[Solved] 1.4.37.7 - Didn´t work well at all (for me anyway)
It did however upload an errorfile so I hope you can/could analyze it.
What v7 did was to "throw up" on every IE related file I wanted to integrate as opposed to v6 which accepted all updates but KB2533552.
Keep up the good work!
Edited by sweden8
I´m back B)
Using v9 was a pleasure!
Everything went fine, besides KB2533552 which "popped up" as usual... Knowing how to get this annoying KB to go away would be great.
Autounattend, doesn't apply with 1.4.36.2, RunOnce doesn't work at install ! why is that ? I am so frustrated ! I've spend 2 days lurkin ! no luck !
Edited by KEiGHT
shall we treat KB2533552 as silent?, how do we integrate this? been missing a lot of info lately....
Yep but it should of added it to silent for yo anyway.
You need to make your own thread with as much details as possible. Also upload your unattended but remove any person information i.e. replace your name with MY NAME and replace your key with XXXXX-XXXXX-.... :)
Why RunOnce doesn't work !?
It is missing., with other versions RunOnce was at WIN folder to be installed, now is nowhere !
Is totally mess with this version !
Edited by KEiGHT
Cipherfx2, on 26 Mar 2014 - 01:26 AM, said:snapback.png
I have it in the silent "sector" - but it still doesn´t work.
I sow that, but nothing says about WinToolkit_Apps folder where is or to install from !
#Any line starting with a # are comments and will be ignored.
#Lets you specify the configuration of the installers
#InstallDir is where your apps are located.
#DriverDir is which directories to scan for inf files.
#Reboot makes RunOnce reboot Windows after completion.
[Config]
INSTALLDIR=Sources\Apps <<< HERE IS THE PROBLEM ? >>> %DVD%:\WinToolkit_Apps ??? it will do the job if i made this change?
DRIVERDIR=Sources\Drivers
#Here are some other samples.
#INSTALLDIR=E:\Software
#DRIVERDIR=X:\MyDriverCollection
REBOOT=FALSE
#Things which will always get installed. Anything after * is a switch i.e. /S /Q /Silent
[Automatic]
#KBXXXXXX-x64=%DVD%:\WinToolkit_Apps\Windows6.1-KBXXXXXX-x64\Windows6.1-KBXXXXXX-x64.msu
#User will be asked to choose which of the following apps to install.
[Manual]
#Microsoft Office 2013=%DVD%:\WinToolkit_Apps\Office2013\Setup.exe*/configure %DVD%:\WinToolkit_Apps\Office2013\config.xml
#Example 1=%DVD%:\WinToolkit_Apps\ExampleProgram\Example.exe*/s
Edited by KEiGHT
Thanks KEiGHT. When I get back from University, I have the entire day to work on it. What I need to do is:
  • Add logging back into the RunOnce so we can finally find the issue.
  • Add a screen which notifies the user there is no installations and close after 10 seconds.
Been up since 6am (8:13 now) for the past three days to find this issue lol.
That shuld do the trick ;)
[Config]
INSTALLDIR=%DVD%:\WinToolkit_Apps
or you can modify even the apps folder to show like this
[Config]
INSTALLDIR=%DVD%:\Apps
rename your WinToolkit_Apps folder to Apps or Setup or anything you like but specify that FolderName in :\SOURCE\Install.ini !
Edited by KEiGHT
