ Posted August 7, 2008 Share Posted August 7, 2008 looks nice! thanx alot. btw, do yo know how to create a custom quicklaunch shortcut instead Win/Alt + tab? i would love it Quote Link to comment Share on other sites More sharing options...
hairbautt Posted August 8, 2008 Share Posted August 8, 2008 Just create a shortcut to the main *.exe (winflip.exe). When you click it and winflip is already running, it'll activate the 3-d environment. Quote Link to comment Share on other sites More sharing options...
bober Posted August 8, 2008 Share Posted August 8, 2008 thx,AMIRZ, winflip has a config file;WinFlip.ini Quote Link to comment Share on other sites More sharing options...
bjfrog Posted August 8, 2008 Author Share Posted August 8, 2008 looks nice! thanx alot. btw, do yo know how to create a custom quicklaunch shortcut instead Win/Alt + tab? i would love itI think using AutoIt scripts can do it perfectly ,unfortunately i'm a starter on AutoIt things,so I'll do a quicklaunch shortcut for you as soon as by me the AutoIt scripts. Here is a sample,run it when WinFlip starting,Flip windows will hung on your desktop 5 sec, its not a solution,its a method,enjoy the sample Quote Link to comment Share on other sites More sharing options...
AMIRZ Posted August 8, 2008 Share Posted August 8, 2008 (edited) again thanx all trying now...EDIT: think using AutoIt scripts can do it perfectly ,unfortunately i'm a starter on AutoIt things,so I'll do a quicklaunch shortcut for you as soon as by me the AutoIt scripts.Here is a sample,run it when WinFlip starting,Flip windows will hung on your desktop 5 sec, its not a solution,its a method,enjoy the sample biggrin.gifbjfrog, :dribble: IT WORKS PERFECTLY! THANX ALOT MATE! Just manually place the win+alt.exe anywhere or in %ProgramFiles%\Utilities\WinFlip, then create shortcut of it onto QuickLaunch bar. Now, while WinFlip is running, i just click (once) the Quicklaunch shorcut instead of Win+Tab! Again, thx you so much bjfrog. :worthy: You rock !!! (just wonder why they are not including it by default). Could you include it in your add on later? NiceNow i just regret why i purchased Topdesk for about $20 :g: ...grrrr (athough we will always get free update from them till version 2.0). But in comparison, the 3d flip quality of Topdesk is still better than Win Flip though. Dunno why, perhaps VGA card acceleration/support, eh? But as freeware, WinFlip is awesome! Edited August 8, 2008 by AMIRZ Quote Link to comment Share on other sites More sharing options...
bober Posted August 8, 2008 Share Posted August 8, 2008 (edited) on an other note, id strongly suggest removing the mouse gestures from WinFlip.ini.(really annoying)and also the startup,but thats jsut me. Edited August 8, 2008 by bober Quote Link to comment Share on other sites More sharing options...
bjfrog Posted August 9, 2008 Author Share Posted August 9, 2008 on an other note, id strongly suggest removing the mouse gestures from WinFlip.ini.(really annoying)and also the startup,but thats jsut me.@Bober when occur that problem?do you try that sample ,oh,its not worthy to give further try that just provide some info that Auoit scripts can simulate keyboard actions and its really really a childish work Quote Link to comment Share on other sites More sharing options...
bjfrog Posted August 9, 2008 Author Share Posted August 9, 2008 hi everybody why not to try this,just mouse left click taryicon once ,see what happen?Then turn mouse wheel back or front,how about now? and mouse right click can change some featuresthats why I say using mouse can handle all operations,this fouction is really awesome! Quote Link to comment Share on other sites More sharing options...
bjfrog Posted August 9, 2008 Author Share Posted August 9, 2008 again thanx all trying now...EDIT: think using AutoIt scripts can do it perfectly ,unfortunately i'm a starter on AutoIt things,so I'll do a quicklaunch shortcut for you as soon as by me the AutoIt scripts.Here is a sample,run it when WinFlip starting,Flip windows will hung on your desktop 5 sec, its not a solution,its a method,enjoy the sample biggrin.gifbjfrog, :dribble: IT WORKS PERFECTLY! THANX ALOT MATE! Just manually place the win+alt.exe anywhere or in %ProgramFiles%\Utilities\WinFlip, then create shortcut of it onto QuickLaunch bar. Now, while WinFlip is running, i just click (once) the Quicklaunch shorcut instead of Win+Tab! Again, thx you so much bjfrog. :worthy: You rock !!! (just wonder why they are not including it by default). Could you include it in your add on later? NiceHi mate ,nice to hear that but sample is really really a chidish work thats why i say i am still a newbie on that,anyhow it provide you that autoit can simulate keyboard actions.http://www.autoitscript.com/autoit3 Quote Link to comment Share on other sites More sharing options...
bjfrog Posted August 9, 2008 Author Share Posted August 9, 2008 Just create a shortcut to the main *.exe (winflip.exe). When you click it and winflip is already running, it'll activate the 3-d environment.yes ,confirmed, support mouse trigger is awesome! Quote Link to comment Share on other sites More sharing options...
bober Posted August 10, 2008 Share Posted August 10, 2008 i meant that if you do a counter clockwise(or clockwise i dont remember) mouse gesture, it will active the flip, for people that have very sensitive mouse settings like me,win flip triggers easily. Quote Link to comment Share on other sites More sharing options...
bjfrog Posted August 10, 2008 Author Share Posted August 10, 2008 i meant that if you do a counter clockwise(or clockwise i dont remember) mouse gesture, it will active the flip, for people that have very sensitive mouse settings like me,win flip triggers easily.I like click trayico that will avoid a fleet of flips hanging your desktop by accidentally mouse operation Quote Link to comment Share on other sites More sharing options...
