Posted July 21, 200717 yr Luna Element Blue:Here's the official link: http://www.deviantart.com/deviation/47567543/ Size - 1.04 megs MD5Hash = 86053c428163b8940711ef60c73dda97....===============================================Luna Element Black:Full Replacement theme..Here's the official link: http://www.deviantart.com/deviation/57571128/Size - 886kb megs MD5Hash = 5cb866def923944c6c1c956260da9589....DON'T FORGET TO PATCH YOUR UXTHEME.DLL!!!
July 21, 200717 yr Luna Element Blue:Here's the official link: http://www.deviantart.com/deviation/47567543/ Size - 1.04 megs MD5Hash = 86053C428163B8940711EF60C73DDA97....===============================================Luna Element Black:Visual Style Only!!!Here's the official link: http://www.deviantart.com/deviation/57571128/Size - 216kb megs MD5Hash = FD501669CB0607166620200BF623EF68....DON'T FORGET TO PATCH YOUR UXTHEME.DLL!!!Thanks Kel! Nice work. Also great job with the CPL and Uber Packs! I love them both. Very Nice Work! :thumbsup_anim: :clap: :prop: :welcome:
January 6, 200817 yr Kelsenellenelvian!Is there a chance you might make a version of this theme, so that it would replace the default Windows XP theme with Luna Element 5.1 ?I think its far more superior than the original blue-green theme, yet similar to it (except of the very good new-style start menu) and this also has a very cool eyecandy wallpaper.I haven't found a way to make it install default. If i use the integrator (1.4.3 or 1.5RC1) it just installs the theme, and is only an available theme for selection in display theme settings.Can you help me out with info on how to make it integrate right with the integrator (at least to set it as default theme), or make a replace addon luna element (like there is a vista sound scheme that replaces the original xp sounds) ?Thanks in advance, and great work! Edited January 6, 200817 yr by PeaNut
January 7, 200817 yr Author Sure can do! Which color do you prefer Blue or Black and which start menu size?
January 7, 200817 yr Sure can do! Which color do you prefer Blue or Black and which start menu size?Wohoo! Thank ya very much!I prefer the blue one... with the compact style.Will test it out tonight if its ready!
January 8, 200817 yr Author Here you go unrar this and overwrite the existing luna.th_ that is in your i386 dir and DON'T forget to patch your uxtheme file..
January 8, 200817 yr Here you go unrar this and overwrite the existing luna.th_ that is in your i386 dir and DON'T forget to patch your uxtheme file..Is this a "redirect" theme that points to the Luna Element 5.1 (when integrated), or i don't understand something clearly, because the attachment is only 1,68 Kilobytes in size... ?
January 13, 200817 yr I had the time to make a new integrated install, works perfectly, TYVM! :thumbsup_anim:
May 16, 200817 yr I want the black one as theme just like blue one. But it is only msstyles:( I can't do it my default theme at windows installation...My wintt.sif will be like that: [shell]CustomDefaultThemeFile="%WinDir%\Resources\Themes\Lune Element 5.1.theme" (or similer, you understand)If exists, i want the black theme just like the blue one. So I will edit the le.cab file and put in it my favourite wallpaper. Then, write in the winnt.sif file to make the default theme. Black one could be nice for me if you can release a real theme just like blue one. Sorry for my bad English. Good luck for myself:) Edited May 16, 200817 yr by baris7seven
May 18, 200817 yr Author OK finished...I added a wallpaper to the black one and also made a luna.the to set it as the defualt theme.DO NOT forget to patch your uxtheme.dll file!
May 22, 200817 yr Here you go unrar this and overwrite the existing luna.th_ that is in your i386 dir and DON'T forget to patch your uxtheme file..How do you get it to be the default theme again? I like the Luna Element Blue with Normal Startmenu, but where's the attachment at? Edited May 22, 200817 yr by hairbautt
May 22, 200817 yr Author Here ya go...UnRAR then overwrite the one in your souce with this one...OH and of course integrate the blue theme pack
May 23, 200817 yr hello , i succesfully apply your package of dark's as default by following your methodbut, it seems to not to use wallpaper as default as wellcould you fix the package of dark's again?
May 23, 200817 yr i edited luna.the and found that[Control Panel\Desktop]Wallpaper=%WinDir%web\wallpaper\Bliss.bmpTileWallpaper=0WallpaperStyle=2Pattern=ScreenSaveActive=0your wallpaper is bliss.jpgis this the key wrong??
May 23, 200817 yr Author No windows, during setup and installation automatically converts bliss to a bmp formatt.
January 20, 200916 yr Hi, this theme looks great but the links aren't working anymore. Can you please upload them again? Thanks
January 20, 200916 yr The link is broken plase update link. Why dont you use rapidshare? The server you preferred is not working properly...
January 20, 200916 yr the download links dont work. can you fix the download links please..thanks i have them now.......... Edited January 21, 200916 yr by dude-uk
January 21, 200916 yr Author The link is broken plase update link. Why dont you use rapidshare? The server you preferred is not working properly...I will NEVER use rapidshare! This is my own host. I took the damned things down after over a 6 months of innactivity!If you guys like the addons you need to post to keep them up. I won't waste server space on addons that seemingly no-one wants.Anyways re-upped...
January 21, 200916 yr I will NEVER use rapidshare! This is my own host. I took the damned things down after over a 6 months of innactivity!If you guys like the addons you need to post to keep them up. I won't waste server space on addons that seemingly no-one wants.Anyways re-upped...Thanks for this. It seems like I have a lot of your add-ons, they're all great Is there a master list of all your add-ons somewhere?
