[Release] Kaspersky
Kaspersky Anti-Virus 7.0 French
Info : Kaspersky Anti-Virus provides classic anti-virus protection from all types of malicious programs. You can be sure that your computer and your data is safe as you work and surf the Internet. Includes antivirus and antispyware using our award-winning technology.
RyanVM Addon
MD5: 704587393CF9F1F33EBAAA1C0F45FDDA
Switchless Silent Installer
NOTE: After downloading extract the file and run the .exe...
MD5: FCF4EB12D1D1D8656EB1DE6DE2B8A2AC
Website: http://www.kaspersky.com/fr/
Edited by Makave2345
1 - extract the rar file
2 - copy it in SVCPACK folder
3 - expand the file SVCPACK.IN_ (expand -r svcpack.in_)
4 - add the file you extracted in svcpack.ini
5 - recompresse svcpack.ini (makecab svcpack.ini)
[tomorrow i think i'll make it as an addon & you just integrate it via Nlite 0r Ryanvm]
but i promise ya if i have time for do that
Arfaoui FirAs.......
I have updated your post to show that this is indeed a French version.
I have also updated your post with a addon that should be able to be integrated with NLite & RyanVM Integrator....
Please upload it to your own share site and edit your post, so I can delete it from my hositng site....
Also NOTE: I did not change anything from your original file... All I did was use your original
.exe (inside a SVCPACK folder) added a ENTRIES_Kaspersky.ini (with the correct info as seen below)
and compressed it using 7-Zip then uploaded it to my hosing site......
[general]
builddate=1/01/2008
description=Arfaoui FirAs Kaspersky Anti-Virus 7.0 Addon
title=Arfaoui FirAs Kaspersky Anti-Virus 7.0 Addon
version=v7.0
website=http://www.kaspersky.com/fr/
[EditFile]
I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram
[AddProgram]
kav7.exe
  • 3 months later...
  • 4 weeks later...
