Problem starting RunOnce in Win7 x64
I do not really understand this point with (not) starting of WinToolkit RunOnce :sad01_anim: !
If I install win7 (prof, x64) unattended I build an autologon as Admin (logon count 2-3) in the autounattend.xml and WinToolkit RunOnce.exe starts without issues;
if I install NOT unattended (normal) the installation happens as Admin and RunOnce.exe starts too!
  • Replies 80
  • Views 18k
Under system32 The txt
There is no folder under System32 you must look for!
In the folder System32 there is a file WinToolkit_RunOnce_Log.log!
BTW, I've downloaded your ISO (before Liam removed the link :D) and installed it in a VM: the log-file is exactly there!
Edited by Thiersee
Dont Share!
If you mean me, of course, is already deleted!
I saw only a difference in the log (I hope, it's a help for Liam);
your log:
Version: 1.4.38.11
Description:
-----------------STARTING--------------
Version: 1.4.38.11
Description: IsSystem: True
IsAdministrator: True
Version: 1.4.38.11
Description: WriteValue:HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnce | !1WinToolkit=WinToolkitRunOnce.exe | String
Version: 1.4.38.11
Description: Running as system. Aborting...
my log (RunOnce works):
Version: 1.4.38.11
Description:
Version: 1.4.38.11
Description: IsSystem: False
Version: 1.4.38.11
Description: Creating Shutdown Handle.
Edited by Thiersee
Dont Share!
your log:
Version: 1.4.38.11
Description:
Version: 1.4.38.11
Version: 1.4.38.11
Version: 1.4.38.11
Version: 1.4.38.11
Description:
Version: 1.4.38.11
Version: 1.4.38.11
switch for silent installer of NET4.5.2 is : /q /norestart
