Posted January 28, 200718 yr Windows Sidebar Styler v2.0.6 [WSS] by Stanimir StoyanovCompatible with Alky for Applicatinos and The Windows Sidebar AddOnI recomend you use RyanVM .Net AIO. Requires .Net Framework 3.0MD5: 2A4AE4547E0B6A121EA6FFB0CCE6FCB9Size: 4.57 MBBlog: http://www.stoyanoff.info/========================================================================Very Special Thanks:KelsenellenelvianSoKoOLzN1KRafael & ZoRoNaXStanimir Stoyanov
January 28, 200718 yr wow.. nice work Rick.. this will be good, cant wait to test it out..thanks,scOot3r!
May 5, 200718 yr Does Favorite WSS Skin & Gadget Settings Auto AddOn Maker same with Gadget Settings Grabber?
May 5, 200718 yr Author Nope, but I think I should combine both AddOn Makers into one that will detect WSS and ask if you want to back up both Sidebar Settings and your current WSS Skin... The WSS Skin Grabber grabs your skin settings and the Gadget Settings grabber grabs your gadget layout and settings...
May 12, 200718 yr After Install, Where can I find the Favorite WSS Skin & Gadget Settings Auto AddOn Maker in my computer?
May 12, 200718 yr Author OK... The WSS skin addon maker is simply the Windows Sidebar Styler skin you have added to your Sidebar, backed up and made into a addon... If WSS gets installed fine during SVCPACK.INF then when you first log into windows the sidebar will already have your favorite WSS skin applied.The Gadget Settings Grabber is the layout of your gadgets, example you set the clock and weather and other gadgets the way you want them... And you execute the gadget settings grabber and the layout will be backed up so when you first log in your gadgets are set the way you had them.
May 15, 200718 yr Sorry Rick. I still don't understand. As I understood, WSS addon maker is a tool to backup current setting and make an addon. So when I use the addon built by the addon maker I will have my favourite sidebar setting. Is'it true?
May 15, 200718 yr Author Not your settings... Your WSS Skin that you have applied to the sidebar will get backed up
May 17, 200718 yr WSS skin and sidebar gadget setting will be backup? Backup as addon? Then where can I find the backup file have been created?
May 17, 200718 yr Author the addon is created on your desktop, just apply your WSS skin and then run the tool, grab the addon ans slipstream it
May 17, 200718 yr Thanks Rick. Now I understand but the problem how do I run this Favorite WSS Skin & Gadget Settings Auto AddOn Maker?
August 17, 200717 yr Wowsy I've not been here for two days and what do I find first. Thanks Rick you are the greatest :thumbsup_anim: Edited August 17, 200717 yr by JurgenDoe
September 4, 200717 yr hey rick, the default sidebar skin has a shadow behind it. is there any way to completely remove this using the sidebar styler?
September 4, 200717 yr Author Completely remove it NO, WSS does not work that way.Using a Resource Patcher can... But you need a non Alky Patched sidebar.exe
September 4, 200717 yr well im not to good with resource hacker...how complicated is it to remove the shadow?and is there anywhere i can download an unpatched sidebar.exe?
