Liams Iso (KB2533552 & .Net Framework 4.5.2) integratable without RunOnce?
Hi Liam,
you have integrate (without RunOnce!)
- KB2533552
- Microsoft .Net Framework 4.5.2!
How does it work?
Can you provide us to dispose These opportunities?
Please, thats very cool .........
Liams Statement was alaway KB2533552 can not be integrated.
Your ISO Shows us the converse
Liam, can you help me to integrate without runonce:
- Microsoft .Net Framework 4.5.2 LP
- Microsoft Defender 1.175.578.0
- Microsoft Removal Tool 5.12
- Microsoft Silverlight 5.1.30214.0
- Microsoft Visual C++ 2008 SP1 x86
- Windows6.1 KB2533552
? Special thanks, im a donate man
Edited by Cartman586
How does it work?
That is best explained this way:
Technically, the Reverse Integration method is not slipstreaming. The Reverse Integration method captures the Windows image during the installation process and then that Windows image file is applied to the original Windows 7 install files.
If i am correct, you you can use virtualbox, to install windows 7, once reached the place where you enter a username,
You use shift+ctrl+f3 to enter admin account and skip everything else,
Install everything + do the updates you want, after you have done this make sure you enable geniralize or what it was called.
And restart, you will get the language option if you got multiple languages installed + the ability to choose username and what not.
But do not continue just shutdown, mount the image and commit it to the install.wim
This is not a complete guide, have not used it myself fully. but i think he means this.
You will end up with a iso with everything you added to the install in virtual box.
Though i do not know how it go's about with system specific updates as drivers etc.
Hi Cartman,
I write an answer for you in "WinToolkit Request", because this is not a bug ;).
Thiersee
