June 16, 201312 yr Hello, guys. It seems i can't find the following update KB2647753 but v4. I only find up to v2 on MS website. Can some1 help please? Thanks.
June 16, 201312 yr I assumed you wanted Windows6.1-KB2647753-v4-x64 http://www1.datafilehost.com/d/48fd7f0a
December 15, 201311 yr I am only download version 2...the version 4 therisn't ....thanks Edited December 15, 201311 yr by mattew
December 15, 201311 yr Yeah, I was going to suggest looking here, but it seems it is also only v2. So, I can find torrents for it, but where did v4 come from? Is it not an official MS release? Cheers and Regards
December 16, 201311 yr I got v4 on update catalog. Direct link: http://download.windowsupdate.com/msdownload/update/software/updt/2012/10/windows6.1-kb2647753-v4-x86_165012a593fa109fc0b502ab2ed70d9e6a1d84dc.msu
December 16, 201311 yr Thanks. For completeness, here's the direct link for the x64 version: http://download.windowsupdate.com/msdownload/update/software/updt/2012/10/windows6.1-kb2647753-v4-x64_ca4e3f204c16f2ca28523d855f06fb4fa0d61ec7.msu By the way, the update catalog also works using IE Tab Classic extension under Chrome. @mooms, I was able to get the direct link for the x64 version by modifying the link you provided with the x64 filename, but how did you get the direct link for the x86 version? Cheers and Regards
