Nobody knows how to solve the problem "ERROR: please check your internet connection"?
Have you tried all of this?:
Quote
Q: I'm experiencing one of the following symptoms:
  • After selecting a software version, everything grays out and freezes.
  • You receive the message "ERROR. Please check your internet connection." (When the message appears in the status bar, the tool can't connect to HeiDoc.net to update the download lists, but will generally work. When the message comes up in a popup, then the tool can't connect to microsoft.com and won't work.)
  • You receive the message "GetHostEntry failed!" (This is a warning message when the tool is unable to detect whether your HOSTS file has been modified or not.)
A: This is your local connection issue, and can have a number of root causes:
  • You have modified your HOSTS file. Please remove the following two lines.
    0.0.0.0 aa.online-metrix.net
    0.0.0.0 c.bing.com
  • You have installed software that prevents scripts from modifying secure websites, such as certain adblockers, firewalls or similar security related software.
  • You have disabled TLS 1.2 in your internet settings. You can enable it again in the control panel in the Internet Options category.
  • In rare cases, starting the tool as administrator can resolve the issue.
  • In rare cases, installing the latest Windows updates, or updating Internet Explorer or the .NET framework to the latest version can resolve the issue.
You'll find this information here, on FAQ page: Microsoft Windows and Office ISO Download Tool - FAQ
I'm Having the same issue, I tried to use the program on my girlfriends laptop but it says the above error.  I then tried to use the program on my laptop, but all i get when i click windows 7 is a large grey screen and then i'm unable to select any other versions of windows to download.  Any chance someone who can use the tool and send me a link for an English windows 7 professional 32bit iso?
Thanks
Carl
On 10/24/2017 at 8:01 PM, ianymaty said:
That was perfect, Thanks ianymaty, download worked fine, but even after i have made a fresh install of windows, i still can't get the windows tool to work.  I have the same problem as before.  So now must ask again if someone can post another link for a windows 7 image for my girlfriends laptop, (shes German so would prefer the german version), So it would be amazing if someone with a working version of this tool can post up a link for a Windows 7 professional german/Deutsch 32bit iso.
Thank you very much
Carl
Edited by Carl8210
Guys, when you post about this issue, please, inform which OS are you using and if you followed the FAQ.
This issue seems to happen only in Windows 7. At least, i never saw someone complaining about it while trying to use this tool on Windows 8, 8.1 or 10.
I was using the windows 7 download tool with windows 7 pro and had the above problem and with a laptop using windows vista with the same problem also.  I have now installed IE11 and the windows download tool now works perfectly.
Thanks guys for the previous links and help, Hopefully just installing IE11 will be the solution for everyone with this problem.
Update your windows explorer to the latest version!
Open it set it to be default brovser!
Close it!
Run Windows download tool as admin now it should work!
This solved internet connection error for me!59fe0f532ba7a_bandicam2017-11-0420-03-41-268.jpg.56d88ab06dd0fb98a74ee6ad869578aa.jpg59fe0f74013ef_bandicam2017-11-0420-04-18-398.jpg.b8cf4c384aacf2f89b06960da4a8d464.jpg
I get this error too.
This is what comes up in the popup.
URL: https://www.microsoft.com/en-us/software-download/windows10ISO
Document:
<BODY style="transform: scale(0.80)" class=CSPvNext><DIV class=row-fluid data-view4="1" data-view3="1" data-view2="1" data-view1="1" data-cols="1">
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><SPAN class=page-data-sources></SPAN><!-- UHF CSS Workarounds --><SPAN><section id=headerArea data-m='{"cN":"headerArea","cT":"Area_coreuiArea","id":"a1Body","sN":1,"aN":"Body"}'>
<DIV id=headerRegion data-m='{"cN":"headerRegion","cT":"Region_coreui-region","id":"r1a1","sN":1,"aN":"a1"}' data-region-key="headerregion">
<DIV id=headerUniversalHeader data-m='{"cN":"headerUniversalHeader","cT":"Module_coreui-universalheader","id":"m1r1a1","sN":1,"aN":"r1a1"}' data-module-id="Category|headerRegion|headerRegion|headerUniversalHeader|coreui-universalheader">
<DIV id=epb class="x-hidden x-hidden-vp1 x-hidden-vp2 uhfc-universal-context context-uhf" ms.cmpgrp="epb">
<DIV class="c-uhfh-alert f-information epb-container epb-default-color" role=alert ms.pgarea="Epb v2">
<DIV>
<P class=c-paragraph><IMG alt="Microsoft Edge" src="https://img-prod-cms-rt-microsoft-com.akamaized.net/cms/api/am/imageFileData/REZlo1?ver=5722"><SPAN class=c-text-group><SPAN class=epb-launch>Try Microsoft Edge</SPAN><SPAN class=epb-text>A fast and secure browser that's designed for Windows 10</SPAN></SPAN><SPAN class=c-group><BUTTON id=close-epb class="c-action-trigger c-action-cancel glyph-cancel" type=submit aria-label="No thanks" ms.title="EPB-dismiss">No thanks</BUTTON><A id=epbTryNow class="epb-launch c-action-trigger c-action-open" aria-label="A fast and secure browser that&amp;#39;s designed for Windows 10" ms.title="EPB-launch">Get started</A></SPAN></P></DIV></DIV></DIV><A style="Z-INDEX: 800" class=m-skip-to-main tabIndex=0 href="#mainContent" data-m='{"pid":"h:28aa282b","id":"n1m1r1a1","sN":1,"aN":"m1r1a1"}' ms.title="Skip to content">Skip to main content</A><header class="c-uhfh context-uhf no-js " role=banner itemtype="http://schema.org/Organization" data-header-footprint="en-us/mssoftware-download/mssoftware-downloadHeader" itemscope="itemscope">
<DIV class="theme-light js-global-head f-closed " ms.pgarea="Universal Header">
<DIV class=c-uhfh-gcontainer><BUTTON aria-expanded=false class="c-action-trigger c-glyph glyph-global-nav-button" type=submit aria-label="Header navigation menu" ms.title="Mobile menu button"></BUTTON><BUTTON aria-expanded=false class="c-action-trigger c-glyph glyph-arrow-htmllegacy" type=submit aria-label="Close search" ms.title="Close Search"></BUTTON><A id=uhfLogo class=c-logo href="https://www.microsoft.com" data-m='{"pid":"h:32f2fa12","id":"n2m1r1a1","sN":2,"aN":"m1r1a1"}' ms.cmpgrp="GlobalNav_Logo" aria-label="Microsoft" itemprop="url"><IMG class=c-image alt=Microsoft src="https://assets.onestore.ms/cdnfiles/external/uhf/long/9a49a7e9d8e881327e81b9eb43dabc01de70a9bb/images/microsoft-gray.png" itemscope="itemscope" itemprop="logo"><SPAN>Microsoft</SPAN></A>
<DIV class=f-mobile-title><BUTTON class="c-action-trigger c-glyph glyph-chevron-left" type=submit aria-label="See more menu options" ms.title="Mobile back button"></BUTTON><SPAN class=js-mobile-title data-global-title="Microsoft home">Software Download</SPAN><BUTTON class="c-action-trigger c-glyph glyph-chevron-right" type=submit aria-label="See more menu options" ms.title="Mobile forward button"></BUTTON></DIV><BUTTON class="c-action-trigger c-glyph glyph-chevron-left js-primary-paddle" tabIndex=-1 type=submit aria-label="Show previous" ms.title="Previous"></BUTTON><nav id=uhf-g-nav class=c-uhfh-gnav role=navigation aria-labelledby=uhfLogo ms.cmpgrp="nav">
<UL class=js-paddle-items>
<LI><A id=shellmenu_0 class=c-uhf-nav-link href="https://products.office.com/en-us/home" ms.title="Office">Office</A></LI>
<LI><A id=shellmenu_1 class=c-uhf-nav-link href="https://www.microsoft.com/en-us/windows/" ms.title="Windows">Windows</A></LI>
<LI><A id=shellmenu_2 class=c-uhf-nav-link href="https://www.microsoft.com/en-us/surface" ms.title="Surface">Surface</A></LI>
<LI><A id=shellmenu_3 class=c-uhf-nav-link href="https://www.xbox.com/" ms.title="Xbox">Xbox</A></LI>
<LI><A id=shellmenu_4 class=c-uhf-nav-link href="https://www.microsoft.com/en-us/store/b/sale?icid=TopNavDealsSale" ms.title="Deals">Deals</A></LI>
<LI><A id=l1_support class=c-uhf-nav-link href="https://support.microsoft.com/en-us" ms.title="Support">Support</A></LI>
<LI>
<DIV class="c-uhf-menu js-nav-menu"><BUTTON aria-haspopup=true style="WHITE-SPACE: nowrap" aria-expanded=false id=More-navigation type=submit ms.title="More" ms.interactiontype="14">More</BUTTON>
<UL aria-hidden=true class="f-multi-column f-multi-column-6" aria-labelledby=More-navigation ms.cmpnm="More">
<LI class="f-sub-menu js-nav-menu" ms.cmpnm="Container"><BUTTON aria-expanded=false id=Software-navigation type=submit ms.title="" ms.interactiontype="14">Software</BUTTON>
<UL aria-hidden=true aria-labelledby=Software-navigation>
<LI ms.cmpnm="More_Software_WindowsApps"><A id=shellmenu_8 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/windows/windows-10-apps" ms.title="More_Software_WindowsApps">Windows apps</A></LI>
<LI ms.cmpnm="More_Software_OneDrive"><A id=shellmenu_9 class=js-subm-uhf-nav-link href="https://onedrive.live.com/about/en-us/" ms.title="More_Software_OneDrive">OneDrive</A></LI>
<LI ms.cmpnm="More_Software_Outlook"><A id=shellmenu_10 class=js-subm-uhf-nav-link href="https://outlook.live.com/owa/" ms.title="More_Software_Outlook">Outlook</A></LI>
<LI ms.cmpnm="More_Software_Skype"><A id=shellmenu_11 class=js-subm-uhf-nav-link href="https://www.skype.com/en/" ms.title="More_Software_Skype">Skype</A></LI>
<LI ms.cmpnm="More_Software_OneNote"><A id=shellmenu_12 class=js-subm-uhf-nav-link href="https://www.onenote.com/" ms.title="More_Software_OneNote">OneNote</A></LI></UL></LI>
<LI class="f-sub-menu js-nav-menu" ms.cmpnm="PCsAndDevices  "><BUTTON aria-expanded=false id=PCs&amp;Devices-navigation type=submit ms.title="PCsAndDevices  " ms.interactiontype="14">PCs &amp; Devices</BUTTON>
<UL aria-hidden=true aria-labelledby=PCs&amp;Devices-navigation>
<LI ms.cmpnm="More_PCsAndDevices_PCsAndTablets"><A id=shellmenu_14 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/windows/devices" ms.title="More_PCsAndDevices_PCsAndTablets">PCs &amp; tablets</A></LI>
<LI ms.cmpnm="More_PCAndDevices_Accessories"><A id=shellmenu_15 class=js-subm-uhf-nav-link href="https://www.microsoft.com/accessories/en-us" ms.title="More_PCAndDevices_Accessories">Accessories</A></LI>
<LI ms.cmpnm="More_PCsAndDevices_VMAndMixedReality"><A id=shellmenu_16 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/store/b/virtualreality?icid=TopNavVirtualReality" ms.title="More_PCsAndDevices_VMAndMixedReality">VR &amp; mixed reality</A></LI>
<LI ms.cmpnm="More_PCsAndDevices_MicrosoftHololens"><A id=shellmenu_17 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/hololens" ms.title="More_PCsAndDevices_MicrosoftHololens">Microsoft HoloLens</A></LI></UL></LI>
<LI class="f-sub-menu js-nav-menu" ms.cmpnm="Container"><BUTTON aria-expanded=false id=Entertainment-navigation type=submit ms.title="" ms.interactiontype="14">Entertainment</BUTTON>
<UL aria-hidden=true aria-labelledby=Entertainment-navigation>
<LI ms.cmpnm="Products_DevicesAndXbox_XboxAndGames"><A id=shellmenu_19 class=js-subm-uhf-nav-link href="https://www.xbox.com/en-us/games/xbox-one?xr=shellnav" ms.title="Products_DevicesAndXbox_XboxAndGames">Xbox games</A></LI>
<LI ms.cmpnm="Entertainment_PCGames"><A id=shellmenu_20 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/windows/windows-10-games" ms.title="Entertainment_PCGames">PC games</A></LI>
<LI ms.cmpnm="More_Entertainment_WindowsDigitalGames"><A id=shellmenu_21 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/store/games/windows?icid=TopNavWindowsGames" ms.title="More_Entertainment_WindowsDigitalGames">Windows digital games</A></LI>
<LI ms.cmpnm="More_Entertainment_MoviesAndTV"><A id=shellmenu_22 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/store/movies-and-tv?icid=TopNavMoviesAndTv" ms.title="More_Entertainment_MoviesAndTV">Movies &amp; TV</A></LI>
<LI ms.cmpnm="More_Entertainment_Books"><A id=shellmenu_23 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/store/books" ms.title="More_Entertainment_Books">Books</A></LI></UL></LI>
<LI class="f-sub-menu js-nav-menu" ms.cmpnm="Container"><BUTTON aria-expanded=false id=Business-navigation type=submit ms.title="" ms.interactiontype="14">Business</BUTTON>
<UL aria-hidden=true aria-labelledby=Business-navigation>
<LI ms.cmpnm="More_Business_MicrosoftAzure"><A id=shellmenu_25 class=js-subm-uhf-nav-link href="https://azure.microsoft.com/en-us/" ms.title="More_Business_MicrosoftAzure">Microsoft Azure</A></LI>
<LI ms.cmpnm="More_Business_MicrosoftDynamics365"><A id=shellmenu_26 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/dynamics365/home" ms.title="More_Business_MicrosoftDynamics365">Microsoft Dynamics 365</A></LI>
<LI ms.cmpnm="Business_Microsoft365"><A id=shellmenu_27 class=js-subm-uhf-nav-link href="https://www.microsoft.com/microsoft-365/?omkt=en-US" ms.title="Business_Microsoft365">Microsoft 365</A></LI>
<LI ms.cmpnm="Products_ForBusiness_CloudPlatform"><A id=shellmenu_28 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/server-cloud/" ms.title="Products_ForBusiness_CloudPlatform">Cloud platform</A></LI>
<LI ms.cmpnm="More_Business_Enterprise"><A id=shellmenu_29 class=js-subm-uhf-nav-link href="https://enterprise.microsoft.com/en-us/" ms.title="More_Business_Enterprise">Enterprise</A></LI>
<LI ms.cmpnm="More_Business_DataPlatform"><A id=shellmenu_30 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/sql-server/ " ms.title="More_Business_DataPlatform">Data platform</A></LI></UL></LI>
<LI class="f-sub-menu js-nav-menu" ms.cmpnm="Container"><BUTTON aria-expanded=false id=Developer&amp;IT-navigation type=submit ms.title="" ms.interactiontype="14">Developer &amp; IT</BUTTON>
<UL aria-hidden=true aria-labelledby=Developer&amp;IT-navigation>
<LI ms.cmpnm="More_DeveloperAndIT_MicrosoftNet"><A id=shellmenu_32 class=js-subm-uhf-nav-link href="https://www.microsoft.com/net/" ms.title="More_DeveloperAndIT_MicrosoftNet">Microsoft.NET</A></LI>
<LI ms.cmpnm="More_DevelopersAndIT_VisualStudio"><A id=shellmenu_33 class=js-subm-uhf-nav-link href="https://www.visualstudio.com/" ms.title="More_DevelopersAndIT_VisualStudio">Visual Studio</A></LI>
<LI ms.cmpnm="More_DeveloperAndIT_WindowsDevCenter"><A id=shellmenu_34 class=js-subm-uhf-nav-link href="https://developer.microsoft.com/en-us/windows" ms.title="More_DeveloperAndIT_WindowsDevCenter">Windows Dev Center</A></LI>
<LI ms.cmpnm="More_DeveloperAndIT_Docs.microsoft.com"><A id=shellmenu_35 class=js-subm-uhf-nav-link href="https://docs.microsoft.com/en-us/" ms.title="More_DeveloperAndIT_Docs.microsoft.com">Microsoft Docs</A></LI></UL></LI>
<LI class="f-sub-menu js-nav-menu" ms.cmpnm="Container"><BUTTON aria-expanded=false id=Other-navigation type=submit ms.title="" ms.interactiontype="14">Other</BUTTON>
<UL aria-hidden=true aria-labelledby=Other-navigation>
<LI ms.cmpnm="Other_MicrosoftStore"><A id=shellmenu_37 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/store/b/home" ms.title="Other_MicrosoftStore">Microsoft Store</A></LI>
<LI ms.cmpnm="Products_SoftwareAndServices_FreeDownloadsAndSecurity"><A id=shellmenu_38 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/download/default.aspx" ms.title="Products_SoftwareAndServices_FreeDownloadsAndSecurity">Free downloads &amp; security</A></LI>
<LI ms.cmpnm="Products_ForStudentsAndEducators_Education"><A id=shellmenu_39 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/education" ms.title="Products_ForStudentsAndEducators_Education">Education</A></LI>
<LI ms.cmpnm="More_Other_Store_Locations"><A id=shellmenu_40 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/store/locations/find-a-store?icid=TopNavStoreLocations" ms.title="More_Other_Store_Locations">Store locations</A></LI>
<LI ms.cmpnm="Store_More_GiftCards"><A id=shellmenu_41 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/store/b/gift-cards" ms.title="Store_More_GiftCards">Gift cards</A></LI>
<LI ms.cmpnm="More_Other_HolidayGiftGuide"><A id=shellmenu_42 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/store/b/holiday-gift-guide?icid=gm_fy18_hol_gg_uhf_L0_other" ms.title="More_Other_HolidayGiftGuide">Holiday gift guide</A></LI></UL></LI>
<LI class=f-multi-column-info><A class=c-glyph href="https://www.microsoft.com/en-us/sitemap.aspx" aria-label="View all" ms.title="View all">View all</A></LI></UL></DIV></LI></UL></nav><BUTTON class="c-action-trigger c-glyph glyph-chevron-right js-secondary-paddle" tabIndex=-1 type=submit aria-label="Show next" ms.title="Next"></BUTTON>
<DIV class=c-uhfh-actions ms.cmpgrp="Header actions">
<FORM aria-expanded=false id=searchForm class=c-search role=search method=get name=searchForm action=https://www.microsoft.com/en-us/search/result.aspx data-seautosuggestapi="https://www.microsoft.com/services/api/v3/suggest" data-seautosuggest='{"queryParams":{"market":"en-us","clientId":"7F27B536-CF6B-4C65-8638-A0F8CBDFCA65","sources":"Microsoft-Terms,Iris-Products,DCatAll-Products","counts":"5,1,5"},"familyNames":{"Apps":"App","Books":"Book","Bundles":"Bundle","Devices":"Device","Fees":"Fee","Games":"Game","MusicAlbums":"Album","MusicTracks":"Song","MusicVideos":"Video","MusicArtists":"Artist","OperatingSystem":"Operating System","Software":"Software","Movies":"Movie","TV":"TV","CSV":"Gift Card","VideoActor":"Actor"}}' autocomplete="off"><INPUT id=cli_shellHeaderSearchInput role=combobox aria-owns=universal-header-search-auto-suggest-ul aria-controls=universal-header-search-auto-suggest-transparent type=search name=q data-m='{"cN":"cli_shellHeaderSearchInput","pid":"q","id":"nn3m1r1a1","sN":3,"aN":"m1r1a1"}' aria-label="Search Microsoft.com" ms.title="SearchBox" placeholder="Search Microsoft.com" aria-autocomplete="list"><BUTTON id=search class=c-glyph type=submit aria-label="Search" ms.title="Search" data-bi-dnt="true"></BUTTON>
<DIV id=universal-header-search-auto-suggest-transparent class=m-auto-suggest role=group>
<UL aria-hidden=true id=universal-header-search-auto-suggest-ul class=c-menu role=listbox ms.cmpgrp="search suggestions" data-bi-dnt="true" data-tel="wedcs" data-js-auto-suggest-position="default"></UL>
<UL aria-hidden=true class="c-menu f-auto-suggest-no-results" tabIndex=0 data-js-auto-suggest-position="default" data-js-auto-suggest-postion="default">
<LI class=c-menu-item><SPAN tabIndex=-1>No results</SPAN></LI></UL></DIV></FORM>
<DIV id=meControl class=c-me ms.cmpgrp="GlobalNav_Account" data-signinsettings='{"containerId":"meControl","enabled":true,"headerHeight":48,"debug":false,"extensibleLinks":[],"userData":{"idp":"msa","firstName":"","lastName":"","memberName":"","cid":"","authenticatedState":"3"},"rpData":{"preferredIdp":"msa","msaInfo":{"signInUrl":"/en-us/store/signin","signOutUrl":"/en-us/store/signout","meUrl":"https://login.live.com/me.srf?wa=wsignin1.0"},"aadInfo":{"signOutUrl":"/en-us/store/signout","appId":null,"siteUrl":null,"blockMsaFed":true}}}'>
<DIV class=msame_Header>
<DIV class=msame_Header_name>Sign in</DIV></DIV></DIV></DIV></DIV></DIV>
<DIV class="theme-dark brand-neutral js-cat-head" ms.cmpgrp="UHF category nav" itemtype="http://schema.org/Brand" itemscope="itemscope" itemprop="brand">
<DIV><A id=uhfCatLogo class=c-logo href="https://www.microsoft.com/en-us/software-download/" aria-label="Software Download" ms.title="Software Download" itemprop="url"><SPAN>Software Download</SPAN></A><BUTTON class="c-action-trigger c-glyph glyph-chevron-left js-primary-paddle" title="Scroll left" tabIndex=-1 type=submit aria-label="Scroll left" ms.title="Previous"></BUTTON><BUTTON class="c-action-trigger c-glyph glyph-chevron-right js-secondary-paddle" title="Scroll right" tabIndex=-1 type=submit aria-label="Scroll right" ms.title="Next"></BUTTON><nav id=uhf-c-nav class=js-paddle-items role=navigation aria-labelledby=uhfCatLogo>
<DIV class="c-uhf-menu js-nav-menu"><BUTTON aria-haspopup=true aria-expanded=false id=shellmenu_43 type=submit ms.title="Office">Office</BUTTON>
<UL aria-hidden=true aria-labelledby=shellmenu_43 ms.cmpnm="Office">
<LI ms.cmpnm="Office 2010"><A id=shellmenu_44 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/office" ms.title="Office 2010">Office 2010</A></LI>
<LI ms.cmpnm="Office 2007"><A id=shellmenu_45 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/office" ms.title="Office 2007">Office 2007</A></LI>
<LI ms.cmpnm="Office for Mac 2011"><A id=shellmenu_46 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/office" ms.title="Office for Mac 2011">Office for Mac 2011</A></LI></UL></DIV>
<DIV class="c-uhf-menu js-nav-menu"><BUTTON aria-haspopup=true aria-expanded=false id=shellmenu_47 type=submit ms.title="Windows">Windows</BUTTON>
<UL aria-hidden=true aria-labelledby=shellmenu_47 ms.cmpnm="Windows">
<LI ms.cmpnm="Windows 10"><A id=shellmenu_48 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windows10" ms.title="Windows 10">Windows 10</A></LI>
<LI ms.cmpnm="Windows 8.1"><A id=shellmenu_49 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windows8" ms.title="Windows 8.1">Windows 8.1</A></LI>
<LI ms.cmpnm="Windows 7"><A id=shellmenu_50 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windows7" ms.title="Windows 7">Windows 7</A></LI>
<LI ms.cmpnm="Desktop App Converter"><A id=shellmenu_51 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/dac" ms.title="Desktop App Converter">Desktop App Converter</A></LI>
<LI ms.cmpnm="Windows 10 IoT Core"><A id=shellmenu_52 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windows10IoTCore" ms.title="Windows 10 IoT Core">Windows 10 IoT Core</A></LI>
<LI ms.cmpnm="Media Feature Pack"><A id=shellmenu_53 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/mediafeaturepack" ms.title="Media Feature Pack">Media Feature Pack</A></LI></UL></DIV>
<DIV class="c-uhf-menu js-nav-menu"><BUTTON aria-haspopup=true aria-expanded=false id=shellmenu_54 type=submit ms.title="Windows Insider Preview">Windows Insider Preview</BUTTON>
<UL aria-hidden=true aria-labelledby=shellmenu_54 ms.cmpnm="Windows Insider Preview">
<LI ms.cmpnm="Windows 10 Insider Preview"><A id=shellmenu_55 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewiso" ms.title="Windows 10 Insider Preview">Windows 10 Insider Preview</A></LI>
<LI ms.cmpnm="Windows 10 Insider Preview Advanced"><A id=shellmenu_56 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewadvanced" ms.title="Windows 10 Insider Preview Advanced">Windows 10 Insider Preview Advanced</A></LI>
<LI ms.cmpnm="Windows 10 Insider Preview Desktop App Converter"><A id=shellmenu_57 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewdac" ms.title="Windows 10 Insider Preview Desktop App Converter">Windows 10 Insider Preview Desktop App Converter</A></LI>
<LI ms.cmpnm="Windows 10 IoT Core Insider Preview"><A id=shellmenu_58 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsiot" ms.title="Windows 10 IoT Core Insider Preview">Windows 10 IoT Core Insider Preview</A></LI>
<LI ms.cmpnm="Windows Server Insider Preview"><A id=shellmenu_59 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewserver" ms.title="Windows Server Insider Preview">Windows Server Insider Preview</A></LI>
<LI ms.cmpnm="SDK Insider Preview"><A id=shellmenu_60 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewSDK" ms.title="SDK Insider Preview">SDK Insider Preview</A></LI>
<LI ms.cmpnm="ADK Insider Preview"><A id=shellmenu_61 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewADK" ms.title="ADK Insider Preview">ADK Insider Preview</A></LI>
<LI ms.cmpnm="WDK Insider Preview"><A id=shellmenu_62 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewWDK" ms.title="WDK Insider Preview">WDK Insider Preview</A></LI>
<LI ms.cmpnm="HLK Insider Preview"><A id=shellmenu_63 class=js-subm-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewHLK" ms.title="HLK Insider Preview">HLK Insider Preview</A></LI></UL></DIV><A id=shellmenu_64 class=c-uhf-nav-link href="https://www.microsoft.com/en-us/software-download/faq" ms.title="FAQ">FAQ</A></nav></DIV></DIV></header></DIV></DIV></section></SPAN>
<DIV class="CSPvNext "><SPAN class=page-data-sources></SPAN>
<DIV style="DISPLAY: none" id=signtesting></DIV>
<DIV style="DISPLAY: none" id=frameContainer></DIV>
<SCRIPT>/*<![CDATA[*/function createSilentAuthFrame(){var n=document.createElement("iframe");n.src="https://"+window.location.hostname+"/en-us/silentauth";n.style="display: none";window.mscc?mscc.hasConsent()&&document.getElementById("frameContainer").appendChild(n):document.getElementById("frameContainer").appendChild(n)}window.addEventListener?window.addEventListener("load",createSilentAuthFrame,!1):window.attachEvent?window.attachEvent("onload",createSilentAuthFrame):window.onload=createSilentAuthFrame/*]]>*/</SCRIPT>
<SCRIPT>/*<![CDATA[*/function MscomLoadOptions(){var i="",t=document.createElement("meta"),n,r;t.name="ms.auth";t.content=isUserSignedIn;document.head&&document.head.appendChild(t);n={meControlOptions:{rpData:{msaInfo:{signInUrl:mscomSignInUrl,signOutUrl:mscomSignOutUrl},aadInfo:{signInUrl:mscomSignInUrl,signOutUrl:mscomSignOutUrl}},userData:{idp:authenticationType==="RPS"?window.msCommonShell.SupportedAuthIdp.MSA:window.msCommonShell.SupportedAuthIdp.AAD,firstName:typeof aFirstName=="undefined"?"":aFirstName,lastName:typeof aLastName=="undefined"?"":aLastName,memberName:typeof aMemberName=="undefined"?"":aMemberName,cid:typeof aCid=="undefined"?"":aCid,authenticatedState:typeof aAuthenticatedState=="undefined"?window.msCommonShell.AuthState.NotSignedIn:aAuthenticatedState}},events:{onSearch:function(n){if(n){var t=n.q.value;typeof ms!="undefined";t&&typeof ms!="undefined"&&(ms["ms.pgarea"]="header",ms["ms.cmpgrp"]="search",ms["ms.cmpnm"]="search",ms["ms.InteractionType"]="2",ms["ms.searchquery"]=t,ms["ms.Title"]="search",wcs["wcs.cot"]="4",MscomBeacon())}},onEventLog:function(n){if(typeof ms!="undefined"){ms["ms.pgarea"]="header";ms["ms.cmpgrp"]="nav";ms["ms.cmpnm"]="mecontrol";wcs["wcs.cot"]="1";switch(n){case"MeControl_SignIn":if(ms["ms.Title"]="sign-in",ms["ms.InteractionType"]="14",MscomBeacon(),i!==""){var t="//microsoftwindows.112.2o7.net/b/ss/msstores1-cmstest-prod/1/H.24.4/",e=((1+Math.random())*65536|0).toString(16).substring(1),u=encodeURIComponent(window.location.pathname.toLowerCase()),o=e+"?ns=microsoftwindows%26pageName=sitemuse%26v1=sitemuse%26events=event2%26c2=ToReplacepth1%26v2=ToReplacepth2%26pe=lnk_o%26pev2=click_sitemuse%26c3=signInClick%26v3=signInClick%26c4=no%26v4=no",s=new Image(0,0);t=t+decodeURIComponent(o);t=t.replace("ToReplacepth1",u);t=t.replace("ToReplacepth2",u);s.src=t}break;case"MeControl_RemoveUser":ms["ms.Title"]="remove account";ms["ms.InteractionType"]="1";MscomBeacon();break;case"MeControl_SwitchUser":ms["ms.Title"]="change account";ms["ms.InteractionType"]="1";MscomBeacon();break;case"MeControl_SignOutAll":if(ms["ms.Title"]="Sign-out",MscomBeacon(),i!==""){var r="//microsoftwindows.112.2o7.net/b/ss/msstores1-cmstest-prod/1/H.24.4/",h=((1+Math.random())*65536|0).toString(16).substring(1),f=encodeURIComponent(window.location.pathname.toLowerCase()),c=h+"?ns=microsoftwindows%26pageName=sitemuse%26v1=sitemuse%26events=event2%26c2=ToReplacepth1%26v2=ToReplacepth2%26pe=lnk_o%26pev2=click_sitemuse%26c3=signOutClick%26v3=signOutClick%26c4=no%26v4=no",l=new Image(0,0);r=r+decodeURIComponent(c);r=r.replace("ToReplacepth1",f);r=r.replace("ToReplacepth2",f);l.src=t}break;case"MeControl_ViewAccount":ms["ms.Title"]="View Account";MscomBeacon();break;case"MeControl_DropdownOpen":ms["ms.Title"]="Profile DropdownOpen";ms["ms.InteractionType"]="1";wcs["wcs.cot"]="5";MscomBeacon();break;case"MeControl_DropdownReady":console.log($(".msame_Header_chev").text());$(".msame_Header_chev").length&&($(".msame_Header_chev").text()?$(".msame_Header_chev").html($(".msame_Header_chev").text()).show():$(".msame_Header_chev").hide())}}}}};autoSuggestOptions!==null&&(r=initSearchSuggest(autoSuggestOptions.requestEndpoint,autoSuggestOptions.locale),n=$.extend(!0,{},n,r));window.msCommonShell.load(n)}var isUserSignedIn="0",href=encodeURIComponent(location.href),authenticationType="",mscomSignInUrl="/en-us/signin.aspx",mscomSignOutUrl="/en-us/signout.aspx",autoSuggestOptions=null;window.msCommonShell?MscomLoadOptions():window.onShellReadyToLoad=function(){window.onShellReadyToLoad=null;MscomLoadOptions()}/*]]>*/</SCRIPT>
</DIV><LINK rel=stylesheet type=text/css href="https://c.s-microsoft.com/en-us/CMSStyles/epb.css?version=43583927-EB99-F50D-EDC6-010FA1F6B5C6">
<SCRIPT>/*<![CDATA[*/function DecodeHTML(){$(".msame_Header_chev").length&&($(".msame_Header_chev").text()?$(".msame_Header_chev").html($(".msame_Header_chev").text()).show():$(".msame_Header_chev").hide())}function checkDecode(){DecodeHTML();$(".msame_Header_chev").unbind("DOMSubtreeModified",checkDecode);$(".msame_Header_chev").unbind("DOMNodeInserted",checkDecode)}$(document).ready(function(){var i=document.getElementById("cli_shellHeaderSearchInput"),t=$(i).attr("placeholder").match(/&#(\d+);/g),r=t&&t.length,n;if(r)for(n=0;n<r;n++)i.placeholder=i.placeholder.replace(t[n],String.fromCharCode(t[n].match(/\d+/)))});$(document).ready(DecodeHTML);$(window).load(DecodeHTML);$(window).resize(function(){$(".msame_Header_chev").bind("DOMSubtreeModified",checkDecode);$(".msame_Header_chev").bind("DOMNodeInserted",checkDecode)});var _elementFound=!1;$(document).bind("DOMSubtreeModified",function(){_elementFound||$(".msame_chev_uhf").length>0&&(DecodeHTML(),_elementFound=!0)})/*]]>*/</SCRIPT>
</DIV></DIV><main id=mainContent role=main>
<DIV class=row-fluid>
<DIV class="software-download span">
<DIV class="CSPvNext CMSvNextComp template-blue">
<DIV class="row-padded-bottom row-fluid" data-view4="1" data-view3="1" data-view2="1" data-view1="1" data-cols="1">
<DIV class="row-fluid title" data-view4="1" data-view3="1" data-view2="1" data-view1="1" data-cols="1">
<H1 class="mscom-container-maxwidth mscom-grid-container">Download Windows 10 Disc Image (ISO File)</H1></DIV></DIV></DIV></DIV></DIV>
<DIV class="mscom-container-maxwidth mscom-grid-container row-fluid" data-view4="3" data-view3="3" data-view2="3" data-view1="1" data-cols="3">
<DIV class="span bp0-col-1-2 bp1-col-3-2 bp2-col-3-2 bp3-col-3-2">
<DIV id=SoftwareDownload_Introduction>
<P>You’ve been routed to this page because the operating system you’re using won’t support the Windows 10 media creation tool and we want to make sure you can download Windows 10. To use the media creation tool, visit the <A href="https://www.microsoft.com/software-download/windows10" target=_blank>Microsoft Software Download Windows 10 page</A> from a Windows 7, Windows 8.1 or Windows 10 device.</P>
<P>You can use this page to download a disc image (ISO file) that can be used to install or reinstall Windows 10. The image can also be used to create installation media using a USB flash drive or DVD.</P></DIV></DIV></DIV></DIV></DIV></DIV>
<DIV class="row-fluid row-padded-bottom" data-view4="1" data-view3="1" data-view2="1" data-view1="1" data-cols="1">
<DIV id=div244502a8-e198-486b-a0d1-8b20fcd840a0 class="CMSvNextComp mscom-accordion" xmlns:bi="urn:schemas-microsoft-com:mscom:bi" bi:type="accordion">
<UL id=244502a8-e198-486b-a0d1-8b20fcd840a0 class=faq-accordion role=tablist bi:type="list">
<LI id=7d5c905c-2314-414e-8702-8441e26eb0ae class=" mscom-accordion-item" role=tab><A aria-expanded=false class="mscom-link mscom-accordion-item-link" aria-selected=false href="/en-us/software-download/windows10ISO?7d5c905c-2314-414e-8702-8441e26eb0ae=True" bi:track="false"><SPAN class=mscom-accordion-item-image></SPAN><SPAN class=mscom-accordion-item-title>Before you begin</SPAN></A>
<DIV class=mscom-accordion-item-container>
<P>Make sure you have:</P>
<UL>
<LI>An internet connection (internet service provider fees may apply).</LI>
<LI>Sufficient data storage available on a computer, USB or external drive for the download.</LI>
<LI>A <STRONG>blank</STRONG> USB flash drive with at least 5 GB of space or blank DVD (and DVD burner) if you want to create media. We recommend using a blank USB or blank DVD, because any content on it will be deleted.</LI>
<LI>When burning a DVD from an ISO file, if you are told the disc image file is too large you will need to use Dual Layer (DL) DVD Media.</LI></UL>
<P>Check these things on the PC where you want to install Windows 10:</P>
<UL>
<LI><STRONG>64-bit or 32-bit processor (CPU).</STRONG> You’ll create either the 64-bit or 32-bit version of Windows 10 that’s appropriate for your CPU. To check this on your PC, go to <STRONG>PC info</STRONG> in PC settings or <STRONG>System</STRONG> in Control Panel, and look for <STRONG>System type</STRONG>.</LI>
<LI><STRONG>System requirements.</STRONG> See the <A href="https://www.microsoft.com/en-us/windows/windows-10-specifications" target=_blank>system requirements</A> before installing Windows 10. We also recommend that you visit your PC manufacturer's website for info about updated drivers and hardware compatibility.</LI>
<LI><STRONG>Language in Windows.</STRONG> You'll need to choose the same language when you install Windows 10. To see what language you're currently using, go to <STRONG>Time and language</STRONG> in PC settings or <STRONG>Region</STRONG> in Control Panel.</LI>
<LI><STRONG>Edition of Windows.</STRONG> You should also choose the same edition of Windows. To check what edition you're currently running, go to <STRONG>PC info</STRONG> in PC settings or <STRONG>System</STRONG> in Control Panel, and look for <STRONG>Windows edition</STRONG>. Windows 10 Enterprise isn’t available here. Please see the <A href="https://www.microsoft.com/licensing/servicecenter/default.aspx" target=_blank>Volume Licensing Service Center</A> for more information.</LI>
<LI><STRONG>Microsoft Office products.</STRONG> If you just purchased a new device that includes Office 365, we recommend redeeming (installing) Office before upgrading to Windows 10. To redeem your copy of Office, please see <A href="https://support.office.com/article/Download-and-install-Office-365-Home-Personal-or-University-on-your-PC-7a28382b-7015-4b5a-9d9b-650d15742c95" target=_blank>Download and install Office 365 Home, Personal, or University on your PC</A>. For more information, check <A href="https://support.office.com/article/How-to-upgrade-to-Windows-10-on-new-devices-that-include-Office-365-6176455a-d152-4c3b-a2fa-723d1f6980f0" target=_blank>How to upgrade to Windows 10 on new devices that include Office 365</A>.
<P>If you have Office 2010 or earlier and choose to perform a clean install of Windows 10, you will need to locate your Office product key. For tips on locating your product key, check <A href="https://products.office.com/2010-microsoft-office-suites-license-designations" target=_blank>Find your Office 2010 product key</A> or <A href="https://support.office.com/article/Enter-the-product-key-for-your-Office-2007-program-fabe03d9-fbc3-452e-8fd4-d1c2e661d518" target=_blank>Enter the product key for your Office 2007 program.</A></P></LI></UL></DIV></DIV></DIV></LI></UL></DIV>
<SCRIPT type=text/javascript>/*<![CDATA[*/typeof $!="undefined"&&$(function(){if(Mscom&&Mscom.Accordion)var n=new Mscom.Accordion("div244502a8-e198-486b-a0d1-8b20fcd840a0")})/*]]>*/</SCRIPT>
<DIV id=SoftwareDownload_EditionSelection>
<H2>Select edition</H2>
<P>Windows 10 editions below are valid for both Windows 10 Home and Windows 10 Pro.</P></DIV></DIV>
<DIV class="input-group row-fluid" data-view4="1" data-view3="1" data-view2="1" data-view1="1" data-cols="1">
<DIV style="PADDING-BOTTOM: 0px" id=productEdition-validation class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1">
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><SPAN id=product-edition-error class=input-error-message role=alert>Select an edition from the drop down menu.</SPAN></DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><SELECT id=product-edition href="#product-info-content"><OPTION selected value="">Select edition</OPTION><OPTGROUP label="Windows 10 Fall Creators Update"><OPTION value=484>Windows 10</OPTION></OPTGROUP></SELECT></DIV></DIV></DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><BUTTON id=submit-product-edition class="button-flat button-main" type=submit>Confirm</BUTTON>
<DIV class="footnote row-padded-top"><A href="https://go.microsoft.com/fwlink/?LinkID=521839" target=_blank>Privacy</A></DIV></DIV></DIV>
<DIV id=divf479448e-0a87-400a-a1c7-2d5a79f00035 class="CMSvNextComp mscom-accordion" xmlns:bi="urn:schemas-microsoft-com:mscom:bi" bi:type="accordion">
<UL id=f479448e-0a87-400a-a1c7-2d5a79f00035 class=faq-accordion role=tablist bi:type="list">
<LI id=4cd9df4f-deef-4431-9497-a04303f34986 class=" mscom-accordion-item" role=tab><A aria-expanded=false class="mscom-link mscom-accordion-item-link" aria-selected=false href="/en-us/software-download/windows10ISO?4cd9df4f-deef-4431-9497-a04303f34986=True" bi:track="false"><SPAN class=mscom-accordion-item-image></SPAN><SPAN class=mscom-accordion-item-title>More download options</SPAN></A>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1">Sign in to the <A href="https://www.microsoft.com/licensing/servicecenter/default.aspx" target=_blank>Volume Licensing Service Center</A> to download Enterprise editions. </DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1">Sign in to your subscription on the <A href="https://msdn.microsoft.com" target=_blank>MSDN Portal</A> for MSDN downloads. </DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1">Visit the <A href="https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewiso" target=_blank>Windows Insider site</A> to download Insider Preview builds </DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1">Visit the <A href="https://www.microsoft.com/en-us/software-download/vlacademicwindows10" target=_blank>Download Academic Products page</A> for Education editions (product key required). </DIV></DIV></DIV></LI></UL></DIV>
<SCRIPT type=text/javascript>/*<![CDATA[*/typeof $!="undefined"&&$(function(){if(Mscom&&Mscom.Accordion)var n=new Mscom.Accordion("divf479448e-0a87-400a-a1c7-2d5a79f00035")})/*]]>*/</SCRIPT>
</DIV></DIV></DIV></DIV></DIV></DIV></DIV></DIV></DIV></DIV>
<DIV id=SoftwareDownload_LanguageSelectionByProductEdition class=mscom-ajax-contentinclude data-AjaxQuery="" data-host-querystring="" data-host-segments="software-download%2cwindows10ISO" data-Host="www.microsoft.com" data-ControlAttributesMapping="" data-ProgrammableContentArea="" data-urlLocale="en-us" data-defaultPageId="a8f8f489-4c7f-463a-9ca6-5cff94d8d041"></DIV></DIV></DIV>
<DIV id=SoftwareDownload_DownloadLinks class=mscom-ajax-contentinclude data-AjaxQuery="" data-host-querystring="" data-host-segments="software-download%2cwindows10ISO" data-Host="www.microsoft.com" data-ControlAttributesMapping="" data-ProgrammableContentArea="" data-urlLocale="en-us" data-defaultPageId="cfa9e580-a81e-4a4b-a846-7b21bf4e2e5b"></DIV></DIV></DIV>
<DIV id=SoftwareDownload_Feedback>
<FORM role=form>
<DIV id=div668657eb-b1ac-4c09-9105-1529f3534c81 class="CMSvNextComp mscom-accordion" xmlns:bi="urn:schemas-microsoft-com:mscom:bi" bi:type="accordion">
<UL id=668657eb-b1ac-4c09-9105-1529f3534c81 class=feedback-accordion role=tablist bi:type="list">
<LI id=774b232c-a48d-452a-a8fb-3906dc168d5c class="input-group mscom-accordion-item" role=tab><A aria-expanded=false class="mscom-link mscom-accordion-item-link" aria-selected=false href="/en-us/software-download/windows10ISO?774b232c-a48d-452a-a8fb-3906dc168d5c=True" bi:track="false"><SPAN class=mscom-accordion-item-image></SPAN><SPAN class=mscom-accordion-item-title>Give feedback</SPAN></A>
<FIELDSET id=feedback-question1>
<DIV id=feedback-question1-error class=input-error-message>Please select an option.</DIV><LEGEND>Was this information helpful?</LEGEND>
<UL>
<LI><LABEL><INPUT value=Yes type=radio name=feedback-question1-radio>Yes</LABEL></LI>
<LI><LABEL><INPUT value=No type=radio name=feedback-question1-radio>No</LABEL></LI>
<LI><LABEL><INPUT value=Somewhat type=radio name=feedback-question1-radio>Somewhat</LABEL></LI></UL></FIELDSET></DIV></DIV>
<DIV class="row-padded row-fluid" data-view4="1" data-view3="1" data-view2="1" data-view1="1" data-cols="1">
<FIELDSET id=feedback-question2>
<DIV id=feedback-question2-error class=input-error-message>Please select an option.</DIV><LEGEND>How much effort did you personally put forth to use this site?</LEGEND>
<UL>
<LI><LABEL><INPUT value="Very low" type=radio name=feedback-question2-radio>Very low</LABEL></LI>
<LI><LABEL><INPUT value=Low type=radio name=feedback-question2-radio>Low</LABEL></LI>
<LI><LABEL><INPUT value=Moderate type=radio name=feedback-question2-radio>Moderate</LABEL></LI>
<LI><LABEL><INPUT value=High type=radio name=feedback-question2-radio>High</LABEL></LI>
<LI><LABEL><INPUT value="Very High" type=radio name=feedback-question2-radio>Very High</LABEL></LI></UL></FIELDSET></DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><LABEL>Tell us what we can do to improve this site <TEXTAREA id=feedback-extra-comments></TEXTAREA></LABEL></DIV></DIV>
<DIV id=feedback-action class="row-padded row-fluid" data-view4="1" data-view3="1" data-view2="1" data-view1="1" data-cols="1">
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><SPAN class=input-success-message>Thank you for your valuable input.</SPAN></DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><BUTTON id=feedback-send-button class="button-flat button-purple" type=submit>Send</BUTTON></DIV></DIV></DIV></DIV></DIV></LI></UL></DIV>
<SCRIPT type=text/javascript>/*<![CDATA[*/typeof $!="undefined"&&$(function(){if(Mscom&&Mscom.Accordion)var n=new Mscom.Accordion("div668657eb-b1ac-4c09-9105-1529f3534c81")})/*]]>*/</SCRIPT>
</DIV></DIV>
<DIV id=SoftwareDownload_FeedbackSubmit class=mscom-ajax-contentinclude data-AjaxQuery="" data-host-querystring="" data-host-segments="software-download%2cwindows10ISO" data-Host="www.microsoft.com" data-ControlAttributesMapping="" data-ProgrammableContentArea="" data-urlLocale="en-us" data-defaultPageId="b3e39122-58b8-4e0e-9e2d-91167c6393aa"></DIV></DIV></DIV></DIV></FORM></DIV></DIV></DIV>
<P><SPAN class=footnote>*Your use of the media creation tools on this site is governed by the <A href="https://www.microsoft.com/en-us/legal/intellectualproperty/copyright/default.aspx" target=_blank>Microsoft Terms of Use</A> for this website.</SPAN></P></DIV></DIV></DIV></DIV></DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-3-1 bp2-col-3-1 bp3-col-3-1">
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><IMG class=mscom-image alt=Windows10 src="https://c.s-microsoft.com/en-us/CMSImages/windows10-laptop.png?version=2eb124e2-b087-ba9a-1b12-bc7fdfa4e15d" width=484 height=297></DIV></DIV></DIV></DIV>
<DIV id=progress-modal class=modal role=dialog aria-describedby=progressModalMessage>
<DIV class=modal-dialog role=document>
<DIV class="modal-wrapper modal-wrapper-progress">
<DIV class=modal-content>
<P id=progressModalMessage>Validating your request. This may take several minutes. Do not refresh the page or select back, doing so will cancel the request.</P><IMG class=mscom-image alt=Loading src="https://c.s-microsoft.com/en-us/CMSImages/Loading.gif?version=d26cd9f0-5c36-d2db-fb28-6b8f087e4e8b" width=66 height=66></DIV></DIV></DIV></DIV></DIV></DIV></DIV></DIV></DIV></DIV></main>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"></DIV></DIV>
<DIV class="span bp0-col-1-1 bp1-col-1-1 bp2-col-1-1 bp3-col-1-1"><SPAN><section id=footerArea data-m='{"cN":"footerArea","cT":"Area_coreuiArea","id":"a2Body","sN":2,"aN":"Body"}'>
<DIV id=footerRegion data-m='{"cN":"footerRegion","cT":"Region_coreui-region","id":"r1a2","sN":1,"aN":"a2"}' data-region-key="footerregion">
<DIV id=footerUniversalFooter data-m='{"cN":"footerUniversalFooter","cT":"Module_coreui-universalfooter","id":"m1r1a2","sN":1,"aN":"r1a2"}' data-module-id="Category|footerRegion|footerRegion|footerUniversalFooter|coreui-universalfooter"><footer id=uhf-footer class="c-uhff context-uhf" ms.pgarea="Uhf footer" data-footer-footprint="en-us/mssoftware-download/mssoftware-downloadFooter" data-uhf-mscc-rq="false"><nav class=c-uhff-nav role=navigation ms.cmpgrp="Footer nav" aria-label="Footer">
<DIV class=c-uhff-nav-row>
<DIV class=c-uhff-nav-group ms.cmpnm="What" _new27_="" s="">
<H6 class=c-heading-4>What's new</H6>
<UL class="c-list f-bare">
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/surface/devices/surface-book-2/overview" ms.title="Footer_WhatsNew_SurfaceBook2">Surface Book 2</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/surface/devices/surface-pro/overview" ms.title="Footer_WhatsNew_NewSurfacePro">New Surface Pro</A></LI>
<LI><A class=c-uhff-link href="https://www.xbox.com/en-us/xbox-one-x" ms.title="Footer_WhatsNew_XboxOneX">Xbox One X</A></LI>
<LI><A class=c-uhff-link href="https://www.xbox.com/en-us/xbox-one-s?xr=shellnav" ms.title="Footer_WhatsNew_XboxOneS">Xbox One S</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/store/b/virtualreality" ms.title="Footer_WhatsNew_VRandMixedReality">VR &amp; mixed reality</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/windows/windows-10-apps" ms.title="Footer_WhatsNew_Windows_10_apps">Windows 10 apps</A></LI>
<LI><A class=c-uhff-link href="https://store.office.com/en-us/appshome.aspx?" ms.title="Footer_WhatsNew_OfficeApps">Office apps</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/store/b/holiday-gift-guide?icid=gm_fy18_hol_gg_uhf_L0_other" ms.title="More_Other_HolidayGiftGuide">Holiday gift guide</A></LI></UL></DIV>
<DIV class=c-uhff-nav-group ms.cmpnm="Store &amp; Support">
<H6 class=c-heading-4>Store &amp; Support</H6>
<LI><A class=c-uhff-link href="https://account.microsoft.com/" ms.title="Footer_StoreandSupport_AccountProfile">Account profile</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/download" ms.title="Footer_StoreandSupport_DownloadCenter">Download Center</A></LI>
<LI><A class=c-uhff-link href="https://go.microsoft.com/fwlink/p/?LinkID=824761&amp;clcid=0x409" ms.title="Footer_StoreandSupport_SalesAndSupport">Sales &amp; support</A></LI>
<LI><A class=c-uhff-link href="https://go.microsoft.com/fwlink/p/?LinkID=824764&amp;clcid=0x409" ms.title="MicrosoftStore_Returns">Returns</A></LI>
<LI><A class=c-uhff-link href="https://account.microsoft.com/orders" ms.title="Footer_StoreandSupport_OrderTracking">Order tracking</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/store/locations/find-a-store" ms.title="Footer_StoreandSupport_StoreLocations">Store locations</A></LI>
<LI><A class=c-uhff-link href="https://support.microsoft.com/en-us" ms.title="Footer_StoreandSupport_Support">Support</A></LI></UL></DIV>
<DIV class=c-uhff-nav-group ms.cmpnm="Education">
<H6 class=c-heading-4>Education</H6>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/education" ms.title="Footer_Education_MicrosoftInEducation">Microsoft in education</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/education/products/office/default.aspx" ms.title="Footer_Education_OfficeForStudents">Office for students</A></LI>
<LI><A class=c-uhff-link href="https://products.office.com/en-us/academic/compare-office-365-education-plans" ms.title="Footer_Education_Office365ForSchools">Office 365 for schools</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/store/b/student" ms.title="Footer_Education_DealsForStudentsandEducators">Deals for students &amp; educators </A></LI>
<LI><A class=c-uhff-link href="https://azure.microsoft.com/en-us/community/education/" ms.title="Footer_MicrosoftAzureInEducation">Microsoft Azure in education</A></LI></UL></DIV></DIV>
<DIV class=c-uhff-nav-group ms.cmpnm="Enterprise">
<H6 class=c-heading-4>Enterprise</H6>
<LI><A class=c-uhff-link href="https://azure.microsoft.com/" ms.title="Footer_Enterprise_MicrosoftAzure ">Microsoft Azure </A></LI>
<LI><A class=c-uhff-link href="https://enterprise.microsoft.com/en-us/" ms.title="Footer_Enterprise_Enterprise">Enterprise</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/sql-server/" ms.title="Footer_Enterprise_DataPlatform">Data platform</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/solution-providers" ms.title="Footer_Enterprise_FindASolutionsProvider">Find a solutions provider</A></LI>
<LI><A class=c-uhff-link href="https://partner.microsoft.com/en-us/" ms.title="Footer_Enterprise_MicrosoftPartnerResources">Microsoft partner resources </A></LI>
<LI><A class=c-uhff-link href="https://go.microsoft.com/fwlink/?LinkID=808093" ms.title="Footer_Enterprise_MicrosoftAppSource ">Microsoft AppSource </A></LI>
<LI><A class=c-uhff-link href="https://enterprise.microsoft.com/en-us/industries/discrete-manufacturing/" ms.title="Footer_Enterprise_ManufacturingAndResources">Manufacturing &amp; resources</A></LI>
<LI><A class=c-uhff-link href="https://enterprise.microsoft.com/en-us" ms.title="Footer_Enterprise_FinanciaServices">Financial services</A></LI></UL></DIV>
<DIV class=c-uhff-nav-group ms.cmpnm="Developer">
<H6 class=c-heading-4>Developer</H6>
<LI><A class=c-uhff-link href="https://www.visualstudio.com/" ms.title="Footer_Developer_MicrosoftVisualStudio">Microsoft Visual Studio</A></LI>
<LI><A class=c-uhff-link href="https://developer.microsoft.com/en-us/windows" ms.title="Footer_Developer_WindowsDevCenter">Windows Dev Center</A></LI>
<LI><A class=c-uhff-link href="https://msdn.microsoft.com/en-us" ms.title="Footer_Developer_MicrosoftDeveloperNetwork">Developer Network</A></LI>
<LI><A class=c-uhff-link href="https://technet.microsoft.com/en-us" ms.title="Footer_Developer_TechNet">TechNet</A></LI>
<LI><A class=c-uhff-link href="https://mva.microsoft.com/" ms.title="Footer_Developer_MicrosoftVirtualAcademy">Microsoft Virtual Academy</A></LI>
<LI><A class=c-uhff-link href="https://developer.microsoft.com/en-us/store/register" ms.title="Footer_Developer_MicrosoftDeveloperProgram">Microsoft developer program</A></LI>
<LI><A class=c-uhff-link href="https://channel9.msdn.com/" ms.title="Footer_Developer_Channel9">Channel 9</A></LI>
<LI><A class=c-uhff-link href="https://dev.office.com/" ms.title="Footer_Developer_OfficeDevCenter">Office Dev Center</A></LI></UL></DIV>
<DIV class=c-uhff-nav-group ms.cmpnm="Company">
<H6 class=c-heading-4>Company</H6>
<LI><A class=c-uhff-link href="https://careers.microsoft.com/" ms.title="Footer_Company_Careers">Careers</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/about" ms.title="Footer_Company_AboutMicrosoft">About Microsoft</A></LI>
<LI><A class=c-uhff-link href="https://news.microsoft.com/" ms.title="Footer_Company_CompanyNews">Company news</A></LI>
<LI><A class=c-uhff-link href="https://privacy.microsoft.com/en-us" ms.title="Footer_Company_PrivacyAtMicrosoft">Privacy at Microsoft</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/investor/default.aspx" ms.title="Footer_Company_Investors">Investors</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/diversity/" ms.title="Footer_Company_DiversityAndInclusion">Diversity and inclusion</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/accessibility/home" ms.title="Footer_Company_Accessibility">Accessibility</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/en-us/security/default.aspx" ms.title="Footer_Company_Security">Security</A></LI></UL></DIV></DIV></nav>
<DIV class=c-uhff-base><A id=locale-picker-link class="c-uhff-link c-uhff-lang-selector c-glyph glyph-world" href="https://www.microsoft.com/en-us/software-download/locale" ms.title="locale_picker(US)">English (United States)</A>
<UL class="c-list f-bare" role=contentinfo ms.cmpgrp="Corp links">
<LI><A class=c-uhff-link href="http://go.microsoft.com/?linkid=2028325" ms.title="Footer_ContactUs" data-mscc-ic="false">Contact us</A></LI>
<LI><A class=c-uhff-link href="http://go.microsoft.com/fwlink/?LinkId=248681" ms.title="Footer_PrivacyandCookies" data-mscc-ic="false">Privacy and cookies </A></LI>
<LI><A class=c-uhff-link href="http://go.microsoft.com/fwlink/?LinkID=530144" ms.title="Footer_TermsOfUse" data-mscc-ic="false">Terms of use</A></LI>
<LI><A class=c-uhff-link href="https://www.microsoft.com/trademarks" ms.title="Footer_Trademarks" data-mscc-ic="false">Trademarks</A></LI>
<LI><A class=c-uhff-link href="https://choice.microsoft.com/" ms.title="Footer_AboutourAds" data-mscc-ic="false">About our ads</A></LI>
<LI>© Microsoft 2017</LI></UL></DIV></footer></DIV></DIV></section></SPAN></DIV></DIV>
<SCRIPT type=text/javascript>/*<![CDATA[*/var varAutoFirePV=1,varClickTracking=1,varCustomerTracking=1,Route="45215",Ctrl="";document.write("<script type='text/javascript' src='"+window.location.protocol+"//c.microsoft.com/ms.js''><\/script>")/*]]>*/</SCRIPT>
<SCRIPT type=text/javascript src="https://c.microsoft.com/ms.js" ?></SCRIPT>
<IFRAME style="Z-INDEX: -1; WIDTH: 1px; DISPLAY: none; HEIGHT: 1px; VISIBILITY: hidden" id=_msnFrame src="https://c1.microsoft.com/c.gif?DI=4050&amp;did=1&amp;t="></IFRAME></DIV></DIV></BODY>
Thanks, very helpful!
Something is messing your HTML within your browser.
The original select field is supposed to look like this:
<select id="product-edition" href="#product-info-content"><option value="" selected="selected">Select edition</option><optgroup label="Windows 10 Fall Creators Update"><option value="484">Windows 10</option></optgroup></select>
However, your HTML code looks like this:
Quotation marks are invalid, and capitalization is invalid. Do you have any rogue browser plugin installed that could have caused this?
Anyway, I'll add a case for this kind of messy HTML to the downloader. I can't guarantee that the scripts are gonna work on invalid HTML. We'll see whether it work or not when I push out the new version, probably after the weekend.
i had the same problem but i solved this by going to control panel / region/ then  change format and locations to USA.
my set up before was  Saudi Arabia .
now i am using windows 8.1 enterprise evaluations .
in windows 7 go to control panel / language and region / then  change format and locations to USA.
note : i set up back to Saudi Arabia but the problem back again and then set up to USA and  the download appears to be downloaded ok i downloaded some of windows and office and that was perfect .
Hi
When I click on a windows for download it flashes and makes a clicking noise. It keeps repeating this and I have to exit the program. Hope this helps.
Also I tried Eid's method with the last two versions, but it made no difference.
Edited by lernien
Could you send a screenshot with the list of all Add-Ons that you run on IE? Something like the following screen(s)?
I suspect that one of them is the culprit.
You could also try disabling all Add-Ons. If that works, we'd know for sure that one of them causes the issue, and then it's only a matter of time to find the rogue.
I have enabled/disabled this one and no difference. I use Firefox as my main browser. I only have 3 in my firefox browser, I disabled them all and it made no difference. I don't have many as this is a fresh install of windows 7.
Edited by lernien
