Adding comments in popular-unattended creator may be useful.
It helps us remembering and becoming organised.
<!-- This is a comment in autounattend.xml somewhere -->
If you look at the file, it already has comments...
Also that file is almost "self-explanatory" anyway, if you look at it ;)
I agree with Etz, seems pointless as it's quite easy to read the autounattended file.
I have looked the file. You are right. That's quite clear. Nothing needed.
Cheers.
