Great Results
I thought you would like to know that using the Technet image and doing things in multiple steps everything seemed to work great (even with the aborting message)
Step 1) IE9 + Hotifx - perfect
Step 2) SoLoR 336 updates - perfect
Step 3) 6 SoLoR Additions & 2 Offline updates as manual SFX- perfect
Step 4) 13 addons (see image) - perfect
http://clip2net.com/s/1L4MR
When I check my event logs and MS update it is exactly what I was hoping for. I will now test the driver packs, some removals and some tweaks. I will also be trying to reduce the number of steps to possibly 1 or 2
REALLY GREAT WORK!!! AWESOME TOOL!!!!
Hi
I´ve succesfully installed a customized System using b1408. All work fine.
You´ve made a great Job. Thanks für your work.
