[SOLVED] Installer-Bug 1.4.38.5, .6, .9, .10, .11, .12 - issue at the end of RunOnce when the job has finished
Hi Lego,
I don't know if this bug the same is as here:
I get always at the end of the install-process (RunOnce Installer) this error
no matter if on VM or real hardware.
With 1.4.38.4 no issue (RunOnce Installer is version 1.4.37.16)
Thiersee
Bug still present in 1.4.38.6.
Thiersee
*bump*
With 1.4.38.7 (Win7 x64 Prof in VirtualBox) seems the bug has gone (1x test).
I'll continue my tests tomorrow.
Thiersee
*bump*
Hi Liam,
with build 1.4.38.9 the same issue like in 1.4.38.5 & .6!
1.4.38.4, 1.4.38.7 & .8 work without this issue.
Regards, Thiersee
Hi Liam,
with version 1.4.38.10 same issue like post #1 & #5 :sad02:!
Thiersee
Edit:
During the last test I saw that an error-log has been uploaded ;).
Error-Log:
Wednesday 28 May 2014 11:43:20 AM +02:00 Mitteleuropäische Zeit
Log ID: 1x8434A6EA12ADF25CAC036E2E38C35D62_Ex060039B2_frmAllInOne_de-DE_432352
NOTE: Use the 'Log ID' when referring to your issue on the forum.
It will allow me to find your log and have a look at the problem easier.
***BASIC***
Error patching theme
***EXTENDED***
C:\WinToolkit_Mount\
***EXCEPTION***
C:\WinToolkit_Mount\\Windows\System32\
InnerException:
Source: System
TargetSite: System.Diagnostics.FileVersionInfo GetVersionInfo(System.String)
***WINTOOLKIT INFO***
Win Toolkit v1.4.38.10*
Win Toolkit Directory: E:\Windows_7_Toolkit-Ausfuehren
Anti-Virus: True
User Temp Path: C:\Windows\Temp\WinToolkit
WTK Temp Path: C:\WinToolkit_Temp
Open Forms: frmAllInOne
Form History: frmStartup, frmToolsManager, frmAntiVirus, frmWIMManager, frmAllInOne, frmAIOPresetManager, frmAntiVirus, frmAIOPresetName
***COMPUTER INFO***
System Directory: C:\Windows\system32
DISM Location: C:\Program Files\Windows AIK\Tools\amd64\Servicing\Dism.exe
DISM Version: 6.1.7600.16385 (win7_rtm.090713-1255)Microsoft Windows NT 6.1.7601 Service Pack 1 (de-DE)
Windows 7 Professional (64-bit)
7601.17514.amd64fre.win7sp1_rtm.101119-1850
Resolution: W 1920 H 1080 D 32
CPU:
Name- AMD A10-7850K APU with Radeon R7 Graphics
Speed- 3700Mhz / 3700Mhz
Cores- 2 / 4
Status- 45% OK
Physical Memory: 3.437 MB / 15.300 MB (11.862 MB Free)
Virtual Memory : 3.251 MB / 30.598 MB (27.347 MB Free)
Drives
C:\ Fix NTFS 132,15 GB / 202,70 GB Internet
D:\ Fix NTFS 209,56 GB / 232,88 GB Internet-1
E:\ Fix NTFS 1.091,58 GB / 1.863,02 GB Verbindung
***OPTIONS***
fAddons=E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Reapers
fDrivers=E:\DriverWin7_F2A85XM\AMD\Support\14-4-win7-win8-win8.1-32-64-sb\Packages\Drivers\SBDrv\SMBus\W764A
fSilents=E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Ricktendo
fUpdates=E:\ServicePacks-Install\Win_7\Updates-Mai\Framework\3.51\x86
sAddRunOnce=True
sAICommands=True
sAVScan=True
sAIOSave=True
sUpdFilter=True
sAIOTIME=09m:11s
sPreventSleep=True
sCheckForUpdates=True
sDLogging=True
sFreeRAM=True
sLastDir=E:\Win7_Prof_x64_DE_SP1_X17-59885
sLastWIM=E:\Win7_Prof_x64_DE_SP1_X17-59885\sources\install.wim
sPLastWIM=E:\Win7_Prof_x64_DE_SP1_X17-59885\sources\install.wim|E:\Win7_Prof_x64_DE_SP1_X17-59885_Test\sources\install.wim|E:\Win7_Prof_x86_DE_SP1_X17-59886 - Kopie\sources\install.wim|E:\Win7_Prof_x64_IT_SP1_X17-59215\sources\install.wim|E:\Win7_Prof_x86_DE_SP1_X17-59886\sources\install.wim|
smCheck=False
sAIOPM=True
sMountTemp=C:\WinToolkit_Mount
sQuickMerge=True
sFormSize=|frmUpdCatalog:896*431|frmAIODiskCreator:760*464|frmAWUpdCatalog:896*984|frmEXEtoMSP:750*400|frmUnattendedCreator:700*706|frmAllInOne:1477*925|frmWIMManager:1123*350
smVerify=False
sSolDownload=E:\ServicePacks-Install\Win_7\Alphawave_Downloader\
sTransparency=100
sTransparencyAll=False
sWinToolkitDISM=High
sWinToolkitExt=Normal
sWinToolkitPRI=Normal
sWinToolkitTemp=C:\WinToolkit_Temp
sUploadLogs=True
sLastISO_Folder=E:\Win7_Prof_x64_DE_SP1_X17-59885
sLastISO_ISO=E:\ISO's\WinToolkit\Test_RunOnce_NoAdmin.iso
sMountLog=True
sShowWelcome=False
sRegistryLog=True
sDismLoc=C:\Windows\System32\Dism.exe
***STACK***
get_GetStackTrace
PrepareLog
Save
Upload
PatchFiles
IntegrateTweaks
BWRun_DoWork
WorkerThreadStart
_PrivateProcessMessage
AsyncProcessMessage
ThreadPoolCallBack
runTryCode
ExecuteCodeWithGuaranteedCleanup
Run
PerformWaitCallbackInternal
PerformWaitCallback
***RAW_STACK***
bei System.Diagnostics.FileVersionInfo.GetVersionInfo(String fileName)
bei WinToolkit.cThemes.GetVersion(String FilePath)
bei WinToolkit.cThemes.PatchUXInit(String sysFol, Boolean x64Mode)
bei WinToolkit.cThemes.PatchFiles(String WimPath)
***RAW_EXCEPTION***
System.IO.FileNotFoundException: C:\WinToolkit_Mount\\Windows\System32\
BTW, the issue is present even if WinToolkit RunOnce does not start or is not present (no SFX-installers).
Edit 2:
Same issue with 1.4.38.11 :sad01_anim: !
Friday 30 May 2014 14:23:52 PM +02:00 Mitteleuropäische Zeit
Log ID: 1x8434A6EA12ADF25CAC036E2E38C35D62_Ex060039B2_frmAllInOne_de-DE_787181
***BASIC***
***EXTENDED***
***EXCEPTION***
InnerException:
Source: System
Win Toolkit v1.4.38.11*
Anti-Virus: True
Form History: frmStartup, frmToolsManager, frmAntiVirus, frmWIMManager, frmAllInOne, frmAIOPresetManager, frmToolsManager, frmWIMManager, frmAllInOne, frmAIOPresetManager, frmAntiVirus, frmAIOPresetName
***COMPUTER INFO***
CPU:
Cores- 2 / 4
Status- 24% OK
Physical Memory: 3.172 MB / 15.300 MB (12.127 MB Free)
Virtual Memory : 2.954 MB / 30.598 MB (27.643 MB Free)
Drives
C:\ Fix NTFS 131,39 GB / 202,70 GB Internet
E:\ Fix NTFS 1.089,87 GB / 1.863,02 GB Verbindung
***OPTIONS***
fSilents=E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Thiersee
fUpdates=E:\ServicePacks-Install\Win_7\WindowsUpdateDownloader\x64
sAddRunOnce=True
sAICommands=True
sAVScan=True
sAIOSave=True
sUpdFilter=True
sAIOTIME=08m:22s
sPreventSleep=True
sDLogging=True
sFreeRAM=True
smCheck=False
sAIOPM=True
sQuickMerge=True
smVerify=False
sTransparency=100
sUploadLogs=True
sLastISO_ISO=E:\ISO's\WinToolkit\Test_wo_autounattend.iso
sMountLog=True
sShowWelcome=False
sRegistryLog=True
***STACK***
get_GetStackTrace
PrepareLog
Save
Upload
PatchFiles
IntegrateTweaks
BWRun_DoWork
WorkerThreadStart
AsyncProcessMessage
ThreadPoolCallBack
Run
PerformWaitCallback
***RAW_STACK***
***RAW_EXCEPTION***
Edit 3:
1.4.38.12 same issue...
Edited by bphlpt
This thread has been split to http://www.wincert.net/forum/topic/12312-problem-starting-runonce-in-win7-x64/.
Please post any problem about starting RunOnce in the new thread!
This thread is for an issue at the end of RunOnce when the job has finished, not on starting.
TnX, Thiersee
EVERYONE, At Lego's request, and to help him keep track of which bugs have been fixed and which ones still need to be addressed, please start a new thread for each unique bug and keep all discussion in that thread on topic and only discuss that bug.  If a different bug is involved please start a new thread.
This bug is to do with the 3rd part themes tweak rather than the runonce
May be, but until 1.4.38.Test4 it has been working.
BTW, the tweak "Allow 3rd party theme" is checked in my ini.
Edit:
OK, now I unchecked the tweak "Allow 3rd party theme" an the issue has gone; themes from my INI are still installed.
If it's OK for you too, the problem is solved.
Again @Cartman586 and @KEiGHT
PLEASE, POST IN THE RIGHT THREAD!
TNX
Danke
Thiersee
Edited by bphlpt
