WinToolkit does not work!
Howdy,
In my previous thread nobody helped me to fix the problem.
I use WinToolkit to just embed the updates to Win 7 Pro SP1 x64.
Nothing else, but it does not work, I have the lastest iso file downloaded from DigitalRiver.
Here's what I do step by step:
1. WinToolkit.exe 1.5.3.3 is on my D: root
2. Copied the contents of Windows DVD into D:\Win7
3. Copied all 182 Windows Updates to D:\Updates
4. WinToolkit (Run as Admin) > Basic > All-In-One Integrator > Browse for DVD/Folder > Select D:\Win7 > Select > Select [Windows 7 PROFESSIONAL]
5. Updates + Languages > Add all updates in D:\Updates folder
6. Start > Accept
Now I get lots of errors same as before!
I have attached my project and logs so someone can helo me or if there's a bug, fix it!
* Please don't hijack the thread, I really need a working solution.
Cheers.
Logs.rar
Howdy,
You don't need to open a new thread, you can continue in the old one!
6. Start > Accept
Again: which image did you download?  If you renamed the ISO, download it again and say us the number (X17-xxxxx):
Your working sequence is OK.
1): OK,; do you use the installer or portable version?
2): How did you copy?
3): where did you get this 182 updates  (or 172?) from?
4): OK
5): OK
6): OK
But:
a) Where is your DISM located? Please post a screenshot of the tab "Options/Misc."
b ) Do you have full access to all your drives (for example F:\WinToolkit_Mount)? You seems to NOT have access to any updates-file!
c) Did you follow the hint from abbodi?
Cheers.
Nobody doubt that you really need help for a working solution, but something seem to be NOT OK with your system, sorry!
I'm using WTK 1.5.3.3 for myself and it works without issues.
Regards, Thiersee
Edited by Thiersee
- attach C:\Windows\Logs\DISM\dism.log
- update your ADK to latest (Update  6.3.9600.17029)
btw, since your current system is Win7SP1, why do you use ADK to update Win7 image?
- you are integrating updates from D:\ , using Dism from C:\ , to Mount directory on F:\ , and Scratch (extract) directory on C:\
so the updates are extracted from d: to c: then copied to f:
that's a long way :P
try to change mount folder to C: or D: , or change Temp folder to D:
Thank you very much Thiersee for your help, I really appreciate it.
If you suggest me to download the iso again, please help me, which link to use to download the latest build of Windows 7 Pro x64 SP1?
1. Portable version (since they recommend it over installer)
2. Load the iso with Virtual CloneDrive, open drive, normally copy all to D:\Win7
3. Installed a fresh clean copy of Win7 Pro x64 SP1, Windows Update, download each one manually from Microsoft rather than installing automatically, now I have 182 .msu updates!
But:
a ) You mean dism.exe? D:\Win7\Sources - When I right click on it, properties shows 6.1.7601.17514 - also check screenshot
b ) Yes I have full access to everywhere! All updates are in D:\Updates and I have access to them.
c ) Which hint? http://support.microsoft.com/kb/968003? Yes!
post-71203-0-90451200-1416045062_thumb.p
Hi abbodi and thank you for your help,
- Attached
- ADK? Windows Assessment and Deployment Kit? From here: http://www.microsoft.com/en-US/download/details.aspx?id=30652 ?
- Sorry here I am confused, please read what I did step by step, I didn't specify to use Dism from C:\ , to Mount directory on F:\ , and Scratch (extract) directory on C:\ - Where can I change that?
This is the wrong screenshot ;)!
I meant "Options/Misc." in WTK-first-window NOT Options in the AIO.
1), 2), 3): OK.
a) No, your working DISM, either in C:\Windows\System32 or C:\Program Files x86\Windows Kits....; OK, I see you are using Windows ADK ;).
@abbodi1406:
Lego should update the download-link for the new version!
Thiersee
Edited by Thiersee
This is the old one!
The new one:
http://www.microsoft.com/de-de/download/details.aspx?id=39982
You don't need to install the complete kit (5,7GB download!), The second point ONLY (Deployment Tools) is enough.
Regards, Thiersee
- Attached
- Where?
- In Options > Misc, change one of Wintoolkit Temp or Mount folder pathes
btw, what are the sizes of the three partitions you have (c:, d:, f:)?
Howdy,
If either of you think it would be beneficial to merge the threads, just let me know and I'll do so.
Hi Thiersee, I have downloaded Windows Assessment and Deployment Kit from the link you gave me, I attached a snapshot of its features, can you please tell me which ones to choose?!
post-71203-0-44663600-1416075055_thumb.p
Just a small and friendly question: do you read what I write?
Regards, Thiersee
Edited by Thiersee
I think the problem was Windows Assessment and Deployment Kit not installed correctly, now it's OK.
But I still consider it as a problem with software, when Windows Assessment and Deployment Kit is not installed, why it throws improper exceptions/errors?
Access errors are not right ones, in the next version, they should fix it somehow, that if Windows Assessment and Deployment Kit is not present, correct error message is shown :)
2 more questions:
1. When updates are integrated in my above steps, where is new Windows image placed? In the same folder D:\Win7 ?
2. How to make iso file bootable with new Windows contents? I choose Make ISO but I get this error:
Aborted (1)
ISO creation was cancelled!
[cdimage.exe -L"Windows 7 Pro" -m -o -u2 -udfver102 -h -bootdata:2#p0,e,b"C:\Windows\WinToolkit_Temp\BIOS.com"#pEF,e,b"C:\Windows\WinToolkit_Temp\UEFI.bin" "D:" "D:\7.iso"]
OK
Hi,
Windows ADK is NOT necessary for the integration, the DISM-program available in "c:\windows\system 32\" is enough!
In the folder you typed in in the ISO-Maker ;)!
Of course NOT, you can't save the ISO in the same folder you make the ISO!
The ISO is already bootable without any other data; this is what I always use
Thiersee
Edited by Thiersee
So why I receive this error from Make ISO window:
Aborted (1)
[cdimage.exe -L"D:\" -m -o -u2 -udfver102 -h -bootdata:2#p0,e,b"C:\Windows\WinToolkit_Temp\BIOS.com"#pEF,e,b"C:\Windows\WinToolkit_Temp\UEFI.bin" "D:\Win7" "D:\7.iso"]
OK
I got that error when I tried to create the ISO when the ISO was still opened by VMWare Player in the VM I still had running.
Another possible source of this error.
Clark.
