[AddOn] TrueTransparency v0.7 (Updated 10/10/07)
download.png Updated October 10-2007
MD5: A9D3FD6172F06CCA695FB0A558CDC524
Website: <a href="http://www.crystalxp.net/galerie/en.id.513...lorer-tools.htm" target="_blank">http://www.crystalxp.net/galerie/en.id.513...lorer-tools.htm</a>
Changelog:
October 10-2007
- Added TrueAero skin and set it as default
- Removed Startup folder link (uses the registry same as the program)
idk if its just me but this program works perfect, however when i load the skin trueaero, which rele looks the closest to the vista aero look it kinda only works when it feels liek it, normaly the prorgam wont load on startup when this skin is applied, sometiems the program dosent work at all when trueaero is applied.......whats going on with this? why wont it work?
ooh sory rick forgot 2 tel ya trueaero isnt added in with the installer you can get it here.........TrueAero
i have got it to load successfully, however it will only work now if i turn on my comp, log out then log back in, i know it sounds crazy but ya
tell me if you can ifgure anything out with this rick
BUG!
I tried this at Vista, and i can't open any menu's, like "FILE" "EDIT" "VIEW" "HISTORY", It just flashes, and disappears... :(
And this happens only with FF..
Edited by Mr.Thunderbird
UPDATED
I think that by removing the Startup shortcut and using the registy it will solve the problem blind031
thanks rick will give it a try and report back
edit: ehh works perfect on x86, but still havin the same problems on x64, was this not written for x64 or somthin? i meen i copied the utility's folder from program files in x86 xp and put em in the program files folder in x64, any suggestions? or a possibility of writing a .inf for x64?
thanks again
Edited by blind031
well, wut id kinda liek 2 kno, is truetransparency really made to work on x64?
if not woudl you kno how 2 write a msi?, exe, or archive or some sort?
alrite thanks Kelsenellenelvian ill take a look at that when i get home, thanks again
edit: nop still nothin on windows xp x64, i do kno tho that its not the program, because if i load other skins up they work liek a charm, when it comes to this 1 though, i only get problems
any suggestions?
Edited by blind031
