[Addon] 7zCompress V1.0.0.0 (Send To Style)
Here is 7zCompress V1.0.0.0 (Send To Style)
I first found this vbs script on www.doitrightconsulting.net Its made by RogueSpear.
The default switch options in the .ini file are those laid out by code65536
I tested zippig files with winrar on best compression and 7zip with best compression from GUI. Well a lot of
times i got a greater compression with RogueSpear vbs script. His tool called 7zCompress V1.0.0.0
Install 7zip to ore this addon wont work
Features:
Higher compression with 7zip!
Small install
Send To Style
7zCompress V1.0.0.0 True addon:
Homepage:
7z compression command-line discussion:
Install from: True addon
MD5 hash: F6FF829038DE12CBCC650C5E35682B50
File Size: 67.7 KB (69,389 bytes)
Download here:
Update 16-04-2009:
I changend te addon a little thanks to sugestion of ricktendo64. Now it should work on all language versions.
Please try again. Keep in mind this version is only for 32bit Windows.
The zip program depents on the following files to run:
Edited by UtCollector
Is it just me?
I couldn't make it work.
Whenever i'm trying to 7zCompress a folder, i do get a Foldername.7z the problem is it always is 32 bytes and it is empty.
Also,i whenever i try 7zCompress a file, i do get a ".7z.7z" file created in the C:\, which also is empty!
Weird. I wonder if that may be due to Turkish operating system?
I've tried checking what listfile.txt contains.
When i tried compressing Program Files, it only has the below line in it.
C:\Program Files
When i tried adding multiple or single files, the listfile.txt had the correct lines in it but... Resulting .7z file is always empty!
Damn!
I changend the addon a little thanks to sugestions of ricktendo64. Now it should work on all language versions. Please try again. Keep in mind this version is only for 32bit Windows.
I'm running this on a 32Bit Windows XP SP2 Turkish operating system, installed to an imac.
Weird. It still repeats the same problem. Though i have no local characters in my paths, i always get the same 32byte files as result.
I tried 7zCompress on C:\Torrent folder to avoid any language problems. (My user name doesn't have spaces or Turkish characters either.)
But... No luck. I've tried on several files and folders within C:\ but...
I'll go mad. I've been working with the code altering, adding, removing... No luck.
I wonder if it is only me? (The original one does the same as well)
Edited by Nomadturk
@UtCollector:
The the 7zCompress works fine for me if I add 7z.dll to system32.
Thanks for the addon. :thumbsup_anim:
0d
@UtCollector:
0d
Hej thanks for testing with 7zip file it needs to work.
Happy you like it.
