Guide: Creating addons
Requirements: 7zip
I recommend using InstallWatch as it records what new registry entries there is and also which files have been modified.
Every .WA needs a tasks.txt file within it so W7T knows what to do with it, an example is below:
Make a folder i.e. D:\Addon
Step 1: Tasks.txt
Name=Mozilla Firefox
Creator=Legolash2o
Version=3.0.6
Arc=x86
Description=Open Source internet browser.
[CopyFolder]
Mozilla Firefox::Program Files
[CopyFile]
Mozilla Firefox.lnk::Users\Public\Desktop
Mozilla Firefox.lnk::ProgramData\Microsoft\Windows\Start Menu\Programs
Name
This is the name of the program or addon
Creator
Your name or the maker of the addon
Version
The version of the program/addon you are making
Arc
Which version of the program you are making their are only 3 choices
x86 - These addon will work on both x86 and x64 images, if it is integrated into x64 it will put the files in folders like "Program Files (x86)" or "SysWOW64".
x86! - x86 only
x64 - x64 only
Build (Optional)
This will only let you install the addon on certain versions of windows i.e. 7068. This is useful for patches like Themes.
Build=7000! *Build 7000 only
Build=7000 *Build 7000 or newer
Website (Optional)
When the addon is double clicked in the list, it will open the website specified
Step 2: Copying Folders
[CopyFolder]
This is easy...
name of folder::where to put it
Mozilla Firefox will be copied into Program Files folder.
Put Mozilla Firefox folder in your root addon folder (D:\Addon)
Step 3: Copying Files
[CopyFile]
Put Mozilla Firefox.lnk in your root addon folder (D:\Addon)
Also easy....
name of file including extension (.exe, .lnk, whatever):: folder to put it in
Firefox links will be copied to both Desktop and Start Menu
Step 3: Registry Entries
Just simply copy the exported .reg file into the root folder of the addon (D:\Addon)
Note: You may want to clean the registry file and remove entries like your name, serial codes, temp stuff like MuiCache and sometimes there is a really long entry and i mean long, remove that too!
Normal Registry File
[HKEY_LOCAL_MACHINE\SOFTWARE\1]
"Example"="This is an example string"
"Example2"=dword:00000001
Delete Key (Note they hyphen (-) before HKEY_LOCAL_MACHINE\)
[-HKEY_LOCAL_MACHINE\SOFTWARE\1]
Delete Value (Note the hyphen (-) after the equals sign(=))
"Example2"=-
Step 4: Creating the addon file (.WA)
Using the example above you should have something similar to...
D:\Addon
D:\Addon\Mozilla Firefox\ (with firefox files within it)
D:\Addon\Mozilla Firefox.lnk (shortcut)
D:\Addon\Tasks.txt
D:\Addon\Example.reg (optional)
Simply highlight all the files in the folder, right-click, 7zip > Add to Archive
Once its open change .7z to .WA make sure its on Ultra compression and click OK
Tasks.txt Example
7zip x64
Name=7-zip
Creator=Legolash2o
Version=4.65
Arc=x64
Description=7-Zip is an open source file archiver designed originally for Microsoft Windows. Blah.
[CopyFolder]
7-Zip::Program Files
[CopyFile]
7-Zip File Manager.lnk::ProgramData\Microsoft\Windows\Start Menu\Programs
7zip x86 only
Name=7-zip
Creator=Legolash2o
Version=4.65
Arc=x86!
[CopyFolder]
[CopyFile]
Crap Cleaner for both x64 and x86
Name=Crap Cleaner
Creator=Legolash2o
Version=2.18.878
Arc=x86
Description=Cleans all the crap on the computer
[CopyFolder]
CCleaner::Program Files
[CopyFile]
CCleaner.lnk::ProgramData\Microsoft\Windows\Start Menu\Programs
Notes
When it comes to the "Description" in tasks.txt it can only be one line, it can not be multiple lines.
For example:
This program has the following features:
*blah
*blah
*blah
The Addon Integrator will only display "This program has the following features:"
Edited by Legolash2o
  • 4 months later...
  • Replies 54
  • Views 69.6k
  • I am having trouble installing Installwatch. Whenever I run the setup file I get am error saying "Unable to execute. "C:\Users\Sean\AppData\Local\Temp\pft1~tmp\SETUP.EXE" /SMS" Then I click on the ok
  • Yea, manually install my addon using the inf file: 1- Extract the addon to a sub dir 2- Create a folder called i386 (Optional) 3- Move the .cab file into the i386 folder (Optional) 4- Right click the
  • For those who want files in the user profile folders... Use something like: [CopyFolder] Folder1::Users\Default Folder1::Users\Default\AppData:: [CopyFile] Folder2\1.exe::Users\Default Folder2\1.exe::
I am having trouble installing Installwatch. Whenever I run the setup file I get am error saying "Unable to execute. "C:\Users\Sean\AppData\Local\Temp\pft1~tmp\SETUP.EXE" /SMS" Then I click on the ok button and get the dialog box saying "Package for the web error. Unable to execute the specified command line!" I took ownership of the file and have full rights but it's still not working. Any ideas anyone? Thanks in advance. BTW, I am running Vista Ultimate 32. Thanks again. Sean
I had trouble with that download.
I Think its to do with UAC What i did was turn it off and then restart the system and i ran the installtion and it worked..
Yeah, I tried that but still didn't work. This is driving me nuts, lol. Thanks for the reply though, any more ideas? Sean.
Yeah, I have tried downloading it from several different places, including the official site but with no luck. Is there any other program I could use for help making addons?
try this topic
4- Right click the .inf file and choose install
5- Show the .inf installer the location of the .cab file (if steps 2+3 were skipped) and click ok
  • 4 weeks later...
Im gonna do some work to the Addon Maker so it lets you create silent installers, but you can still make one manually and integrate using the new alpha.
if you mean by Silent Installer an exe file
then Yay i hope it's done sson
so i can add it's support to my tool :D
Use something like:
[CopyFolder]
[CopyFile]
Folder2\1.exe::Users\Default\AppData
if you have any registry values or shortcuts (.lnk) then use
"%HomePath%\..." within those values/shortcut itself
Every user account created will have the folders/files by default :)
Use something like:
[CopyFolder]
Users\Default:Folder1
Users\Default\AppData:Folder1
[CopyFile]
Users\Default:Folder2\1.exe
Users\Default\AppData:Folder2\1.exe
well Lego i got a few questions
since i'm working on the WA Installer
i wanted to make sure
of some stuff
<< shouldn't that be double :: not only a :
<< i didn't get that line shouldn't the other side be the destination dir
and
<< that in the task.txt or in the shortcut path it self
and if it's in the task is the the only variable or there would be more ?
of some stuff
and
Opps, sorry.
1. Yep double ::
2. Fixed
3. shortcut or registry value itself not in the task.txt
I was wondering if %DefaultProfile% means it will go to all the user profiles. Where does %Desktop% Go to ?
Only the first time user?
%Desktop% will go to the desktop of all users, so if you have a shortcut that you want to put onto the desktop use %Desktop% to get that file to the desktop. :)
Edited by snakecracker
  • 4 weeks later...
Hey Lego. I have a few questions on making addons for 7. Under [CopyFolder], do you add all of the other folder names also, plus the folders?
Ex. System32 etc.
  • 4 weeks later...
Hi,
i've a problem with registy-entries in an addon. I created a addon for "VLC Media Player" (German). For the contextmenu on directories the following code is used:
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Directory\shell\AddToPlaylistVLC]
@="Zur VLC's Wiedergabeliste hinzufügen"
The Problem is that after integration with W7T and installation the "ü" from "hinzufügen" is converted to somthing strange. The Reg is saved as "Unicode". Do i have to save the Reg as "ANSI" or "UTF-8"? What can i do? Maybe its a bug in W7T?
Please help me
Thanks
Edited by testesser1
I am updating my addon maker and tryng to incorporate this into it and I have 2 question.
1 - Will "Mozilla Firefox::Program Files" install into "Program Files (x86)" on 64-bit systems?
2 - can i run a command or installer, yet?
Thanks
Thanks
about first question
if you made the
Arc=x86 then yes
second
i think not yet but you can try it with runonce commands
it's the only known way now
if you made the
Arc=x86 then yes
second
Thanks
Would the addon be called a "WA" addon or a "W7T" addon?
Thanks
if you mean what you should call it then i think you should call it
W7T addon if about the the extension should be .WA
compressed with 7zip
  • 9 months later...
Requirements: 7zip
Hi,
Can't change .7z to .WA on 7zip :blush: .
The available Archive format are: 7z, tar and zip
I'll appreciate any help
Edited by coucou
