Hi!
If tweaks Adjust Visual Styles is set to Best performance, after installation it is set to best performance from Performance Options, but is not 'applied' (=Windows/cursor/menus/etc. still have shadows, translucent selection..).
Thanks!
E: Sry, forgot some additional information:
Im using Win Toolkit v1.4.0.30, trying to use this tweak for Windows 7 Professional SP1 x64.
Edited by pawtycat
I've just fixed this, will be in v40.
Hi,
Im not sure if this bug is completely fixed. I recently installed version 1.4.0.40 and redid my stuff and installed. Adjust Visual Styles was set to Best performance. Here is an image of fresh Windows 7 installation:
Checkboxes are right; everything is set to best performance, but they are not 'applied'. As you can see, translucent selection rectangle is still there, cursor had shadow (couldnt capture that), also animations in the taskbar were enabled. Surprisingly windows had no shadows nor animations (thats atleast what I can point out).
Can you have a look at this? :)
Thanks!
Hi,
I made some research earlier. I dont know what you have already done, so I will start from the beginning. Going from up to down in the list:
First of all:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects]
"VisualFXSetting"=dword:0000000X
X=0 - Let's Windows choose
X=1 - Best appearance
X=2 - Best performance
X=3 - Custom settings
I think this changes the correct checkboxes for visual styles, so I guess this is what you got there, I dont know about the rest.
Animate windows when minimizing and maximizing [source]
[HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics]
"MinAnimate"="X"
To enable: X=1
To disable: X=0
Animations in the taskbar and Start Menu [source]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
"TaskbarAnimations"=X
To enable: X=1
To disable: X=0
Enable desktop composition [source]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\DWM]
"CompositionPolicy"=X
To enable: X=1
To disable: X=0
Enable transparent glass [source]
"ColorizationOpaqueBlend"=X
To enable: X=1
To disable: X=0
Save taskbar thumbnail previews [source]
"AlwaysHibernateThumbnails"=X
To enable: X=1
To disable: X=0
Show thumbnails instead of icons [source]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"DisableThumbnails"=dword:0000000X
To enable: X=0
To disable: X=1
(notice difference to other values; 0 enables, 1 disables)
Show translucent selection rectangle [source]
"ListviewAlphaSelect"=X
To enable: X=1
To disable: X=0
Show window contents while dragging [source]
[HKEY_CURRENT_USER\Control Panel\Desktop]
"DragFullWindows"=X
To enable: X=1
To disable: X=0
Smooth Edges of Screen Fonts [source]
"FontSmoothing"="X"
To enable: X=1
To disable: X=0
Use drop shadows for icon labels on the desktop [source]
"ListviewShadow"=X
To enable: X=1
To disable: X=0
Disable visual styles on windows and buttons [source]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\ThemeManager]
"ThemeActive"="X"
To enable: X=1
To disable: X=0
For the rest visual effects there is only 1 registry key for it: [source]
"UserPreferencesMask"=hex:XX,XX,XX,80,XX,00,00,00
Here we have 5 binary sets to toggle rest of the visual effects. Convert each binary set to hex for the first 3 and 5th hex entries in registry
The binary sets: 1001ABC0 00D1EF10 00000GH1 10000000 000100J0
..where..
(A) Smooth-scroll list boxes
(B ) Slide open combo boxes
(C ) Fade or slide menus into view
(D) Show shadows under mouse pointer
(E) Fade or slide ToolTips into view
(F) Fade out menu items after clicking
(G) Show shadows under windows
(H) Use Visual styles on windows and buttons
(J) Animate controls and elements inside windows (I had to do my own research for this, so not yet 100% guaranteed)
Examples:
Turn all off>
Binary: 10010000 00010010 00000001
Hex: 90 12 1 8 10
Registry: "UserPreferencesMask"=hex:90,12,01,80,10,00,00,00
Turn all on>
Binary: 10011110 00111110 00000111
Hex: 9E 3E 7 8 12
Registry: "UserPreferencesMask"=hex:9E,3E,07,80,12,00,00,00
Few examples:
Disclaimer: I have NOT tested these registery changes YET - use at Your Own risk!
Best performance.reg
; Visual Effects
; Do not Animate windows when minimizing and maximizing
"MinAnimate"="0"
; Disable Animations in Taskbar and Start Menu
"TaskbarAnimations"=0
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
"TaskbarAnimations"=-
; Disable desktop composition
"CompositionPolicy"=0
; Enable transparent glass
"ColorizationOpaqueBlend"=0
; Disable Taskbar Thumbnail Previews
"AlwaysHibernateThumbnails"=dword:00000000
; Disable Explorer Thumbnails (All Users)
"DisableThumbnails"=dword:00000001
; Disable translucent selection rectangle
"ListviewAlphaSelect"=0
; Dont show window contents while dragging
"DragFullWindows"=0
; Dont smooth Edges of Screen Fonts
"FontSmoothing"="0"
; Use drop shadows for icon labels on the desktop
"ListviewShadow"=0
; Disable visual styles on windows and buttons
"ThemeActive"="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ThemeManager]
"ThemeActive"=-
; Disable following:
; * Animate controls and elements inside windows
; * Smooth-scroll list boxes
; * Slide open combo boxes
; * Fade or slide menus into view
; * Show shadows under mouse pointer
; * Fade or slide ToolTips into view
; * Fade out menu items after clicking
; * Show shadows under windows
; * Use Visual styles on windows and buttons
Best appearance.reg
; Visual Effects
; Animate windows when minimizing and maximizing
"MinAnimate"="1"
; Enable Animations in Taskbar and Start Menu
"TaskbarAnimations"=1
; Enable desktop composition
"CompositionPolicy"=1
"ColorizationOpaqueBlend"=1
; Enable Taskbar Thumbnail Previews
"AlwaysHibernateThumbnails"=dword:00000001
; Enable Explorer Thumbnails (All Users)
"DisableThumbnails"=dword:00000000
; Enable translucent selection rectangle
"ListviewAlphaSelect"=1
; Show window contents while dragging
"DragFullWindows"=1
; Smooth Edges of Screen Fonts
"FontSmoothing"="1"
"ListviewShadow"=1
; Enable visual styles on windows and buttons
"ThemeActive"="1"
; Enable following:
I think you could also make a little extra form to create custom visual styles, takes little effort but you are hardworking d00d ;)
Hope this helps!
Edited by pawtycat
Hi,
I tried v44 other day and no cigar. Same thing happened; checkboxes are unchecked but features still there.
Im not sure why this doesnt work. I've tried to disable them using Setupcomplete.cmd few months ago and didn't work.
What do you think; can it be because these tweaks are executed by TrustedInstaller and not the user I log on (I make user at Windows Setup, not by unattended file)?
Quickpost - Im in the middle-of-nowhere with laptop and battery running out :)
