February 17, 200916 yr Size : 10.1 MBCRC32 : 60DBD0C8MD4 : 2AC96BD5EBAA61C4A77549FA7C474E9BMD5 : EA1F3C8DA62160437A3700494A9C0BF1SHA-1 : 4B4A6533A859FCEC24F1E13FE6D71B3A7E349C60Publisher : GRETECHLicense : FreeVersion : 2.1.40.5106OS : 2000/XPLanguage(s) : EnglishGOM Player is a powerfull and easy-to-use FREE multimedia player.Supported formats :audio : ASF, ASX, MP3, OGG, WMA, WAV etc.video : AVI, Divx, MPEG, MKV, MOV, WMV, ASF, VOB, RM, 3GP, etc.Location :app : %ProgramFiles%\GRETECHlinks : Start Menu\ProgramsNOTE (07.10.2009) :Addon is now installable/uninstallable through Add/Remove Windows components: Edited May 11, 201213 yr by Ken@fri
March 14, 200916 yr Author UPDATED.Fix typo error :[Gom.DelayActions]HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce","GOM Player",,"rundll32.exe advpack.dll,LaunchINFSection GOMPlyer.inf,Launch.GOM.Register,1,N"to[Gom.DelayActions]HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce","GOM Player",,"rundll32.exe advpack.dll,LaunchINFSection GOMPlayr.inf,Launch.GOM.Register,1,N"
April 14, 200916 yr Author 13.04.2009 : ** updated from v.2.1.16 to v2.1.17** Minor INF modifications** Only true addon version is available but it's compatible with RyanVM & nLite (all files are cabbed)
June 22, 200916 yr Author 22.06.2009 : ** updated from v.2.1.17(Build 4610) to v2.1.18 (Build 4762)** Minor INF modifications (Gom.AddReg section)
June 23, 200916 yr The best player IMO. I'm using it with CoreAVC codecs and FFDShow and it's working perfectly. The best thing about it is that it automatically disables junk codecs from Nero etc, while you can choose your favorite/primary codec for any file type.N1!
June 23, 200916 yr Author The best player IMO. I'm using it with CoreAVC codecs and FFDShow and it's working perfectly. The best thing about it is that it automatically disables junk codecs from Nero etc, while you can choose your favorite/primary codec for any file type.N1!OK with you :thumbsup_anim: and it's a great honor for me, Boss :worthy: .
November 18, 200916 yr Author Version 2.1.21 is outUpdated to v2.1.21@ LUZR4LIFEThanx :thumbsup_anim: . Edited April 30, 201015 yr by Ken@fri
November 18, 200916 yr Author thanks a lot !!! :thumbsup_anim:You're welcome, man ! Edited November 18, 200916 yr by Ken@fri
December 5, 201014 yr Author Updated :- Gomplayer (v2.1.28 Build 5039)Fixed : - Start GOMPlayer opens a web page instead of the progie - GOMPlayer welcome web page adress (www.gomlab.com) during manual install ONLY Edited February 18, 201114 yr by Ken@fri
February 18, 201114 yr Author 18.02.2011Updated :Xtr3mAddOneRes.dll (v2.0.0.3)Regentry about Ultimate HTPC version (v2.0.2) Edited February 18, 201114 yr by Ken@fri
January 2, 201213 yr Author UpdatedGOM (2.1.36 Build 5083)Xtr3mAddOneRes.dll (v2.0.0.9)Fixed (in INF File)File copy optimization (addon size reduced)variable %KEY_WIN_CURVER% instead of %%KEY_WIN_CURVER% Edited January 2, 201213 yr by Ken@fri
