addons not completed?
Hi again
I"ve integrated some addons using w7t ver 98 into ultimate 64. After installation was complete on virtual machine, windows was left with a cab file opened in windows explorer and additional windows that asking where do i wand to extract the files, as if some addond is not fully automated...? Is this a new bug? Should'nt the addons installation be seemles and fully automated?
thanks
I have the same issue, windows askswhere is "apps" folder. When i select it nothing happens, same with silent installers. I used Flash and Java addons.
Might be helpful to tell us which addon it is? it could be the addon itself...
I"m not sure at wich addon it get this message. i need to check again. But here are all the addons used:
post-21539-0-90394200-1327697638_thumb.j
BTW, with all other previous versions of w7t, addons installation always involves cab files opened using windows explorer and remain open even after the addodn install setup is complete... But with the latest version, no matter what, i always endup with a windows asking me for extract destination folder... I need to check each addon and see if it was installed successfully... I'll report back
The same for USB installation.
Silent installers fails.
Previous versions I tested in December 2011 had no problem.
I prefer w7t .wa addons but long time no news from Reaper :rolleyes:
  • 4 weeks later...
