[SOLVED] 1.6.0.8 and Test 1.6.0.9
Hi Liam,
both versions shows this warning on loading preset and the number of selected tweaks is wrong.
In 1.6.0.7 and before is OK
Same preset in both cases.
Regards
Edited by Thiersee
17 hours ago, Legolash2o said:
Thanks for the report. It's not a big fix so I can do it tomorrow :)
Hi Lego,
Another small cosmetic error to be fixed:
When launching an oder Version of WTK a newer version 1.6.0.8 ist offered, although v1.6.0.9 is (still) actual.
Thanks for your work.
Regards, Nemo
Edited by Nemo_G
4 hours ago, serg130270 said:
When using Tweaks All-In-One Integrator, the second stage stops the installation of Windows 10 Enterprise 2016 LTSB 14393 Version 1607
You'd have to start a new thread and also attach your preset.
3 hours ago, sweden8 said:
I have tried v10 and it works very well, just like v7. Both on win 7 x64.
Glad it's working!
