January 16, 201313 yr Hello, The title says all, addons are not installed with 1.4.1.8.Everything else is fine, tweaks, updates and sfx. Previously used 1.5beta, with same addons and that worked. Windows 7 Sp1 32 bits French.Tested in Virtual Box. Attached the session.last-session.zip
January 16, 201313 yr #AddonsF:\win7\addons\CmdOpen.2.1.0.0.x86.Windows7.or.8.AddOn.WA Just one comment to this AddOn: you don't really need it, you get the same result with two tweaks in WinToolkit. MfG, Thiersee
January 16, 201313 yr Author Hi Thiersee It's not exactly the same : CmdOpen is translated into my language (French). Back on topic: I have tested with exactly the same options (same ini) with WinToolkit 1.5.1beta and addons are installed, so it is clearly a bug in WinToolkit 1.4.1.8 Anyway, i have made silent installers (sfx) with stock installers of Notepad2mod and CmdOpen, I only use one AddOn now (Unlocker, because original installer is bloated).
January 22, 201312 yr This is actually the same bug as the porblem with the reg files not importing (there is already a thread on this). The Addon files, for some AddOns at least (such as 7zip), will be copied across, but without the reg files being added the AddOn appears to not be present.
January 23, 201312 yr Some user has already reported the reg file issue. I'm just waiting for a response.
