WinToolkit Installer position
Can you control the position of the WinToolkit Installer?
If yes, I'd suggest to make it apear on top center instead of where it comes up now.
I'm asking this as all the windows that come in the procces of installing silent apps (progres, extraction, finish) are covered by the main window.
If the main window appear on top center than the rest of the windows will be visible on the middle of the screen not (partialy) hidden by the main window.
This is mostly cosmetic but I like to know what happens in every stage.
