Need a directive to logoff current user when manually installation finished
I need send a logoff directive to make registry entries take effects when manually installation finished
[Install]
BeginPrompt =BeginInst
RunPreSetupCommands =Create.i386:1
CopyFiles =program.files
AddReg =Uninst.AddReg
ProfileItems =Program.Addshortcut
RunPostSetupCommands=Delete.i386
EndPrompt =EndInst
;<----------------------------------------add Logoff directive here and with a prompt
I have Googled internet,only found directives to reboot machine like below
Reboot =  1
SmartReboot =A / N
any help is appreciated.
[Install]
EndPrompt =EndInst
Reboot =  1
SmartReboot =A / N
I think that the command would be
CMD /Q /C shutdown -l
just add this to Delete.i386 section and should work, or create another section under RunPostSetupCommands
check with ricktendo64 on syntax for the inf, but "shutdown -l" is logoff user
Edited by Jonnyboy
