[Script] IntelliPoint/Type Pro v8.20.468
Microsoft IntelliPoint + IntelliType Pro v8.20.468 (silent switch makers)
Info: Builds custom silent switch installers for Microsoft Mouse and Keyboard hardware drivers/software. Detailed instructions are in the Readme.docx/pdf/xps
tabdownload.pngXP, Vista, 7 x86 English
http://adf.ly/1713566/msmousekb
MD5: a2054e5d0f7aa3bf60cadeb63b988d7e
Website: http://www.microsoft.com/hardware/mouseand...rd/default.mspx
Changelog:
May 27-11
- Updated IP program/drivers to v8.15.406.0
- Added new mouse/keyboard command-line # to Readme DOCX, RTF, PDF and XPS
Sep 5-10
- Updated IP program/drivers to v8.0.225.0
Mar 13-10
- Updated IP program/drivers to v7.10.344.0
- Added 3 new mouse command-line # to Readme DOCX, PDF and XPS
Jan 22-10
- Updated ITP program/drivers to v7.10.344.0
- Added 2 new keyboard command-line # to Readme DOCX, PDF and XPS
Jun 20-09
- Updated program/drivers to v7.00.260.0
- Added new keyboard command-line # to Readme DOCX, PDF and XPS
Apr 23-09
- Removed TRANSFORMS commandline and added /norestart
Apr 21-09
- Updated program/drivers to v6.31.258.0
- Removed some useless files from the installer
- Added Readme DOCX and XPS formats in addition to the PDF
- Added new keyboard/mouse command-line # to Readme DOCX, PDF and XPS
Sep 10-08
- Updated program/drivers to v6.30.192.0
- Added new keyboard/mouse command-line # to Readme PDF
  • Replies 50
  • Views 29.7k
  • 4 months later...
I am assuming this addon is made for the XP x86-32 operating system. How hard would it be to prepare an installer for the XP x86-64 OS?
Back when I was using 32 bits, I loved this "instructional" installer. I just hope there is one available for 64 bits.
IDK but I think if you 7zip the x64 version the same installer files (extract them from the installer) you can create a x64 version with the same x86 installer builder
Look in the xml to see if the command line switches for the different KB/MM models are the same as the x86 ones, should not be to hard to figure it out
The problem with using a 32-bit installer setup is that it tends to put the files in the wrong location due to the WOW64 redirection. Even if the files (in this case some hardware driver stuff) are 64bit, using a 32bit install process redirects those files to the wrong location. This is how it was explained to me over at RyanVM.net.
If there is a physical x64 bit executable that will do the same thing as your x32 bit executable above, I can use it. However I am going to work with what I believe to be an alternative way to make it all work.
Everything has to be extracted from the original MS executable. It contains several directories. Assuming the "updates" are already installed, one can just take the ipoint (or itype) directory and use the .MSI installer from that directory (with the appropriate parameters). Yes the MM and KB option would still apply to the MSI file. If you also use the /qn option, it installs silently. So in the end, I figured out a way to still make it work. Now I just need to test it on a standard install. I will let you know how it goes.
Look crashfly the addon builder will work the same for x64 as it it does for x86, it has nothing to do with the installer putting files "in the wrong location due to the WOW64", this is handled by the MSI
So if you just look at the 32 bit installers 7ip file you can see what files are needed, then you extract the x64 installer and 7zip those same files, now you build your silent switch intaller with the x64 files using my 7zip sfx and config.txt
The 7zip sfx works with both installers, the only thing that matters is whats inside the 7zip file
Rick, just found this tool. It's awesome! Thank you for this and for the continued work you do in the community. You're a real leader and a real asset! :thumbsup_anim:
Uncle Gadget
Thanks for the heads up Uncle Gadget
Thanks, ricktendo, for the fast update. However, I believe the 1033.mst transforms are missing from the 7-zip files. Am I correct or am I missing something?
Hey Rick I just download this tool and modify the installer to make it in Spanish, and it works!!. Thank you for this and all your work. :prop:
Hi ricktendo64,
Please update the link to the 7-zip file.
I'm watching this post.
I'll try to do the addon myself meanwhile.
Thank you.
Hi rick
IntelliType Pro 7.1 released
Download
Updated ITP only
Off Topic: GOSH! this makes me miss my Laser Mouse 6000, best mouse I had so sad it died
