November 15, 200916 yr [Addon] Paint.NET v3.5.2 INT (x86 & x64)Paint.NET is free image and photo editing software for computers that run Windows. It features an intuitive and innovative user interface with support for layers, unlimited undo, special effects, and a wide variety of useful and powerful tools. An active and growing online community provides friendly help, tutorials, and plugins.It started development as an undergraduate college senior design project mentored by Microsoft, and is currently being maintained by some of the alumni that originally worked on it. Originally intended as a free replacement for the Microsoft Paint software that comes with Windows, it has grown into a powerful yet simple image and photo editor tool. It has been compared to other digital photo editing software packages such as Adobe Edited January 4, 201016 yr by beats
November 15, 200916 yr beats i think you need also to add a runonce switch like if you run the program from switch installer it run fineif added -ai it would add the Runonce registry cause not every one installs netframe in svcpack
November 15, 200916 yr Author Well, that's what the switchless installer is for. You can install it from anywhere, even on a live system.
November 16, 200916 yr Author Updated, as suggested by yumeyao. - Removed USINGWIZARD=1 condition from the LaunchCondition table. - Removed hardcoded "C:\Program Files\Paint.NET" as TARGETDIR from the Property table. Edited November 16, 200916 yr by beats
November 16, 200916 yr beats what i meant is see the runonce example by Rick that is good for tools that prerequisite net frame etc ..
November 16, 200916 yr Author I know what you mean, but in this case it's quite pointless IMHO. Either integrate it as a svcpack addon, or extract the switchless installer and run that from a location c.q. installation point you like. Also, the MSI itself checks if all requirements and conditions are met; if not, it will simply not install.
November 20, 200916 yr Greats beats!paitdotnet is my favorite program,it must be integrated into my XP CDthanks using MSI way creating it
November 26, 200916 yr thanks update,look forward to seeing version4 releasedbtw i found parameters DESKTOPSHORTCUT=0 PROGRAMSGROUP=Accessories still work for MSI
January 3, 201016 yr i try to install this addon on italian xp, but i have an error...maybe i change program dir in C:\Programmi\????how make this? thanks!
January 3, 201016 yr well what kind of an error i think there would be a runtime error use this http://www.mediafire.com/file/wnnkumyyzhk/2_VC2005SP1VC2008SP1.EXEit should fix your problem
January 4, 201016 yr ok i'll try and tell if works!if i try to install 2_VC2005SP1VC2008SP1.EXE in windows already installed after install open a txt window called Install.vbs, not close automatically??thanks
January 4, 201016 yr Author 1) The MSIs have some installation quirks on non-English Windows versions. It seems that they will be fixed in v3.5.2. See the Paint.NET forums. There is not much I can do about it.2) What's 2_VC2005SP1VC2008SP1.EXE ? An addon by someone?
January 4, 201016 yr Author Oh, just found out 3.5.2 Final was released. So... updated.Note, the original 3.5.2 MSIs still had hard coded paths to "C:\Program Files\Paint.NET" -> removed from Property table. Edited January 4, 201016 yr by beats
January 5, 201016 yr this is the error:how can i resolve this??i use the [Addon] Onepiece XP Post-SP3 AIO Update Pack v3.2.0 Ita...thanks Edited January 5, 201016 yr by dacorsa
