WinToolkit_1.6.0.5 does not launch
i have downloaded WinToolkit_1.6.0.5_Portable  unpacked it and programm does not launch at all. nothing happens when i double click on in.
windows 10 x64
there is also other report that wintoolkit app crash on start
i have downloaded WinToolkit_1.6.0.5_Portable and When I start this program I get errors ?? :(
Windows ultimate SP1 X64 - Asustek Laptop
Problemsignatur:
  Problemereignisname:    APPCRASH
  Application Name:    WINTOO~1.EXE
  Application Version:    1.6.0.5
  Application Timestamp:    5ad4f4d4
  Fault Module Name:    KERNELBASE.dll
  Fault Module Version:    6.1.7601.23403
  Fault Module Timestamp:    56f58b17
  Exception Code:    e0434f4d
  Exception Offset:    000000000001a06d
  Betriebsystemversion:    6.1.7601.2.1.0.256.1
  Gebietsschema-ID:    1031
4 hours ago, jenyco2 said:
winToolkit_1.6.0.5 does not launch
win10 x64
Same here.
No log files were written. Tested on 2 PCs.
v1.6.0.1 works on same PCs.
Regards, Nemo
Edited by Nemo_G
if you guys noted, there was a HUGE difference in the compressed file's size.
Both exes were around 12MB (1.6.0.1 & 1.6.0.5), but v1.6.0.1 barely compressed to about 10MB, while v1.6.0.5 compressed to about 5MB. I suspect the problem lies there
51 minutes ago, jvidal said:
.... I suspect the problem lies there
I don't think so:
earlier versions were  high-compressed in the same way, but they were working.
And this is not the first time, WTK has this kind of crash...
Be patient and wait that Lego has a look at this thread.
