January 16, 200718 yr Hi guys, well at last here it is...the new release of the pack with 32bit icons!thanx to tihiy, the line is finally crossed!so check this out!and let me know if you found something while testingnew one with bugfixes and the begin off multilang installment.damian666vistapack2000 1.3.3 betai have attached a preview.preview Edited March 21, 200718 yr by damian666
January 18, 200718 yr Author cant get the preview on the page!whats wrong, why do i have only 28k left?the image is 50ksome help nic?oke here goes...previewdamian666 Edited January 19, 200718 yr by damian666
January 18, 200718 yr I'l test it when i go to my homeneed a screeshot..Upload the image to ImageShack.us and post the ThumbNail..THanks
January 18, 200718 yr Yes, imageshack is best option for this.If you'll have any trouble with this, let us know so we can right a step by step tutorial
January 19, 200718 yr Shell32.dll file not copied, during installation..The files after shell32 are also not copied, bwfore that all arefineVista 2000 BootScreen,My Comp,IE 7 ICon,etcStart Menu Vista 2000Vista Sounds and wallsall are fine..If possible add some screensavers..I think, you need to shut the Explorer.exe, and to copy the Shell32
January 22, 200718 yr Author hi man, thanx for testing.but just to be sure, did you install it in safemode?because thats really neccesary untill i find a way to defeat wfp.and in my computer, where your oemlogo is, if you got that.do you see any changes?because it did not work before and now i changed it so would like to know.thanx!!!damian666
January 22, 200718 yr Yeah, i missed to install in Safe Mode..I'm having dual OS, Win 2000 and Xp,and i cant know to boot into safe mode, becoz of dual OS.OEMLOGO, where is it?You mean this one?this is taken, when i test it first..
January 22, 200718 yr He's actually reffering to this one I think.(the dell logo) Edited January 22, 200718 yr by cygnus
January 23, 200718 yr Author He's actually reffering to this one I think.(the dell logo)yep, thats the one.could you please look in to it for me?!thanx damian666
January 23, 200718 yr if your reffering to finding that picture, then thats an easy one, its called "OEMLOGO.BMP" in the system32 directory. To get the button with more information, that ones called "OEMINFO.INI". The "OEMLOGO.BMP" file should be around the size of 169 x 57 or so. Give or take.Here is t he contents of mine when I loaded up XP on my laptop (OEM Restore CD)[General]Manufacturer=Dell Computer CorporationModel=Latitude CPx JSupportURL=http://support.dell.com/[support Information]Line1=When contacting Dell Computer for support, please haveLine2=the following information available.Line3=Line4= Service Tag: snippedLine5= Express Service Code: snippedLine6=Line7=For online support, please go to http://support.dell.comLINE8=For 24-hour technical support, in the USA, call 1-800-BUY-DELL Edited January 23, 200718 yr by cygnus
January 23, 200718 yr He's actually reffering to this one I think.(the dell logo)That screen shot seems like XP.Anyhow, Damien, not get like that in Win 2000It seems same as before installation..
January 25, 200718 yr Author well, if its the same, then it didnt work. so its back to the drawing table for me.well hope to fix it for the next version.damian666
January 26, 200718 yr It may be from XP, but its the same file in Windows 2000 Professional.Ofcourse cyg,I placed it manually on my own, and it works...i thought, it will work only in Win XP, but now proved. :angry:
January 26, 200718 yr Author hi guys, im going to do it differently.i made a pack using the XPize installer system.its called vistapack2000 beta1, and thats just what it is, beta.it installs fin ebut i need to adjust the uninstaller for it.so please try this on a vm or when you like the vista look on your life system.But be warned, it wont uninstall everything!still, i hope you guys are willing to test this for me.so see the first post for the link.thanx damian666
January 27, 200718 yr hi guys, im going to do it differently.i made a pack using the XPize installer system.its called vistapack2000 beta1, and thats just what it is, beta.it installs fin ebut i need to adjust the uninstaller for it.so please try this on a vm or when you like the vista look on your life system.But be warned, it wont uninstall everything!still, i hope you guys are willing to test this for me.so see the first post for the link.thanx damian666Add a uninstaller and give,becoz, i dont have a VM(due to my RAM is 128MB)
January 29, 200718 yr Author @tamilcheetasthe uninstaller now works, except for the cursor and sound scheme.this oke for you?or have any ideas for those pesky little m.f.?let me know.link in the first post.damian666
January 29, 200718 yr @tamilcheetasthe uninstaller now works, except for the cursor and sound scheme.this oke for you?or have any ideas for those pesky little m.f.?let me know.link in the first post.damian666I'll try and tell you in 2 days.i'm goin to format my HDD
January 4, 200817 yr Hey Damian, the pack is great, but my late 90's video card doesn't support 32-bit color depth.Maybe you could make a modified version with 16 or 24-bit icons for those of us who wantthe Vista look on a crappy old computer? :guiltysmiley:
