(Finished) I need helping building a PC on a budget
I have around 180 USD. I am looking to buy a mobo, cpu, ram (at least 2G) and a heatsink. Preferably Intel
Thank You
Also. Any help on CPU's to stay away from will be a big plus also.
Edited by LUZR4LIFE
ECS REALLY SUCKS!
I had one of their mobo's and hated it the whole time I used it.
Try this:
http://www.newegg.co...st=Combo.258819
http://www.newegg.co...N82E16820161028 2 to 4 of these
Thanks Kel. I thought about that combo and I am a Asus fan but I was trying to go a cheap as possible, but that would be the better deal if I go AMD.
I love Gigabyte boards! I've never had a single problem with them. Never skimp on your mobo!
If you can stretch your funds...
Mobo: Gigabyte GA-MA770T-UD3P ($80)
CPU: Athlon II X4 620 Propus 2.6GHz quad-core ($99)
RAM: Crucial 2GB (2 x 1GB) DDR3 1333 ($39)
Total: $218
ccl0 is right, you need to look at your PSU also since newer boards (like above) have different power connectors than the older ones. A decent 400W (plenty!) will set you back $60.
Total: $218
Thanks Mr_Smartepants, maybe I should hold off a little longer and save up more.
do you have a frys or microcenter near where you live?
edit: apparently you do :)http://www.microcent...on_heights.html
Yeah, They also know me by name. LMAO. They don't have a large CPU selection, well under a 100. That was going to be my 1st place but I didn't see much for my budget.
Edited by LUZR4LIFE
Oooh, very nice! Definitely go for the 1066 RAM (watch your latencies). The board is DDR2 so RAM is going to be dirt-cheap...go large! 4GB minimum, 8GB if you can stretch it.
That board should make a really nice HTPC should you decide to go that route in the future.
Nice choice!
Edited by Mr_Smartepants
Let us know how the build goes.
As soon as I get the parts I will take pics and take pics of the build. Maybe even video record the build. LOL With over 100 system builds I have never recorded any.
That's not bad at all, you've made a good choice.
Thanks N1, I actually spent day on it and I mean whole days. LOL. 3 different site and 20 - 30 different combos.
Edited by LUZR4LIFE
OK, my PC is built and running. Now several hours of software installation and imaging and I will be up and running. I will post pics later.
Windows Experience Index
Processor 6.5
Memory 5.9
Graphics 4.3
Gaming Graphics 5.4
Primary Hard Disk 5.4
