suggestion: 'bug' forum for wintoolkit
currently there is just one forum for miscellaneous wintoolkit issues/questions, and everything gets lumped into there.  http://www.wincert.net/forum/forum/179-win-toolkit/
it makes it hard to 'navigate' amongst all of it.
since work on wintoolkit has picked up again, there have been new builds and consequently new bugs.  so most of the topics on the first page in there are existing issues, bug reports, and solved bugs.  but all the question topics get pushed way down as a result.
so my suggestion is either a new 'bug' forum,  or a 'general help Q/A' type forum
I did some of the ones that were obvious they were about bugs from the first couple of pages just to make a start at this and left a redirection link as you asked.  But after Lego approves and the redirection links have been there for a day or two, I would think that the redirection links should be removed.  Otherwise, The main problem that ccl0 had:
... it makes it hard to 'navigate' amongst all of it.
still remains. I also think that Lego might want to create a "[sOLVED] WinToolkit Bugs" subforum, either inside "WinToolkit Bugs" or parallel to it, to make his job easier to keep track of things he still needs to do, while still having the solved info available to the forum search function.  Just a thought.
Cheers anb Regards
yes, in the future the bug forum will be great, but now theres all those arrows. i guess those are the redirects?
i also think the suggestion for a solved bug forum is a good idea as well.   but thats just my opinion :)
Hello guyz,
I have a simple question for WinToolkit (latest version)!
Why I can't go back to wolcome interface when I finis building my release of windows tweaks and all stuff ? I need to modify Unattented !
How sould I do that ?
Thanks !
Edited by KEiGHT
