[Solved] Wincert "All Editions" - More Images Selected make big problems
The first passage, for example, with "Home" works correctly.
the second passage "Home Premium"
the third passage "Professional"
the fourth passage "Ultimate"
here are error in the KB integration!!!
But at the first passage "Home" no KB errors!
Yes, this is a know bug since 1.4.29 final, but it's only cosmetic, KB are actually integrated.
It did not exist in 1.4.29.18
other threads about the same bug:
http://www.wincert.net/forum/topic/11988-error-integration-updates/
http://www.wincert.net/forum/topic/11957-this-bug-is-since-1432-14337/
http://www.wincert.net/forum/topic/11731-14302-several-updates-appears-as-not-integrated/
@Liam, are you still considering updating multiple images in Win Toolkit by means of integrating updates into the lowest image of each x86 and x64, and then copying/exporting/promoting the image and renaming it to each other image name desired?  I know you experimented with this method just to verify that it worked, and you said it did, but I don't know if it can be automated with Win Toolkit.  If so, it would solve the above problem and save a LOT of time.
I most likely will do it as part of the FYP. AIO-Integrator requires the most work and it's at the point where adding anything like that would be quite complex.
It does work and I use it quite a lot for my AIO Disks. For example I upgrade the base image. Copy and paste the install.wim and upgrade it via WIM Manager and then once all of them are done. I merge them back together. There's just many variables to make it public.
