[Solved] Strange things in AIO "Updates + Languages" section
Hi,
I was just trying to add the new Cumulative Security Update for Internet Explorer: July 10, 2012 ( IE9-Windows6.1-KB2719177-x64.cab ), but the update is not shown in the list.
Then I try again by pointing the "+" icon, but the update will not apear in the list.
After that, I removed another update "IE9-Windows6.1-LanguagePack-x64-deu.cab" and added it again with the "+" icon.
The update is shown on the buttom of the list.
I marked the update and choose "Move To Top", but it did not move to top, it moved to the middle of the updates ( I think, it was the position 250 ). So I must mark it again, must choose "Move To Top" again and then the update is on top.
Can someone confirm the behavior with IE9-Windows6.1-KB2719177-x64.cab and the "Move To Top" button ?
THX
P.S.: v1.4.0.32
Edited by caphp
Can someone confirm the behavior with ......... the "Move To Top" button ?
I confirm it!
BTW, with "Move to Bottom" is the same behaviour.
Edit:
I tried version 1.4.0.27 again and this behaviour was also present!
MfG, Thiersee
Edited by Thiersee
Checked 1.4.0.33
The problem with IE9-Windows6.1-KB2719177-x64.cab still exists.
The "Move To Top" problem is solved.
@Lego
Please take a look at the cumulative security update. Its really important. THX
I just added this update with v33... and it worked fine
Checked 1.4.0.33
Thanks for the response and I apologize for not being clear with my post... I was referring to the difference between my work and caphp's which jgp clarified... thanks again.
KB982861 is the IE9-Installation from 3/14/2011
KB2719177 is the IE9-update from 6/12/2012.
Regards, Thiersee
Because the update is not needed, it's only needed when you have Windows 7 RTM installed and your installing Service Pack 1 normally.
  • You install Windows 7 Service Pack 1 (SP1) or Windows 2008 R2 Service Pack 1 (SP1) on a computer.
  • You install some other updates before you restart the computer to complete the installation process. Or, the service pack is installed at the same time as other updates by using Windows Server Update Services (WSUS).
This issue occurs because Windows tries to perform operations in the Primitive Operation Queue (POQ) two times during the service pack installation process. The second attempt to perform these operations fails (because the operations have already been performed). Therefore, Windows generates a "0xc0000034" error.
You're not installing a Service Pack as it's already integrated.
Your site does not understand the Russian character set. It is necessary to correct this behavior :type:
Example:
Здравствуйте, ваша программа работает отлично!
Need to change the title of the code page
<meta http-equiv="content-type" content="text/html; charset=iso-8859-1" />
to:
<meta http-equiv="content-type" content="text/html; charset=UTF-8" />
Edited by loginvovchyk
Example:
to:
Done, please try now. It should work now, here it goes:
Тестирование набора символов
