January 11, 201313 yr I have a small problem understanding the terms "Prerequisite" (WinToolkit) and "supersedes" MS-Bullettin. What does it mean exactly, when WinToolkit puts an update under "Prerequisite"? Means, it is necessary for other updates? I ask this, because KB2731771 has been put as "Prerequisite" by WinToolkit and MS says KB2726535 supersedes KB2731771; same behavior for KB2533623 Update for Windows 7, Windows Server 2008 R2, and Windows Server 2008 (KB2726535)Locale: AllDeployment: Recommended/Automatic Updates, WSUS, and CatalogClassification: Updates, Non-SecuritySupersedes:KB2533623 on Windows Server 2008KB2731771 on Windows 7 and Windows Server 2008 R2 If I look for "supersede" in the dictionary the meaning is "replace". Have a nice weekend. Thiersee
January 11, 201313 yr As I understand, Prerequisite means is needed for other updates to install correctly that's why Prerequisites will be integrated first before others.
January 22, 201313 yr yep, prereq.. means that this particular update/addon needs to be integrated in the first stage to make other updates work, i.e. IE9 is a prereq for cumulative IE updates. but as 'sperseded' status go, i'm lost too.how does the WT determine which KB superseds other KB?
January 23, 201313 yr Win Toolkit doesn't have a database, it's hardcoded Prerequisite's need to be intalled before certain other updates for example Internet Explorer 10 before an update for Internet Explorer 10.
January 24, 201313 yr Win Toolkit doesn't have a database, it's hardcoded Maybe this needs a 'non-hardcoded' solution? Would it be possible to have a "default" set of prerequisites and supersedes, and a way to change them (maybe saved in a text file or something)?This would help resolve the problem of (if) WinToolKit (ever) stopped being maintained and it would still allow for updates to be properly prepared.
