[Solved] Some of the problems. Is it personal or bug
@ Legolash2o primarily due to work for this beautiful thank you very much. Due to lack of knowledge of language translation with google translate did. I hope you understood my problem and wrong in a situation not cause I can tell. I'm sorry if I open such a situation.
WT Version : Test 4
Windows 7 Turkish - Professional version
Features, including the old version does not work.
1. Desktop Icon Size::16
2. Disable Language Bar
Working in previous versions, but the latest version does not work;
1. Disable Highlighting of new Programs
post-8298-0-30760600-1360014110_thumb.pn
2. Language pack is integrated into Internet Explorer. However, the system installation is complete, Internet Explorer works in English instead of Turkish.During integration does not consist of any error.
When Windows Update and check for updates, language pack seems to be not installed. After the installation is operating normally.
Thanks for the quick solution. :-) @Legolash2o
Probably a better solution would be to remove.
Finally, I want to ask you something.
Do you think in the future to provide multi-language support?
@Legolash2o,
I test it beta WinToolkit141-15_Test14
1. Desktop Icon Size::16  - Not working. I investigate have a free time.
2. Disable Highlighting of new Programs - Worked.
3. Language pack is integrated - Not working
Edit;
Default user and administrator account registry settings correctly changed to 16, but this tweak not working.
I cant understand why not working. :)
Edited by X-Force
What was the last version that this worked correctly?  (With everything else except the Win Toolkit version used being exactly the same.  Same Win toolkit options used, same exact sources used including same wim used and same Win7 version chosen, same set of tweaks and addons, same hardware and host OS used to make the build, etc.)  Any error logs produced?
Hi,
afaik ie language packs cannot be integrated, i always install mine as sfx and that works well.
just add the language pack file as installer/sfx.
Greetz X23
Edited by x23piracy
