May 22, 200719 yr This pack contains Aero, Aero II, BlackSpins V3 (9 Flavors), Chrome Glass, Conrast Black & White, Fedora, Fedora Inverse, Gant cursors 2006 vol 1, Gant cursors 2006 vol 2, Mac OS X Aqua, Mac OS X Aqua Swirl, Mac OS X Graphite, Mac OS X Graphite Swirl, Mac OS X Radioactive, Mac OS X Rainbow Swirl, OSX4XP, VistaPlastic (S&W), xFree, XZ-B-ONE, XZ-B-ONE Light Cursor Packs.They will be installed to their default folders, and also registry entries will be installed as default.If you use with a cursor pack that exist here, no problems will occur, as i used original names & folders.This packs contains just one cab and just one inf file. It was a hard work to collect them all, rename to a proper name, then build again.... 8) Thanks to Kelsenellenelvian & ricktendo64 for addon permissions, and also to all creators of these schemes, for their valuable efforts.No errors in FGCBA. (Tested and working fine.)Please refer to CursAIO.inf file in addon for Cursor pack informations.Enjoy! Download: NR_CursorsAIO_Addon_1.9.rarMirror: NR_CursorsAIO_Addon_1.9.rarRapidshare Mirror: http://rapidshare.com/files/85589920/NR_Cu...on_1.9.rar.htmlSize: 784 KB / Md5: 6965D8D75734A8BC942210ABAEDDB9FDChangelog:2007-07-16 v1.9: Added VistaPlastic Cursors.2007-05-22 v1.8: Added BlackSpins V3. Removed HighSpins V2 cursors. Edited January 22, 200818 yr by MrNxDmX
July 25, 200719 yr Hi, MrNxDmXHow I do to Mac OSX Radioactive to be my cursor default, at install this pack?0d
September 30, 200719 yr Yep... Anything with the name AddOn is meant for just that thing (you can manually install it too)You add it in the Hotfixes and Updatepacks area of nLite.
September 30, 200719 yr thanks.i have cursorxp how do i enable to use these? how do i find the mouse pointer properties? i tried to look in control panel but its not there :confused02:
December 29, 200718 yr All links is dead.Only rapid link is dead, other two links work just fine..Anyway, I'll attach it in this post so you can download it..NR_CursorsAIO_Addon_1.9.rar
January 22, 200818 yr Author Which ones do you suggest MadMaxX Rapid link is up again. Thanks N1K for attachment Edited January 22, 200818 yr by MrNxDmX
July 25, 200917 yr Looks like an awesome collection--I'm eager to try this out on my next build this weekend.Thanks for sharing your work.
November 7, 20197 yr On 5/23/2007 at 6:36 AM, MrNxDmX said: This pack contains Aero, Aero II, BlackSpins V3 (9 Flavors), Chrome Glass, Conrast Black & White, Fedora, Fedora Inverse, Gant cursors 2006 vol 1, Gant cursors 2006 vol 2, Mac OS X Aqua, Mac OS X Aqua Swirl, Mac OS X Graphite, Mac OS X Graphite Swirl, Mac OS X Radioactive, Mac OS X Rainbow Swirl, OSX4XP, VistaPlastic (S&W), xFree, XZ-B-ONE, XZ-B-ONE Light Cursor Packs. They will be installed to their default folders, and also registry entries will be installed as default. If you use with a cursor pack that exist here, no problems will occur, as i used original names & folders. This packs contains just one cab and just one inf file. It was a hard work to collect them all, rename to a proper name, then build again.... 😎 Thanks to Kelsenellenelvian & ricktendo64 for addon permissions, and also to all creators of these schemes, for their valuable efforts. No errors in FGCBA. (Tested and working fine.) Please refer to CursAIO.inf file in addon for Cursor pack informations. Enjoy! Download: NR_CursorsAIO_Addon_1.9.rar Mirror: NR_CursorsAIO_Addon_1.9.rar Rapidshare Mirror: http://rapidshare.com/files/85589920/NR_Cu...on_1.9.rar.html Size: 784 KB / Md5: 6965D8D75734A8BC942210ABAEDDB9FD Changelog: 2007-07-16 v1.9: Added VistaPlastic Cursors. 2007-05-22 v1.8: Added BlackSpins V3. Removed HighSpins V2 cursors. All the links are dead
