June 2, 201411 yr Now that I'm back. Can members who have posted bugs in this forum please check if the bug is still there or not.1. If the bug is present then give the topic a 'bump'2. If the bug is NOT present please just say it's no longer a problem.I don't want to hunt for bugs which no longer exist Thank you.
July 18, 201411 yr Author Can users please try the latest version and let me know in there bug reports if they are still affected by it or not Thanks.
August 10, 201411 yr Yea, like the previous bughunter-competition.Winner get a request-wish fullfilled in WTK2.
August 10, 201411 yr Author I've been focusing more on v2 than v1 bug fixes. I will be adding as many requests as possible anyway
August 11, 201411 yr I mean WTK2 bugs (first beta/rcs) Yeah man thats great news!I will make a... little... list, for you,hihi ;D My opinion: (Translate: So its awesome! ) Edited August 11, 201411 yr by BrokenZer0
August 11, 201411 yr Author Haha, what is that video :D Well the converters are actually working, so feel free to look for bugs in that
October 4, 201411 yr wintoolkit not work with windows 10 technical preview ===> please solve itThat is not a bug. That is a feature request and he is not taking those right now.
February 29, 201610 yr i m getting error every time when i click on tweaks 1xBBBD09F763694E89E17A8FDC1859E546_Ex0600021E_frmAllInOne_en-US_643970 ***EXTENDED*** Node:Context-Menu ***EXCEPTION*** Object reference not set to an instance of an object. InnerException: Source: WinToolkit TargetSite: Void tvTweaks_Checked(System.Windows.Forms.TreeNode) ***WINTOOLKIT INFO*** Win Toolkit v1.5.4.4 Win Toolkit Directory: G:\wtk Anti-Virus: False User Temp Path: C:\Windows\WinToolkit_Temp WTK Temp Path: C:\Windows\WinToolkit_Temp Open Forms: frmAllInOne
January 5, 20188 yr i was update cache in toolkit got an error Error_1.6.0_1xD34A6A187F1147895C6EA57455B94A28_Ex06001FB2_frmToolsManager_en-US_803796.log
January 5, 20188 yr Hello Sakec, just run WinToolkit without pushing the update cache button and everything will work perfectly. Edited January 5, 20188 yr by sweden8
October 31, 20187 yr add package NetFx3 Win10 LTSB 1607 - works add package NetFx3 Win10 LTSC 1809 - errore
January 15, 20215 yr On 7/18/2014 at 11:14 AM, Legolash2o said: Can users please try the latest version and let me know in there bug reports if they are still affected by it or not Thanks. Hi! I tried the last version of Windows-ISO-Downloader 8.46 and the windows 10 options don't show any information at the select field.
January 16, 20215 yr If I have to be honest, I am literally shocked by the message that appeared on my screen. I use this wonderful program and I have never had a similar problem. Does anyone have the same problem ??? What should I do now? I want this program, I just think it for the best software and I love it! Where is this mistake, so far I have not had such messages
January 22, 20215 yr The same situation,and the same mistake🙄,never mind that I did it,the same answer dude!!!!Damn!!!!! Its not already surprise,I dont know what to do,your advice doesnt help me!
