Favorite intergrator program. 23 members have voted
  1. 1. Which intergrator do you use the most?
    • WPI Wizard
      2
    • nLite - Windows Installation Customizer
      12
    • RyanVM Integrator
      4
    • HFSLIP - Open source intergrator
      3
    • Other?
      0
  2. 2. Which intergrator will outlast the others?
    • WPI Wizard
      3
      8
    • RyanVM Integrator
      8
      4
    • Other?
      0
Please sign in or register to vote in this poll.
Please give your opinion on integrators and maybe insight to why one is better than the other. Pros-Cons, best support..etc.
If you use something other than the programs listed please add it here and I will add the name to the poll.
Thanks.
Edited by feared
nLite - Windows Installation Customizer & RyanVM Integrator. RyanVM Integrator for creating bootable XP CD/DVD, and for everything else = nLite - Windows Installation Customizer.
Looks like I'm the only one using HFslip here ...
I like HFslip for it's easy folder's implementation. Many kinds of folders to control what runs at when.
It also support autoit script in .au3 format (w/o compiling to exe)
Can easily replace system files with own resource-hack one (like shell32.dll, explorer.exe etc)
Takes registry (.reg) files w/o using batch command (At T13 and GUIRUNONCE)
Takes .inf files w/o using batch command (At T13 and GUIRUNONCE)
Easily place GUIRUNONCE applications w/o using batch command
U tweak only if u know how (for customization), thus face less issue to resolve.
Takes silent exe (w/o wrapping with entries.ini in cab/.7z/rar format)
The smallest in term of file size but probably the longest .cmd script in the world :D
Nice Geej,
Thanks for the info. I'll give this one a try!
  • 4 weeks later...
nLite and WPI here
Same here!
Stuff I always want in (like Update Packs, Kel's CP addons, stuff I can't live without (Taskbar Shuffle, QT bars etc.) and some minor tweaks and fixes) I use nLite for, the rest (also big apps such as Nero, Office etc) WPI.
Much more convenient, plus, I don't have to install everything when I'm just doing a test run (but I don't want to miss the aforementioned apps even then!).
I use RVMI for nearly everything. But I use Nlite as well. Some addons work with one, but not the other.
I've never used HFslip, and I didn't even realize WPIW would do integrations (I use it post install).
A tool is a tool...
whatever will get the job done is fine.
Thanks for the info Geej. It's always nice for me to try something new ;)
