[Addon] UltraISO v8.6.6
LUZR4LIFE
UltraISO v8.6.6
INFO: UltraISO is an ISO CD/DVD image file creating/editing/converting tool and a bootable CD/DVD maker , it can directly edit the CD/DVD image file and extract files and folders from it, as well as directly make ISO files from your CD/DVD-ROM or hard disk. At the same time, you can maintain the ISO bootable information, thus creating your own bootable CD/DVDs. You now have the power to make and edit your own ISO files, and then burn them to CD/DVD for your own needs.
  • Duplicate Disc to CD/DVD Image
  • Build Files/Folders to One ISO File
  • Organize and Manage Efficiently
  • Edit and Convert ISO File in Many Format
  • Make Bootable CD/DVDs
  • Create/Edit Audio CD Image
Along with the large capacity hard disk popularity, people were already used to copying compact discs to CD/DVD image files, generally used is the famous ISO 9660 international standards format, therefore CD/DVD image files are called ISO files. Because the ISO file retained complete data information of the compact disc (including compact disc boot information), you were allowed the convenience to use commonly used CD/DVD burning software (for example Nero-Burning ROM ) to record the disc with your CD-R/RW or DVD-R/RW over and over forever, it can also be used directly through Virtual CD/DVD-ROM drive software (for example Daemon-Tools ) .
UltraISO is in sole possession of the intellectualized ISO document format analyzer, it can process at the present time almost all types of image files, including ISO and BIN, it may even support new image files which are yet to be created. UltraISO can open these image files, directly extract files and folders, edit it and convert other image files to the standard ISO format.
UltraISO uses the double window unification user contact interface, you have the choice to only use the quick buttons and/or the mouse Drag & Drops, you can handle any CD/DVD image file easily.
Website: http://www.ezbsystems.com/ultraiso/
MIRROR
MD5 - 4777363C0A501BBC51FFB74A82F184CB
Size - 961 KB
Edited by LUZR4LIFE
Link to comment
Share on other sites
  • 2 years later...
