[BUG] WTK doesnt allow to choose different parts from different presets
Hi,
i don't understand why i cannot choose different entry from different presets.
Lets say two different presets and i want options and installers from first preset
and updates and addons from a seconds one.
I cannot see any reason why that shouldn't work.
Why is that not possible?
@Lego please make it possible if possible :)
EDIT: WTK 1.4.1.15
Greetz X23
Edited by x23piracy
If I understand your question in the right way, this feature is already present!
If you have a preset with ALL your entries, let's say preset-all.ini, you can load it and the save every tab alone under "Presets/Save XYZ"; after that you can load every single preset you need (but not a part of a preset).
Gruß, Thiersee
Hi,
no i talk about the automatism that creates ini with the recent changes.
If you start WTK again preset manager open and lets you choose which preset to load.
Then it's not possible to choose some parts of different presets.
You can only choose parts from same preset!
Greetz X23
What I mean is:
you can save every single tab, for example AddOn1, 2, 3, Installers1, 2, 3, Option 1, 2, 3, Updates1, 2, 3;
after that you start WTK without choosing a particular preset (Skip, No Preset) and in every single tab with "Load Preset" you can load what you want, let say AddOn1, Installers2 and so on.
It's not automatic, but I think it's not a bug and you cant put it into "Requests"-thread.
Gruß, Thiersee
Hi,
The feature has not been implemented, so technically it's not a bug. You can load each tab individually if you want but until someone posts about it in the requests forum, i wont add it :)
stupid me i will place it at the right place ;)
Greetz X23
