I am trying to create a fully updated windows 7 install disc. This is my first time to use win toolkit.  After following all the instructions to the letter, I got this Error.
An error occurred whilst integrating an update!
Exception:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Admin\Desktop\Slipstream files>chcp 65001
C:\Users\Admin\Desktop\Slipstream files>Set SEE_MASK_NOZONECHECKS=1
C:\Users\Admin\Desktop\Slipstream files>"C:\Windows\System32\Dism.exe"  /Image:"C:\WinToolkit_Mount_64222ED2515EF89F1B4FEA06A5813C24" /Add-Package /PackagePath:"C:\Users\Admin\Desktop\Slipstream files\Updates\Windows7-x64\Security\Windows6.1-KB3042058-x64.msu" /ScratchDir:"C:\Windows\WinToolkit_Temp\ScratchDir_8EF59CA91979F74A7608356A5C48F645" /English
Deployment Image Servicing and Management tool
Version: 6.1.7600.16385
Image Version: 6.1.7600.16385
Processing 1 of 1 - Adding package C:\Users\Admin\Desktop\Slipstream files\Updates\Windows7-x64\Security\Windows6.1-KB3042058-x64.msu
C:\Users\Admin\Desktop\Slipstream files\Updates\Windows7-x64\Security\Windows6.1-KB3042058-x64.msu: An error occurred applying the Unattend.xml file from the .msu package.
For more information, review the log file.
 Error: 0x800736b5
Error: 14005
The manifest file contains one or more syntax errors.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
C:\Users\Admin\Desktop\Slipstream files>exit
I don't know what to do.
Edited by jungleexplorer
Which version of windows 7 are you using?
this error can occurred , if u use wrong updates on wrong os
example: windows 7 and x64 updates.......don't mix them
check that you're using the right updates, with the right os.
Also update your os often and install runtimes,net, drivers
I am trying to create a Win 7 64bit Install disc.  I downloaded the Win 7 64bit SP1 ISO image from Microsoft servers.  I downloaded updates for Win 7 64 bit in Win Toolkit.  The system I am working on is a Win 7 64bit machine that is fully updated.
That update always make trouble for me too. It should be added to the list to auto move to silent install.
Until then just right click on it an select Move to Silent Installers and all will be fine.
I did this and it completed, but when I try to create an iso file I get this error.
