Posted January 13, 200718 yr http://gallery.artofgregmartin.com/tuts_ar...g_a_planet.htmlPlanet Texture: Here1. Start with a plain black image, 500x500 pixels. Make a new layer and, using the circle marquee select a circle about 2/3 the size of the root image.Fill it black, and leave the marquee active (do not deselect).Grab the Airbrush Soft Round 300 (we need a big, fuzzy brush).Set the opacity of the brush to 30% and the mode to Linear Dodge.We're going to pretend our light source is coming from the upper left (this is arbitrary).Start brushing color (we'll use hexadecimal value 664029) from about 8 o'clock to 2 o'clock, working towards the upper left corner. You want the result to look like the image to the left of this text. Basically, we've just established the main "sphere" of our planet.2.Alrighty, time to grab that planet texture I had you download. Open it up and go to Edit > Define Pattern. Name it whatever you want.This done, grab your trusty brush tool again (same exact settings as before, and go up to the brushes tab at the top of your screen in Adobe PS. You need to set the texture of your brush to the planet texture for the next step. The window for the brush settings looks like so...Select the pattern we just made from the menu of available patterns. 3.Repeat the brush motions that we used to define our basic sphere, only this time we're adiding texture to the planet. Again, brush from 8 to 2 o'clock only, leave the dark area dark, as it's the shadow on our planet. The result should look like so...(we've still got our marquee selecting the circle of our planet... don't deselect the planet quite yet).4.Now we're going to help our sphere a little via Photoshop's sphereize filter.Go to Filter > Distort > Sphereize, set it to 100%, and click OK. Just for good measure, repeat this action for an additional 50%.Once that's done, cut your planet from the layer it is wth the Edit > Cut command(or ctrl - x if you're shortcut savvy).Paste it into a new transparent layer and delete the old layer. This gets rid of some annoying pixel-y artifacts around the rim of the planet, leaving you with a nice, smooth edge to work with (because real planets don't have pixels!).This is now our "planet" layer. It would be a good idea to rename it as such so you know what you've got. 4.Next we'll add some atmosphere.Duplicate your planet layer, and then go toLayer > Layer Style > Blending Options.You can also get to the resulting windowvia right-clicking on the layer in the layer paletteand selecting Blending Options.Change the Blend Mode to Linear Dodge, and the Fill Opacity to 0% (as shown)Add an outer glow as shown... for the purposes of this tutorial, we'll use hexadecimal color value of 6283A7 for the glow color.Add an inner glow as shown... again, we'll use hexadecimal color value of 6283A7 for the glow color, because the two glows need to match, or they'll look really silly where they meet at the planet outline.5.Your planet should look something like this now. Not too shabby, but we've got way too much atmosphere on our planet.Create a new layer on top of your second planet layer. Link this layer to the top planet layer (the one with all the effects), and then merge the two together. This will make your effects just a layer instead of actual effects... so you'll now have a layer with just your blue ring of atmosphere in it. Youll need to set the layer mode of the atmosphere layer to Linear Dodge again to make it match the image once more. This is now our "atmosphere" layer. Again, it is a good idea to rename it as such so you know what you've got.6.Next we'll grab the eraser tool... Same brush size as the one we used to set our original sphere (Airbrush Soft Round 300 or sme equivalent big fuzzy brush).Gently erase between 6 and 3 o'clock on your atmosphere layer. You should get a result like this... (the white circle is the brush erasing).We're looking pretty good right now, but we're not done yet.7.Let's be nitpicky and add a tiny bit of embossing to the planet to really make it pop. Right now you should still have three layers total... atmosphere on top of planet on top of black background. Duplicate the planet layer.Go to Filter > Stylize > Emboss and emboss the sucker at an Angle of about -33 degrees, Height of 1 and Amount of 500%.This done, desaturate (ctrl - shift - u) the embossed layer and duplicate it again so you have two of the suckers.8.We need to isolate the light and dark elements of the embossed layers, because we'll play with both seperately (hence the two layers.)Use levels on the topmost one to isolate the lights by increasing the darkness until the main part of the layer is black with just a few white squiggles. This is now our "highlights" layer. You might want to rename it as such.9.Repeat this with the lower embossed layer, only this time pull the lightness up so you've got all white with black squiggles. This is now our "shadows" layer. Again, it might be a good idea to rename it as such.10.Change the black embossed layer mode to Linear Dodge, and the white embossed layer mode to Multiply. You'll notice a strong white outline in the shadow of our planet... use your big fuzzy eraser brush to erase it like you did the extra atmosphere we had earlier.At this point, you're just about done. Our embossing is a little blatant, however. Planetary details need to be subtle to work with the right sense of scale, so make our "highlights" layer about 50% opaque. The "shadows" layer should be good at about 70% opacity.I personally like a good amount of contrast, so I toyed slightly with curves (ctrl - m) to make the planet a little more vibrant. This is optional... you've now got a finished planet!Original LinkAll credits to ArtOfGregMartin.com. Check it out! Some great tutorials there.EDIT: My own personal attempt, tweaked a bit. I know the planet looks a little out of place But I might work on it more later. The texture is really useful! Edited January 13, 200718 yr by beemarin
January 13, 200718 yr Awesome tut Zaphirer, if you here more of them, please post here buddy.. :thumb_yello:
January 13, 200718 yr Funny thing is, a day before this was posted, I sent this very tutorial to WolfX2.
January 13, 200718 yr Funny thing is, a day before this was posted, I sent this very tutorial to WolfX2. You could post it here lazy officer
January 14, 200718 yr It is pretty nice, huh? If I find any more really good ones like this I'll post it up
January 28, 200718 yr Post it here in 1680x1050 resolution, 'cause I can't get it from the Shoutbox link..
January 28, 200718 yr That last pic I posted there wasn't made into a wallpaper, I think I may make it into one though. I'll keep you posted.
May 7, 200817 yr That tutorial is rly cool Done it a while ago too, Loved doing that tutorial makes you wanna do more of those planets Its still basic stuff though, i've seen people make a whole galaxy with stars and planets and all! thats soo cool to do! if you've got the time and skill of course
Please sign in to comment
Sign In Now
