November 6, 201113 yr im sorry if im posting in wrong section im new to the forum but i was just wondering what the differences were or the ones that matter in using addons vs the aio silent installs is one better to use than the other???
November 7, 201113 yr The differences are that silent installers actually install right before the machine is ready to use. The "addons" are integrated into the install media and are 'pre-installed'. There is not a "right" way to do it, so either way would work depending on the preferences of the person setting up the install media. I myself prefer the silent installers, but I will use "addons" if necessary.
November 8, 201113 yr I also prefer the silent installers. One of their advantages is that they can also be applied to an existing running system.Cheers and Regards
December 6, 201113 yr can you tell me about slint software install in windows 7 ..........? with Rt seven lite if i install slint software but he don't run after windows install.
March 4, 201213 yr I am alo new to the forum,so I dont understend what really addons are,is they preinstalled so there is no user interaction through install like is that with silent installer,and where I can find silent installer programs and how to find out what shwitch is used?
March 10, 201213 yr The differences are that silent installers actually install right before the machine is ready to use. The "addons" are integrated into the install media and are 'pre-installed'. There is not a "right" way to do it, so either way would work depending on the preferences of the person setting up the install media. I myself prefer the silent installers, but I will use "addons" if necessary."Pre-installed" like reverse integration???????
March 10, 201213 yr "Pre-installed" like reverse integration???????Yes. Although some addons do add silent installers.
