Posted May 17, 200916 yr I m in urgent need of good UPX Unpacker with procedure that how to unpack pack file if it is no gui version and a good C# Decompiler.Thanks in Advance.
May 18, 200916 yr Author Thanks Kels but it don,t seem to work for me. No problem if u give me the name of any retail version of C# Decompiler & UPX Unpacker below 100$.
May 18, 200916 yr You can also use PE Explorer for UPX unpacker and Delphi not sure for C# decompiler though
May 19, 200916 yr Author You can also use PE Explorer for UPX unpacker and Delphi not sure for C# decompiler thoughI know PE Explorer is able is Unapack UPX but how to save unpack product?
May 25, 200916 yr upx packed file can be unpacked with this simple code..upx.exe -d file.exeor use resource tuner
May 28, 200916 yr Author upx packed file can be unpacked with this simple code..upx.exe -d file.exeor use resource tunerThanks
