[Solved] Messagebox "error" while installation after using tweak
hi,
starting installation and after extracting files and restarting it loads services and after the installation screen appears i´m getting this Messagebox after using this tweak:
Allow 3rd Party Themes
im using windows 7 x64 Ultimate
my iso was untouched by any tools exept winreducer (i removed components with All in one Integrator)
... my iso was untouched by any tools exept winreducer (i removed components with All in one Integrator)
I'm sorry, but as long as you are using ANY other tools other than Win Toolkit itself, then I am going to believe that any errors you get are the fault of the other tool. Unless you get the error without using any other tools, then you should make your error reporting at a forum for the other tool. This is a forum for reporting errors caused by Win Toolkit, not for errors caused by another tool that happen to show up when you also use Win Toolkit.
ahh sorry because i didnt sleep much i wrote some **** xD
 i wanted to write wintoolkit not winreducer !
so the sentence should be :
"my iso was untouched by any tools exept wintoolkit (i removed components with All in one Integrator)"
so to make it clear only wintoolkit was used no other tools !!!
Edited by KrX
What version of WinToolKit were you using when this error occurred?
And while you are at it, what components did you remove?
Side note:  have you tried your install without removing any components?
i tried again with an untouched iso
i didnt even remove any components via wintoolkit only applyed this tweak and i get this error again
I get the same error. I do not understand what you mean Telios?
wait guys i tell you when you go delete the -ms from regedit..
Yes, but you did not actually clarify what you meant.
He might not have any idea that you mean from the remotely loaded wim's registry file and he might not have any idea where to look since you were not at all specific.
does this fix only the "error"?
can i set a 3rd party theme after doing that?
and what exactly do i need to remove? i searched the whole registry for "-ms" and found a lot of things. after 40 or so i stoped searching
using beta 8 this error dont show up but the first login takes A LOT of time and after that i get this error:
and i cant use a 3rd Party Theme after  that
Did the error autoclose though?
no it didnt close for me (waited 3 min)
Also what are the File Hashes of both the files (on install media and original download)?
MD5, CRC32, SHA-1
which files do you mean? i just used everytime this one tweak nothing more
