Posted February 20, 200817 yr This is my second tutorial, hopefully you guys have already watched the first one (if you haven't you should do so first). I will be showing the steps on making a "Program AddOn" using a program called ImgBurn.Required:Kels UberPack (you can manually install this)CMenu or Send2A3X (by MHz).Net Framework 2.0 (required for FGCBA)7-Zip (also required for FGCBA)ImgBurn InstallerVideo:ImgBurn Part 1 (18.4 MB)ImgBurn Part 2 (15.2 MB)ImgBurn Part 3 (21.5 MB)ImgBurn Part 4 (16.3 MB)ImgBurn Part 5 (43.0 MB)ImgBurn Part 6 (34.7 MB)Other:ImgBurn_AddOn (Example addon)Example ProfileItems Section[profile-items-section]Name=link-name(,profile-items-flags]CmdLine=dirid,(subdir),filename(SubDir=path)(WorkingDir=wd-dirid,wd-subdir)(IconPath=icon-dirid,(icon-subdir),icon-filename)(IconIndex=index-value)(InfoTip=info-tip)ProfileItems Flags0x00000001 Create menu item in Current User flag0x00000002 Delete menu item flag0x00000004 Create Start menu group under All Users\Start\Programs0x00000005 Create Start menu group under Current User\Start\Programs0x00000006 Delete Start menu group under All Users\Start\Programs0x00000007 Delete Start menu group under Current User\Start\ProgramsSpecial ProfileItems Flags0x00000008,2 = "%UserProfile%\Start Menu\Programs"0x00000008,5 = "%UserProfile%\My Documents"0x00000008,6 = "%UserProfile%\Favorites" <- Perfect for adding custom IE Bookmarks0x00000008,7 = "%UserProfile%\Start Menu\Programs\Startup"0x00000008,8 = "%UserProfile%\Recent"0x00000008,9 = "%UserProfile%\SendTo"0x00000008,11 = "%UserProfile%\Start Menu"0x00000008,13 = "%UserProfile%\My Documents\My Music"0x00000008,14 = "%UserProfile%\My Documents\My Videos"0x00000008,16 = "%UserProfile%\Desktop"0x00000008,19 = "%UserProfile%\NetHood"0x00000008,20 = "%WinDir%\Fonts"0x00000008,21 = "%UserProfile%\Templates"0x00000008,22 = "%AllUsersProfile%\Start Menu"0x00000008,23 = "%AllUsersProfile%\Start Menu\Programs"0x00000008,24 = "%AllUsersProfile%\Start Menu\Programs\Startup"0x00000008,25 = "%AllUsersProfile%\Desktop"0x00000008,26 = "%UserProfile%\Application Data" <- Perfect for QuickLauch0x00000008,27 = "%UserProfile%\PrintHood"0x00000008,28 = "%UserProfile%\Local Settings\Application Data"0x00000008,31 = "%AllUsersProfile%\Favorites"0x00000008,32 = "%UserProfile%\Local Settings\Temporary Internet Files"0x00000008,33 = "%UserProfile%\Local Settings\Cookies"0x00000008,34 = "%UserProfile%\Local Settings\History"0x00000008,35 = "%AllUsersProfile%\Application Data"0x00000008,36 = "%WinDir%"0x00000008,37 = "%WinDir%\system32"0x00000008,38 = "%ProgramFiles%"0x00000008,39 = "%UserProfile%\My Documents\My Pictures"0x00000008,40 = "%UserProfile%"0x00000008,41 = "%WinDir%\system32"0x00000008,43 = "%CommonProgramFiles%"0x00000008,45 = "%AllUsersProfile%\Templates"0x00000008,46 = "%AllUsersProfile%\Documents"0x00000008,47 = "%AllUsersProfile%\Start Menu\Programs\Administrative Tools"0x00000008,48 = "%UserProfile%\Start Menu\Programs\Administrative Tools"0x00000008,53 = "%AllUsersProfile%\Documents\My Music"0x00000008,54 = "%AllUsersProfile%\Documents\My Pictures"0x00000008,55 = "%AllUsersProfile%\Documents\My Videos"0x00000008,56 = "%WinDir%\Resources"0x00000008,57 = "%WinDir%\Resources\0409"0x00000008,59 = "%UserProfile%\Local Settings\Application Data\Microsoft\CD Burning"
February 23, 200817 yr Definitely a fan of your video tut's RickJust saw this post... Didn't realize you made another one.I'll get to watching this asap!To be honest videos tut's speak volumes to those of us that wish we could make our own addons but feel that the learning curve is too steep to climb for infrequent system reinstalls. However your vid's really seem to tap that urge in me to have a real attempt.You've clearly put a lot of effort into your tut's. I really am thankful Rick.
April 29, 200817 yr This is my second tutorial, hopefully you guys have already watched the first one (if you haven't you should do so first). I will be showing the steps on making a "Program AddOn" using a program called ImgBurn.Required:Kels UberPack (you can manually install this)CMenu or Send2A3X (by MHz).Net Framework 2.0 (required for FGCBA)7-Zip (also required for FGCBA)ImgBurn InstallerVideo:ImgBurn Part 1 (18.4 MB)ImgBurn Part 2 (15.2 MB)ImgBurn Part 3 (21.5 MB)ImgBurn Part 4 (16.3 MB)ImgBurn Part 5 (43.0 MB)ImgBurn Part 6 (34.7 MB)Other:ImgBurn_AddOn (Example addon)Example ProfileItems Section[profile-items-section]Name=link-name(,profile-items-flags]CmdLine=dirid,(subdir),filename(SubDir=path)(WorkingDir=wd-dirid,wd-subdir)(IconPath=icon-dirid,(icon-subdir),icon-filename)(IconIndex=index-value)(InfoTip=info-tip)ProfileItems Flags0x00000001 Create menu item in Current User flag0x00000002 Delete menu item flag0x00000004 Create Start menu group under All Users\Start\Programs0x00000005 Create Start menu group under Current User\Start\Programs0x00000006 Delete Start menu group under All Users\Start\Programs0x00000007 Delete Start menu group under Current User\Start\ProgramsSpecial ProfileItems Flagsplease make Mirror for download get error 501and 505
May 22, 200817 yr Hello mr.rick do you can learn more [strings] section the easy. And Do You can create Video for learn install font in method inf install i thank
June 4, 200817 yr ****!!! I would if i could, I deleted the videos from my hdd long agoHow to create empty folder to this patchC:\Documents and Settings\5\Application Data
June 5, 200817 yr How to create empty folder to this patchC:\Documents and Settings\5\Application DataOne way you can do it is by creating a "FAKE".txt[ApplicationData.Files]Fake.txtI am sure you know where to add the reset of the entries for the "fake".txtRick knows another way of doing it. I lost all the info I had saved from Rick on tips and tricks, but I know that was a easy way.
June 5, 200817 yr Thanks rick.I just discovered these the other day. I have tried infs by looking at Mrs Peels addons. Video tutorials are much easier to follow.
June 12, 200817 yr Your videos are awesome ricktendo64! It's realle easy to understand. You're such a good teacher By they way, I installed Kel's UberPacK v12.6 but it does not create a "Power Tweaks" in Right Click menu. How did you get this one? Manually?Cheers,KalEDIT: Is there an Addon containing only utilities for Addon makers? I mean, UverPacks comes with a lot of things I don't need, such as Image Resizer or Calculator Plus... Edited June 12, 200817 yr by Kal
June 12, 200817 yr Unfortunately, the Uber Pack is the only thing out at the moment. I started working on a pack just for addon making/XPCD making tools but haven't had time to finish it, I also lost all that I had so I will have to start over.
June 12, 200817 yr Ok I'm gonna "rip" UberPack Addon if Kels agree and if I find time I will remove any extra to keep just things we need to make addons and unattended xp cd. Edited June 12, 200817 yr by Kal
June 12, 200817 yr LOL. Good luck, I have tried it myself with no luck. I am sure he will have no problem with you doing that, just make sure to give him credit.
June 12, 200817 yr Author I will make a couple more... I was thinking some videos on how to make a 7zip sfx and another on how to edit MSI & other installers
June 12, 200817 yr Ok I'm gonna "rip" UberPack Addon if Kels agree and if I find time I will remove any extra to keep just things we need to make addons and unattended xp cd.Hmmm no I don't think I agree with a "Rip" of my pack. However you are free to build your OWN pack from the ground up with the tools you desire in it. Then release it.
June 12, 200817 yr Hmmm no I don't think I agree with a "Rip" of my pack. However you are free to build your OWN pack from the ground up with the tools you desire in it. Then release it.Sorry about that Kel.
June 12, 200817 yr Hmmm no I don't think I agree with a "Rip" of my pack. However you are free to build your OWN pack from the ground up with the tools you desire in it. Then release it.No problem, I understand. I will build mine from scratch and it will be a great practice for me. By the way, may I use your power tweaks menu? Because that's exactly what I want... And for this, I will have to copy/paste your registry entires for "ShellEx\ContextMenuHandlers"... I hope you don't mind. Kal Edited June 12, 200817 yr by Kal
July 3, 200816 yr Thanks Rick!I've finally completed my first two true addons. Now I just need a place to host them.
August 17, 200816 yr thanks rickstarting my addonwith some help with LUZR4LIFE thanks LUZR!soon as im done ill post it
June 8, 200916 yr :thumbsup_anim: Ricktendo! i am here in the forum for the last few days. but after examining your guidelines and tutorial i must say "you are incredible" i am really thankful to you
