October 13, 200916 yr I have a HDD that I have ran scndsk on and when I try to copy things to the (bad)HDD it just hangs.I was wondering if anyone has used this program and have successfully repaired a bad HDD.THANKS
October 13, 200916 yr I have a HDD that I have ran scndsk on and when I try to copy things to the (bad)HDD it just hangs.I was wondering if anyone has used this program and have successfully repaired a bad HDD.THANKSI've used it.First on a 60GB old drive with 20% bad sectors and then on a new SATA drive with just some bad sectors.The SATA drive got repaired. I re-run a second check just to be shure.The 60GB one unfortunately seemed to be repaired but on a second scan the bad sectors reappeared.It was my notebook's drive. It became so slow that I had to wait almost 10 min for XP just to boot.Dumped it as soon as I could afford a new one .In my opinion it's good only if few sectors are bad, caused by an improper shut-down (logical bad sectors).Bad sectors tend to spread faster than a plauge. Edited October 13, 200916 yr by felix3650
October 13, 200916 yr Author Thanks, I am working on a 160G Lappy HDD. It found 40 bad sectors at the beginning (before 1%) and now it's @ 61.95% and has been working on around 100. I still have away to go and hope soon to hit a good patch again. LOL. I also planned on running it a 2nd time.
October 13, 200916 yr i've used some of these tools in the past http://hddguru.com/content/en/software/ they worked for me
October 13, 200916 yr Author Thanks ccl0. I had 147 bad sectors repaired but there was still a issue with the HDD. I ran it again and it picked up 4 bad sectors before I canceled it. I will check those tools out.
October 14, 200916 yr do you tried formating hard disk with zero fill. This is the only and best way that actually removes bad sectors.
