Adobe Flash Player v11.1.102.55 True AddOn INTL
Ragazzi ecco come true addon anche il Adobe Flash Player, ecco il link
OnePiece Adobe Flash Player v11.1.102.55 for WinXPSP3 True AddOn
tabdownload.png Aggiornato (Dicembre 01 2011)
Hash MD5 1BC2C3CFB4C3A79E59C1FBAEE9C28D8C
Filesize: 3.22 MB (3385849 bytes)
Edited by OnePiece
ı want to use this addon but ı dont know what its version is...
if its version is 9.0.124.0, ı will use it...
so can you tell me what the version is?
Hi ALtF4, just and of the last version, that 9.0.124.0, always watch the entries.ini in case that to the doubts,
[general]
builddate=2008/05/13
description=OnepPiece Adobe
[general]
looking for latest adobe flash player with active x control without google silent install addon for nlite
is this addon a match? lol! i'm just learning, been reading & downloading, will not quit till i can contribute!thanks to all
  • 3 months later...
  • 4 weeks later...
well Link is down.........
  • 5 weeks later...
Hi OnePiece.I like your addons.
I integrated this flash addon to my Turkish XP CD.But it looks it isn't supports firefox, I installed Firefox (3.0.4) after this addon and Firefox can't play flash animations :(
Is it supports firefox? If supports why Firefox can't play movies? I don't find about firefox in this thread.
(I'm sorry for my bad english.ignore my mistakes :) )
Hi morning, and everything ok my English is already the translate.google.com
flash player about this and only for IE, Firefox use the other flash, generally those who do the firefox addon lie inside also, so I report it remains in the topic of firefox addon that used to ask what created the addon add to that used by default in the flash for firefox
Ciao.
  • 8 months later...
Ragazzi addon già aggiornato, e stato aggiunto anche la ultima v10.1.51.45, ragazzi come si capisce e una versione BETA, come si sa le versione BETA a volte non sono molto stabili o potranno fare uscire problemi, cosi usatelo a vostro rischio
Ragazzi se si usa nlite per integrare il addon, potrà segnalare un errore, ignoratelo e andate avanti, la cosa succede perche il addon e progettato integrarsi in cd dopo update pack, e in un cd pulito, cosi nlite quando usa [ExtraFileEdits], se non trova il line da modificare segnala il errore, ma come detto in questo caso andate avanti e sarà tutto ok
in caso che si usa RVMi e già tutto OK.
Ragazzi e consigliato integrarlo questo addon dopo update pack, e non in un colpo insieme.
Ciao a tutti.
Edited by OnePiece
  • 3 months later...
OnePiece,
A new update to Flash Player was released yesterday by Adobe. Please when you have time would you be able to update this addon.
OnePiece,
A new version of Adobe Flash Player has been released. When you have time please could you update your addon.
