March 6, 201313 yr Hi, like the subject asks which is the right tweak and is there one? i found this in the tweaks but that is no enable disable option, i have to choose an amountof items from to. Greetz X23 Edited March 11, 201313 yr by x23piracy
March 7, 201313 yr Author Hi, I haven't tried it, but what happens if you enter "0"? Cheers and Regards that's the point no way to enter 0 it starts with 1. Greetz X23 Edited March 7, 201313 yr by x23piracy
March 7, 201313 yr You can try: Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_TrackDocs"=dword:00000000"Start_TrackProgs"=dword:00000000
March 7, 201313 yr Author Hi, Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_TrackDocs"=dword:00000000"Start_TrackProgs"=dword:00000000 is that also usable as HKLM?I want it for the complete machine. Greetz X23
March 7, 201313 yr It's about those two options: Start_TrackProgs = Store and display recently opened programs in the Start menuStart_TrackDocs = Store and display recently opened items in the Start menu and the taskbar http://www.sevenforums.com/tutorials/265-start-menu-customize.html Regards *Edit:There is only one question and the OP was finding inside reg options (Start menu) to find those options!But they are not inside WinToolkit options! Edited March 7, 201313 yr by myselfidem
March 7, 201313 yr I think there are more than one question there Legolash2o. The first one should be these options: The second question relates to the enabling / disabling of jump lists. Edited March 7, 201313 yr by crashfly
March 9, 201313 yr Hi, is that also usable as HKLM?I want it for the complete machine. Greetz X23 Adding this registry file inside the mounted hive NTUSER.DAT works fine ! Tested !
March 10, 201313 yr Author Hi, Adding this registry file inside the mounted hive NTUSER.DAT works fine ! Tested ! that means open the registry like this?: Which is NTUSER.DAT? WIM_Default or WIM_Software?Sorry iam a little bit confused with the names and right meanings... damn PS @Lego that window is to tiny and can't resized. Greetz X23 Edited March 10, 201313 yr by x23piracy
March 10, 201313 yr I tested successfully like this:1 - Using this batch file:REG_Hive.cmd@echo offColor 0Arem adapt folder name, index and mounted folder to your needs !rem set the registry key (Tweaks.reg) inside the folder C:\DISM_Temp created previously.echo."C:\Program Files\Windows AIK\Tools\x86\Servicing\Dism.exe" /Mount-Wim /Wimfile:"C:\Win7_SP1\sources\install.wim" /index:1 /MountDir:"C:\work"echo.pauseecho.reg.exe load HKLM\WIM_Default "C:\work\Users\Default\NTUSER.DAT"echo.pauseecho.reg.exe import "C:\DISM_Temp\Tweaks.reg"echo.reg.exe unload HKLM\WIM_Defaultecho.pauseecho."C:\Program Files\Windows AIK\Tools\x86\Servicing\Dism.exe" /Unmount-Wim /MountDir:"C:\work" /Commitecho.echo ==Appuyez sur n'importe qu'elle touche pour quitter==&pause>nulTweaks.regWindows Registry Editor Version 5.00; Disable: Store and display recently opened programs in the Start menu; Disable: Store and display recently opened items in the Start menu and the taskbar[HKEY_LOCAL_MACHINE\WIM_Default\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_TrackDocs"=dword:00000000"Start_TrackProgs"=dword:00000000 Edited March 10, 201313 yr by myselfidem
March 11, 201313 yr Author Maybe Legolash2o can add this new tweak inside WinToolkit ? @Lego Yes please
April 16, 201312 yr Great tweak. I'll add it in the tweaks requests thread, however divided in two, as only one (half) I find to be very useful - the one about recently opened docs. I've firstly tried them both, but I get a half-blank start menu screen, because I also used the ''disable programs'' tweak. And I cannot make windows 7 behave like windows xp, and show all programs by default instead, at least not through tweaks. The only way is through a small app that always loads when windows starts, but this is not an elegant solution. So I'll keep using the windows default setting when it comes to showing recently opened programs in the start menu. I prefer this by default instead of a blank screen.
