[Release] Printer UpdatePack and XPS Addon 1.2.0
What is this addon(or switchless installer) for:
1. The XPS Printer contains several common printer driver files, so making it a "true addon" saves space. Additionally, XPS Printer copies some files to driver cache, so we can just merge these files into driver.cab
2. For those who want to update their XP/2003's common printer drivers to latest, the "true addon" also updates them
3. As the reasons above, I decide to remove XPS in my .NET installer release. So this addon is to make it complete. Please note that .NET 3.0 installs without XPS Printer flawlessly only that XPS Viewer won't work because XPS Driver is not present.
Content:
COMMON PRINTER DRIVERS:
KB977225-v3(from vista):
(only in true addon)pcl4res.dll/0.3.5479.0
(only in true addon)pcl5eres.dll/0.3.5479.0
(only in true addon)pcl5ures.dll/0.3.5479.0
(only in true addon)ps5ui.dll/0.3.7601.21760
(only in true addon)pscript5.dll/0.3.7601.21760
unidrv.dll/0.3.7601.21760
unidrvui.dll/0.3.7601.21760
unires.dll/0.3.7601.21760
XPS PRINTER:
KB971276:
filterpipelineprintproc.dll/6.1.2600.5863
msxpsdrv.cat
msxpsdrv.inf
msxpsinc.gpd
msxpsinc.ppd
mxdwdui.gpd
mxdwdui.ini
printfilterpipelinesvc.exe/6.1.2600.5863
prntvpt.dll/6.1.2600.5863
KB977585(from vista):
mxdwdui.dll/0.3.6002.22298
xpsshhdr.dll/6.0.6002.22298
mxdwdrv.dll/0.3.7601.21760
xpssvcs.dll/0.3.7601.21760
Compatiblity with updatepacks:
NOT compatible with Onepiece's updatepack because his pack already include this part.
Compatible with u_h's updatepack but each time you integrate his pack(for an over-integrating) you must select this addon too.
Compatible with XP/2003 x86 of any service pack level.
Credits:
Thanks to Onepiece, ricktendo64 and 5eraph, for they inspired me to make it fully compatible with both nLite and RVMi
Downloads: 2 releases are available:
  • True Addon: Updated Files's Info not added for compatiblity for both XP/2003.
    Please note you must integrate this addon "with an updatepack" or "as an updatepack" when using RVMi.
    YumeYao_Printer_UpdatePack_And_XPS_Addon_1_2_0.7z MD5: 05e6c78098f5ed1aaa7ccc9917ee2801
  • Switchless Installer(T-13 Addon):
    YumeYao_XPS_Installer_Addon_1_2_0.cab MD5: 09921db0290e5f93c35558222a92ca35
  • Additionally, there is a hybrid installer(T-13 Addon) contains both XPS and WIC for smaller installer size:
    Integrating True Addons is recommended!! This is only for use if you just want the installer.
    YumeYao_XPSWIC_Installer_Addon_1_2_0.cab MD5: 2b52b6cfce758dad7ee2edda909fcb4d
Version Info:
Ver 1.2.0 2011-8-14
Updated KB2165648-v2 to KB977225-v3.
Ver 1.1.2 2011-6-17
Updated KB2165648 to KB2165648-v2.
Ver 1.1.1 2011-3-10
Added KB2165648, replaces KB983237.
Ver 1.1.0 2010-8-27
Misc fix, including slightly setup routine compact.
Ver 1.0.0 2010-8-12
contains KB971276, KB977585 and KB983237
Edited by ricktendo64
  • 6 months later...
  • 3 months later...
