May 12, 201214 yr Here is something you guys might find useful, Its a must have if you are into driverpack making and it comes with InstallShield (used to extract drivers/files from installers with data1.cab/hdr packages created with InstallShield) Here is my SendTo style installer, I extracted the files from InstallShield 2018 SP1 (may also require Visual C++ Runtimes) Download: https://mega.nz/#F!SpQgkAII!07wjhxEh89CUQlTV8oXPyg MD5: 7de20da0f41b1425739f23ad49b31a59 Size: 18.2 MB For unattended install Passive:<installer>.exe /SILENTQuiet:<installer>.exe /VERYSILENTOther command-line options:/NOICONSInstructs Setup to initially check the Don't create a Start Menu folder check box on the Select Start Menu Folder wizard page./COMPONENTS="!help"Do NOT! install "Help files" components. (If a component name is prefixed with a "!" character, the component will be deselected.)/TASKS="sendtoicon,desktopicon,quicklaunchicon"Deselect all tasks, then select the "desktopicon", "sendtoicon" and "quicklaunchicon" (Vista & under) tasks. (Use the /MERGETASKS parameter instead if you want to keep the default set of tasks and only select/deselect some of them.)/MERGETASKS="desktopicon"Keep the default set of selected tasks, but additionally select the "desktopicon" tasks. (If a task name is prefixed with a "!" character, the task will be deselected.) Edited July 15, 20187 yr by ricktendo Updated 2018 SP1
April 5, 201313 yr Author Updated with files from InstallShield 2012 Sring SP1 (a.k.a. v19.0) and updated installer to use inno vs 7zip sfx
February 2, 201412 yr Author Updated with files from InstallShield 2013 SP1 (only FrmWrkLib.dll updated to v20.0.0.496)
August 21, 201510 yr Updated with files from InstallShield 2015?Download: https://esdhttp.flexnetoperations.com/cgi-bin/download?rid=3638705517&rp=DTM20150821212129NTMzOTI5Mzg2
July 10, 20169 yr On 21.08.2015 at 11:23 PM, Forseti said: Updated with files from InstallShield 2015? Download: https://esdhttp.flexnetoperations.com/cgi-bin/download?rid=3638705517&rp=DTM20150821212129NTMzOTI5Mzg2 InstallShield Cabinet and Log File Viewer 2015 SP1 22.0.0.330 (MediaBuild40.dll 22.0.0.330)ISCABViewer2015.rarInstallShield Cabinet and Log File Viewer 2016 SP1 23.0.0.428 (MediaBuild40.dll 23.0.0.428)ISCABViewer2016.rar Edited September 22, 20178 yr by vodek
