Posted October 30, 200619 yr Is CCleaner a bit slow for you?I mean, mine used to take roughly 0.100 seconds to do a scan when there wasn't much to find (!!!). Can't be doing sitting around waiting for that.So, wander over to your programmes folder, find the CCleaner folder and find the file winapp.iniIn here are the references that CCleaner uses to hunt for junk files. Now, this hunts through multiple locations for Office (XP, 2003, etc) multiple version of Acrobat Reader (6.0 7.0 etc) and software I don't use. So, go through the file, and delete references to any software that you don't have. Save.Now, when I run CCleaner, a search takes 0.075 seconds! I've sheared off 0.025 seconds! Now, if that isn't efficient I don't know what is...Scheeze... not sure what's sadder, that I found this out, that I wrote it up here, or that some of you will probably implement this "tweak" http://www.bold-fortune.com/forums/index.p...ic=1326&st=
October 30, 200619 yr I've always asked about why the programmer supposed that every user for this tool will have this applications installed.Thanks for this one:)
December 29, 200618 yr There should be a method to scan for installed programs and add them to one list to clean, instead of having it scan through two huge lists.
March 25, 200817 yr @ricktendo: try this...i made a batch file that automatically runs crap cleaner and mru-blaster silently in the background. just create a shortcut to the batch file and double-click it. All you'll see is a command window showing you that CCleaner/MRU-Blaster are still working, but you can setup the shortcut to minimize this window too.@echo offTITLE Paranoiaecho Paranoia: Temporary File Killerecho =================================echo.cd C:\Program Files (x86)\MRU-Blaster\mrublaster.exe -silentecho -Working...echo.cd C:\Program Files (x86)\Crap Cleaner\ccleaner.exe /AUTOecho -Done!echo.
